[Bio] / FigKernelPackages / gjoseqlib.pm Repository:
Log of /FigKernelPackages/gjoseqlib.pm
Sat Feb 5 21:23:20 2011 UTC (9 years, 2 months ago) by golsen
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, myrast_33, myrast_rel40, rast_rel_2011_0928
Changes since 1.24: +14 -14 lines
Diff to previous 1.24
Just some additions to the function descriptions.
Sun Jan 2 18:57:43 2011 UTC (9 years, 3 months ago) by golsen
CVS Tags: rast_rel_2011_0119
Changes since 1.23: +7 -5 lines
Diff to previous 1.23
Some minor changes to translation with user codes (saving the ambiguous
codon translations that are encountered).
Fri Sep 17 20:23:35 2010 UTC (9 years, 6 months ago) by overbeek
CVS Tags: rast_rel_2010_0928, rast_rel_2010_1206
Changes since 1.22: +0 -1 lines
Diff to previous 1.22
get rid of Dumper
Fri Sep 17 20:18:15 2010 UTC (9 years, 6 months ago) by golsen
Changes since 1.21: +5 -6 lines
Diff to previous 1.21
Bug fixes in oligomer_similarity().
Fri Sep 17 20:04:05 2010 UTC (9 years, 6 months ago) by golsen
Changes since 1.20: +62 -0 lines
Diff to previous 1.20
Add code for similarity at any arbitary oligo size.
Sun Aug 29 22:13:28 2010 UTC (9 years, 7 months ago) by golsen
Changes since 1.19: +200 -20 lines
Diff to previous 1.19
Much code clean-up and consolidation.
New version of add to alignment that does much better gap placement.
Sat Aug 21 17:29:14 2010 UTC (9 years, 7 months ago) by golsen
CVS Tags: rast_rel_2010_0827
Changes since 1.18: +30 -2 lines
Diff to previous 1.18
Add a pack sequences function, and allow * in a packed sequence (stop).
Sun Aug 15 23:51:00 2010 UTC (9 years, 7 months ago) by golsen
Changes since 1.17: +32 -20 lines
Diff to previous 1.17
Minor style updates.
Add the ability of read_fasta() to interpret a reference to a sting as
a fasta format string.
use gjoseqlib; $s=join("",<>); @seq=read_fasta(\$s); print_alignment_as_fasta(\@seq);
will echo sequences from stdin.
Mon Jan 18 20:01:14 2010 UTC (10 years, 2 months ago) by golsen
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526
Changes since 1.16: +72 -2 lines
Diff to previous 1.16
Add new function for assessing similarity of aligned sequences.
Fix a bug in print fasta when sequence function is undefined under -w.
Tue Nov 24 21:22:46 2009 UTC (10 years, 4 months ago) by olson
Changes since 1.15: +2 -0 lines
Add more modules to the SAS toolkit.
Mon Apr 13 18:42:53 2009 UTC (10 years, 11 months ago) by golsen
CVS Tags: rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925
Changes since 1.14: +51 -6 lines
Improve the comments and descriptions of functions.
Thu Feb 5 14:50:43 2009 UTC (11 years, 2 months ago) by overbeek
CVS Tags: rast_rel_2009_03_26
Changes since 1.13: +10 -17 lines
fixes to support search for rRNAs
Tue Feb 12 20:08:01 2008 UTC (12 years, 1 month ago) by golsen
Fixed major error in read_fasta() when there is not definition.
Mon Feb 11 20:37:27 2008 UTC (12 years, 1 month ago) by golsen
Changes since 1.11: +167 -49 lines
Fix a bug in translation with user-supplied genetic code (thank you Gordon).
Fix a bug in read_next_fasta_seq() that failed when the fasta header line
had an id, a space, and then no description.
Improve flexibility of read_next_fasta_seq() so that it will take a file
name, a file handle, or default to STDIN.
Double the speed of read_fasta by reading the whole file, then splitting
it into the structures.
Thu Jan 3 21:36:41 2008 UTC (12 years, 3 months ago) by golsen
Changes since 1.10: +169 -0 lines
Add routines for calculating the fractional sequence difference in a
nucleotide alignment.  They sould be much faster than a loop over
pairs of positions, and allow separate weighting of gap openning and
gap extension, and of terminal versus interal gaps.
Fri Nov 23 00:33:31 2007 UTC (12 years, 4 months ago) by golsen
Changes since 1.9: +208 -215 lines
Add support for pyrrolysyl proteins.  Also, major revision and clean-up
of the translation utilities in gjoseqlib.pm.
Thu Nov 1 20:07:42 2007 UTC (12 years, 5 months ago) by golsen
Changes since 1.8: +72 -6 lines
Add new subsequence subroutines.
Tue Jun 26 15:20:16 2007 UTC (12 years, 9 months ago) by overbeek
minor fixes
Sun Jun 10 17:34:54 2007 UTC (12 years, 9 months ago) by golsen
Changes since 1.6: +96 -3 lines
Remove dependency on gjolib.pm
Add function to read a sequencing quality score file.
Sun Jun 10 17:24:38 2007 UTC (12 years, 9 months ago) by golsen
Changes since 1.5: +8 -2 lines
Add just a little more usage information for pack_alignment()
Sun Jun 10 17:17:40 2007 UTC (12 years, 9 months ago) by golsen
Changes since 1.4: +39 -0 lines
Add a pack_alignment function.
Fri Dec 15 00:09:52 2006 UTC (13 years, 3 months ago) by overbeek
Changes since 1.3: +597 -227 lines
add ability to insert sequences into a tree
Mon Dec 5 19:06:30 2005 UTC (14 years, 4 months ago) by olson
Added license words.
Wed Nov 30 18:33:41 2005 UTC (14 years, 4 months ago) by golsen
Changes since 1.1: +476 -90 lines
This package is not currently used by any scripts, but I anticipate doing
so.  I had not been keeping the FIG version up-to-date relative to my
own.
Mon Dec 1 16:54:26 2003 UTC (16 years, 4 months ago) by efrank
Branch point for: initial
