[Bio] / FigKernelPackages / gjostat.pm Repository:
Log of /FigKernelPackages/gjostat.pm
Mon Dec 6 20:40:24 2010 UTC (9 years, 6 months ago) by golsen
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2011_0119, rast_rel_2011_0928
Changes since 1.2: +57 -56 lines
Convert die to confess.
Sun Aug 15 20:14:59 2010 UTC (9 years, 9 months ago) by golsen
CVS Tags: rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206
Changes since 1.1: +55 -54 lines
Integrate the function descriptions into a string returned by the function
gjostat::usage().
Mon Jan 18 19:52:18 2010 UTC (10 years, 4 months ago) by golsen
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526
Adding a library of useful statistical functions.
