[Bio] / FigKernelPackages / model.pm Repository:
Log of /FigKernelPackages/model.pm
Tue Dec 21 19:32:09 2010 UTC (9 years, 3 months ago) by dejongh
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.35: +9 -21 lines
Diff to previous 1.35
change scenario handling to use path_info.txt
Thu Jun 17 21:09:54 2010 UTC (9 years, 9 months ago) by olson
CVS Tags: rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206
Changes since 1.34: +12 -10 lines
Diff to previous 1.34
make it not a fatal error to not load hope_supersets; this was causing a crash on PSEED.
Fri Jan 22 17:38:16 2010 UTC (10 years, 2 months ago) by dejongh
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526
Diff to previous 1.33
fix reference
Mon Nov 16 17:56:21 2009 UTC (10 years, 4 months ago) by dejongh
Changes since 1.32: +202 -116 lines
Diff to previous 1.32
Lots of changes
Thu Apr 2 01:19:02 2009 UTC (11 years ago) by parrello
CVS Tags: rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925
Changes since 1.31: +9 -8 lines
Diff to previous 1.31
Fixed a bunch of compiler warnings.
Mon Feb 23 10:28:43 2009 UTC (11 years, 1 month ago) by dejongh
CVS Tags: rast_rel_2009_03_26
Changes since 1.30: +8 -28 lines
Diff to previous 1.30
Deleted checking for pegs in subsystem cells; only using seq_with_roles so it won't matter if a genome is active in a subsystem, or up to date in the subsystem
Fri Dec 12 23:43:13 2008 UTC (11 years, 3 months ago) by dejongh
CVS Tags: rast_rel_2008_12_18, rast_rel_2009_02_05
Changes since 1.29: +1 -3 lines
Diff to previous 1.29
debug msg
Thu Dec 11 17:01:39 2008 UTC (11 years, 3 months ago) by dejongh
Diff to previous 1.28
fix
Thu Dec 11 16:54:24 2008 UTC (11 years, 3 months ago) by dejongh
Changes since 1.27: +54 -0 lines
Diff to previous 1.27
check_hope_info process added
Wed Dec 3 14:28:04 2008 UTC (11 years, 3 months ago) by dejongh
Changes since 1.26: +9 -17 lines
Diff to previous 1.26
use seqs_with_roles instead of seqs_with_roles_in_genomes, for FIGV compatibility
Thu Nov 20 16:28:42 2008 UTC (11 years, 4 months ago) by dejongh
CVS Tags: rast_rel_2008_11_24
Changes since 1.25: +3 -18 lines
Diff to previous 1.25
copy path files instead of linking to them
Mon Nov 17 18:31:54 2008 UTC (11 years, 4 months ago) by dejongh
Changes since 1.24: +1 -0 lines
Diff to previous 1.24
added debug stmt
Thu Nov 13 21:54:41 2008 UTC (11 years, 4 months ago) by dejongh
Changes since 1.23: +53 -17 lines
Diff to previous 1.23
Move get_hope_reactions_for_genome to model.pm
Wed Nov 12 18:19:12 2008 UTC (11 years, 4 months ago) by dejongh
Changes since 1.22: +28 -29 lines
Diff to previous 1.22
switch to scenario_directory
Wed Nov 5 15:25:06 2008 UTC (11 years, 4 months ago) by dejongh
CVS Tags: mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2
Changes since 1.21: +0 -6 lines
Diff to previous 1.21
assume supersets are loaded
Wed Nov 5 15:24:12 2008 UTC (11 years, 4 months ago) by dejongh
Changes since 1.20: +409 -1 lines
Diff to previous 1.20
Add network analysis
Mon Nov 3 18:38:44 2008 UTC (11 years, 4 months ago) by dejongh
Changes since 1.19: +47 -35 lines
Diff to previous 1.19
Changes to move the 'All' scenarios directory to FIG_Config::global/Models/All
Wed Oct 15 21:21:33 2008 UTC (11 years, 5 months ago) by dejongh
CVS Tags: rast_rel_2008_10_29
Changes since 1.18: +68 -17 lines
Diff to previous 1.18
Support for model curation tools
Mon Mar 31 19:17:09 2008 UTC (12 years ago) by dejongh
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_release_2008_09_29
Changes since 1.17: +15 -12 lines
Diff to previous 1.17
Fixes for excluding . and .. when reading directories for paths
Fri Nov 2 19:12:58 2007 UTC (12 years, 5 months ago) by dejongh
Changes since 1.16: +103 -53 lines
Diff to previous 1.16
Hope College updates
Mon Jul 23 15:07:25 2007 UTC (12 years, 8 months ago) by formsma
Updated some error statments for better information - Kevin
Fri Jul 20 18:15:53 2007 UTC (12 years, 8 months ago) by formsma
Changes since 1.14: +2 -1 lines
Commented out a line which was causing the model's analysis directory to be deleted. This line was causing the data
from run_model_generation to be wiped out, and it doesn't need to remove the folder there - Kevin
Tue Jul 17 15:58:27 2007 UTC (12 years, 8 months ago) by formsma
Changes since 1.13: +77 -0 lines
Added predict_pegs_used function which will predict what pegs are going to be used by scenarios for a given genome - Kevin
Wed May 30 16:10:24 2007 UTC (12 years, 10 months ago) by olson
Changes since 1.12: +28 -15 lines
update to use $fig->model_directory(); change find opts based on mac vs linux.
Wed May 30 14:18:03 2007 UTC (12 years, 10 months ago) by dejongh
Changes since 1.11: +41 -38 lines
Changed model.pm to store scenarios under a subdirectory named Scenarios, and analysis under a subdirectory named Analysis
Tue May 29 19:37:12 2007 UTC (12 years, 10 months ago) by olson
Changes since 1.10: +21 -2 lines
add FIGV support.
Tue May 29 19:16:26 2007 UTC (12 years, 10 months ago) by olson
Changes since 1.9: +39 -36 lines
Changes for using $fig->scenario_directory() instead of constructed paths.
Wed May 23 22:21:47 2007 UTC (12 years, 10 months ago) by dejongh
Added analysis of scenario connections
Wed May 23 22:06:46 2007 UTC (12 years, 10 months ago) by dejongh
Changes since 1.7: +59 -29 lines
Tue May 22 18:16:57 2007 UTC (12 years, 10 months ago) by dejongh
Changes since 1.6: +2 -2 lines
get_hope_reactions_for_genome now returns a hash of reactions to pegs
Mon May 21 21:46:47 2007 UTC (12 years, 10 months ago) by dejongh
Changes since 1.5: +11 -2 lines
compare_scenario now creates soft links to paths with the same name as the path in the All directory
Mon May 21 20:23:27 2007 UTC (12 years, 10 months ago) by dejongh
Changes since 1.4: +6 -0 lines
compare_scenario now creates placeholder directories for paths with the same name as the path in the All directory
Fri May 18 16:57:26 2007 UTC (12 years, 10 months ago) by dejongh
Changes since 1.3: +18 -37 lines
Added get_hope_reactions_for_genome
Thu May 17 16:51:43 2007 UTC (12 years, 10 months ago) by olson
fix couple of missed temp replacements
Thu May 17 16:46:24 2007 UTC (12 years, 10 months ago) by olson
Changes since 1.1: +173 -10 lines
Changes to hope model stuff
Tue May 15 21:14:31 2007 UTC (12 years, 10 months ago) by olson
New file for Hope reaction stuff.
