[Bio] / FigKernelPackages / gjoseqlib.pm Repository:
Log of /FigKernelPackages/gjoseqlib.pm
Links to rast_rel_2008_10_09: (view) (download) (as text) (annotate)
Tue Feb 12 20:08:01 2008 UTC (11 years, 11 months ago) by golsen
Diff to previous 1.12 , to selected 1.11
Fixed major error in read_fasta() when there is not definition.
Mon Feb 11 20:37:27 2008 UTC (11 years, 11 months ago) by golsen
Changes since 1.11: +167 -49 lines
Fix a bug in translation with user-supplied genetic code (thank you Gordon).
Fix a bug in read_next_fasta_seq() that failed when the fasta header line
had an id, a space, and then no description.
Improve flexibility of read_next_fasta_seq() so that it will take a file
name, a file handle, or default to STDIN.
Double the speed of read_fasta by reading the whole file, then splitting
it into the structures.
Revision 1.11 - (view) (download) (as text) (annotate) - [selected]
Thu Jan 3 21:36:41 2008 UTC (12 years ago) by golsen
Changes since 1.10: +169 -0 lines
Add routines for calculating the fractional sequence difference in a
nucleotide alignment.  They sould be much faster than a loop over
pairs of positions, and allow separate weighting of gap openning and
gap extension, and of terminal versus interal gaps.
Fri Nov 23 00:33:31 2007 UTC (12 years, 2 months ago) by golsen
Changes since 1.9: +208 -215 lines
Diff to previous 1.9 , to selected 1.11
Add support for pyrrolysyl proteins.  Also, major revision and clean-up
of the translation utilities in gjoseqlib.pm.
Thu Nov 1 20:07:42 2007 UTC (12 years, 2 months ago) by golsen
Changes since 1.8: +72 -6 lines
Diff to previous 1.8 , to selected 1.11
Add new subsequence subroutines.
Tue Jun 26 15:20:16 2007 UTC (12 years, 7 months ago) by overbeek
Diff to previous 1.7 , to selected 1.11
minor fixes
Sun Jun 10 17:34:54 2007 UTC (12 years, 7 months ago) by golsen
Changes since 1.6: +96 -3 lines
Diff to previous 1.6 , to selected 1.11
Remove dependency on gjolib.pm
Add function to read a sequencing quality score file.
Sun Jun 10 17:24:38 2007 UTC (12 years, 7 months ago) by golsen
Changes since 1.5: +8 -2 lines
Diff to previous 1.5 , to selected 1.11
Add just a little more usage information for pack_alignment()
Sun Jun 10 17:17:40 2007 UTC (12 years, 7 months ago) by golsen
Changes since 1.4: +39 -0 lines
Diff to previous 1.4 , to selected 1.11
Add a pack_alignment function.
Fri Dec 15 00:09:52 2006 UTC (13 years, 1 month ago) by overbeek
Changes since 1.3: +597 -227 lines
Diff to previous 1.3 , to selected 1.11
add ability to insert sequences into a tree
Diff to previous 1.2 , to selected 1.11
Added license words.
Wed Nov 30 18:33:41 2005 UTC (14 years, 1 month ago) by golsen
Changes since 1.1: +476 -90 lines
Diff to previous 1.1 , to selected 1.11
This package is not currently used by any scripts, but I anticipate doing
so.  I had not been keeping the FIG version up-to-date relative to my
own.
Mon Dec 1 16:54:26 2003 UTC (16 years, 1 month ago) by efrank
Branch point for: initial
Diff to selected 1.11
