[Bio] / FigKernelPackages / gjostat.pm Repository:
Log of /FigKernelPackages/gjostat.pm
Sun Aug 15 20:14:59 2010 UTC (9 years, 9 months ago) by golsen
CVS Tags: rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206
Changes since 1.1: +55 -54 lines
Integrate the function descriptions into a string returned by the function
gjostat::usage().
Mon Jan 18 19:52:18 2010 UTC (10 years, 4 months ago) by golsen
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526
Adding a library of useful statistical functions.
