[Bio] / FigKernelPackages / proml.pm Repository:
Log of /FigKernelPackages/proml.pm
Tue Jan 19 01:55:51 2010 UTC (10 years, 4 months ago) by golsen
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928
Changes since 1.8: +91 -34 lines
Minor updates to SEED awareness.
Sun Feb 11 18:35:46 2007 UTC (13 years, 3 months ago) by golsen
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_release_2008_09_29
Changes since 1.7: +11 -9 lines
A few updates to proml.pm, but this should be replaced by gjophylip.pm
function calls anyway.
Wed Jan 31 22:38:39 2007 UTC (13 years, 4 months ago) by golsen
Changes since 1.6: +8 -5 lines
Bug fixes and minor modifications.
Wed Jan 31 01:06:51 2007 UTC (13 years, 4 months ago) by golsen
Changes since 1.5: +16 -15 lines
Updates to the proml package.  Mostly cosmetic.
Mon Jan 29 18:14:50 2007 UTC (13 years, 4 months ago) by golsen
Changes since 1.4: +57 -42 lines
Moving some tree building tools into packages.
Sat Jan 13 17:15:28 2007 UTC (13 years, 4 months ago) by overbeek
Changes since 1.3: +1 -4 lines
minor fix to scaling in proml.pm
Sat Jan 13 03:49:35 2007 UTC (13 years, 4 months ago) by overbeek
weights and rates stuff
Sat Jan 13 03:22:44 2007 UTC (13 years, 4 months ago) by overbeek
add rates to phylogeny stuff
Fri Jan 12 23:45:29 2007 UTC (13 years, 4 months ago) by overbeek
Diff to selected 1.3
new versions of gjo packages
