[Bio] / FigKernelPackages / raedraw.pm Repository:
Log of /FigKernelPackages/raedraw.pm
Tue Feb 5 02:05:06 2008 UTC (12 years, 1 month ago) by parrello
Changes since 1.13: +15 -13 lines
Changed POD heading levels.
Tue Aug 1 17:57:15 2006 UTC (13 years, 8 months ago) by overbeek
Changes since 1.12: +26 -7 lines
RAE: fixing genome drawing for comparative genomes
Tue Jun 6 00:58:23 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.11: +14 -0 lines
RAE: Initial release of a new interface that plots a heatmap of proteins that are in subsystems. The initial release is just based on a single attribute (ss_connections), but I hope to extend it to mapping on different things. Makes pretty tables though!
Mon Dec 5 19:06:30 2005 UTC (14 years, 3 months ago) by olson
Changes since 1.10: +17 -0 lines
Added license words.
Thu Dec 1 22:28:13 2005 UTC (14 years, 4 months ago) by overbeek
Making attributes work for Ed
Mon Jul 11 21:25:03 2005 UTC (14 years, 8 months ago) by redwards
CVS Tags: caBIG-00-00-00, caBIG-dataload-0, merge-trunktag-bodev_news-3
changing raedraw and raelib
Fri Apr 8 20:22:23 2005 UTC (14 years, 11 months ago) by redwards
changed tag/value pairs completely. Ooops!
Thu Apr 7 19:16:10 2005 UTC (14 years, 11 months ago) by redwards
Changes since 1.6: +30 -30 lines
many changes to key/value pairs to make them work
Fri Feb 4 06:59:46 2005 UTC (15 years, 1 month ago) by redwards
Changes since 1.5: +65 -9 lines
more changes to genomebrowser.cgi to make it work really well
Fri Feb 4 00:38:17 2005 UTC (15 years, 1 month ago) by redwards
Changes since 1.4: +4 -4 lines
More changes to raedraw/genomebrowser.cgi to get tag/vals working properly. They do now.
Thu Feb 3 20:43:02 2005 UTC (15 years, 1 month ago) by redwards
Changes since 1.3: +5 -5 lines
Minor changes to raedraw to make it work
Thu Feb 3 19:36:47 2005 UTC (15 years, 1 month ago) by redwards
Changes since 1.2: +108 -20 lines
Added support for tag/value pairs to genomebrowser.cgi/raedraw.cgi
Wed Feb 2 22:08:56 2005 UTC (15 years, 1 month ago) by redwards
Changes since 1.1: +11 -5 lines
Minor corrections to SVG genome browser
Wed Feb 2 21:01:07 2005 UTC (15 years, 1 month ago) by redwards
raedraw.pm contains a bunch of methods I am adding for SVG support and for creating a genome browser.
SVG is experimental and I want to isolate this in a large way from GenoGraphics and other functionality.
