[Bio] / FigKernelPackages / gjoseqlib.pm Repository:
View of /FigKernelPackages/gjoseqlib.pm
Revision 1.43 - (download) (as text) (annotate)
Thu Jun 16 22:10:42 2016 UTC (3 years, 9 months ago) by golsen
Changes since 1.42: +55 -9 lines
A varienty of enhancements, including more intuitive access to next_fasta().
A bug fix in next_fasta, making $_ local.
package gjoseqlib;
# This is a SAS component.
=head1 Sequence-IO Utilities
A sequence entry is ( $id, $def, $seq )
A list of entries is a list of references
Efficient reading of an entire file of sequences:
  @seq_entries = read_fasta( )                     # STDIN
  @seq_entries = read_fasta( \*FILEHANDLE )
  @seq_entries = read_fasta(  $filename )
Legacy interface:
  @seq_entries = read_fasta_seqs( \*FILEHANDLE )   # Original form
Reading sequences one at a time to conserve memory.  Calls to different
files can be intermixed.
  @entry = read_next_fasta( \*FILEHANDLE )
 \@entry = read_next_fasta( \*FILEHANDLE )
  @entry = read_next_fasta(  $filename )
 \@entry = read_next_fasta(  $filename )
  @entry = read_next_fasta()                   # STDIN
 \@entry = read_next_fasta()                   # STDIN
Close an open file that has not been read to the end:
  close_fasta(  $filename )
Legacy interface:
  @entry = read_next_fasta_seq( \*FILEHANDLE )
 \@entry = read_next_fasta_seq( \*FILEHANDLE )
  @entry = read_next_fasta_seq(  $filename )
 \@entry = read_next_fasta_seq(  $filename )
  @entry = read_next_fasta_seq()                   # STDIN
 \@entry = read_next_fasta_seq()                   # STDIN
Reading clustal alignment.
  @seq_entries = read_clustal( )                   # STDIN
  @seq_entries = read_clustal( \*FILEHANDLE )
  @seq_entries = read_clustal(  $filename )
Legacy interface:
  @seq_entries = read_clustal_file(  $filename )
  $seq_ind   = index_seq_list( @seq_entries );   # hash from ids to entries
  @seq_entry = seq_entry_by_id( \%seq_index, $seq_id );
  $seq_desc  = seq_desc_by_id(  \%seq_index, $seq_id );
  $seq       = seq_data_by_id(  \%seq_index, $seq_id );
  ( $id, $def ) = parse_fasta_title( $title )
  ( $id, $def ) = split_fasta_title( $title )
  @id_def_org   = nr_def_as_id_def_org( $nr_seq_title )
  @id_def_org   = split_id_def_org( @seq_titles );
Write a fasta format file from sequences.
  write_fasta(                @seq_entry_list ); # STDOUT
  write_fasta(               \@seq_entry_list ); # STDOUT
  write_fasta( \*FILEHANDLE,  @seq_entry_list );
  write_fasta( \*FILEHANDLE, \@seq_entry_list );
  write_fasta(  $filename,    @seq_entry_list );
  write_fasta(  $filename,   \@seq_entry_list );
  print_alignment_as_fasta(                @seq_entry_list ); # STDOUT
  print_alignment_as_fasta(               \@seq_entry_list ); # STDOUT
  print_alignment_as_fasta( \*FILEHANDLE,  @seq_entry_list );
  print_alignment_as_fasta( \*FILEHANDLE, \@seq_entry_list );
  print_alignment_as_fasta(  $filename,    @seq_entry_list );
  print_alignment_as_fasta(  $filename,   \@seq_entry_list );
Legacy interface:
  print_seq_list_as_fasta( \*FILEHANDLE, @seq_entry_list );  # Original form
Interface that it really meant for internal use to write the next sequence
to an open file:
  print_seq_as_fasta( \*FILEHANDLE, $id, $desc, $seq );
  print_seq_as_fasta(               $id, $desc, $seq );
  print_seq_as_fasta( \*FILEHANDLE, $id,        $seq );
  print_seq_as_fasta(               $id,        $seq );
Write PHYLIP alignment.  Names might be altered to fit 10 character limit:
  print_alignment_as_phylip(                @seq_entry_list ); # STDOUT
  print_alignment_as_phylip(               \@seq_entry_list ); # STDOUT
  print_alignment_as_phylip( \*FILEHANDLE,  @seq_entry_list );
  print_alignment_as_phylip( \*FILEHANDLE, \@seq_entry_list );
  print_alignment_as_phylip(  $filename,    @seq_entry_list );
  print_alignment_as_phylip(  $filename,   \@seq_entry_list );
Write basic NEXUS alignment for PAUP.
  print_alignment_as_nexus(               [ \%label_hash, ]  @seq_entry_list );
  print_alignment_as_nexus(               [ \%label_hash, ] \@seq_entry_list );
  print_alignment_as_nexus( \*FILEHANDLE, [ \%label_hash, ]  @seq_entry_list );
  print_alignment_as_nexus( \*FILEHANDLE, [ \%label_hash, ] \@seq_entry_list );
  print_alignment_as_nexus(  $filename,   [ \%label_hash, ]  @seq_entry_list );
  print_alignment_as_nexus(  $filename,   [ \%label_hash, ] \@seq_entry_list );
  print_gb_locus( \*FILEHANDLE, $locus, $def, $accession, $seq );
Remove extra columns of alignment gaps from an alignment:
   @packed_seqs = pack_alignment(  @seqs )
   @packed_seqs = pack_alignment( \@seqs )
  \@packed_seqs = pack_alignment(  @seqs )
  \@packed_seqs = pack_alignment( \@seqs )
Pack mask for an alignment (gap = 0x00, others are 0xFF)
   $mask = alignment_gap_mask(  @seqs )
   $mask = alignment_gap_mask( \@seqs )
Pack a sequence alignment according to a mask:
   @packed = pack_alignment_by_mask( $mask,  @align )
   @packed = pack_alignment_by_mask( $mask, \@align )
  \@packed = pack_alignment_by_mask( $mask,  @align )
  \@packed = pack_alignment_by_mask( $mask, \@align )
Expand sequence by a mask, adding indel at "\000" or '-' in mask:
   $expanded = expand_sequence_by_mask( $seq, $mask )
Remove all alignment gaps from sequences (modify a copy):
   @packed_seqs = pack_sequences(  @seqs )  #  Works for one sequence, too
   @packed_seqs = pack_sequences( \@seqs )
  \@packed_seqs = pack_sequences(  @seqs )
  \@packed_seqs = pack_sequences( \@seqs )
Basic sequence manipulation functions:
  @entry  = subseq_DNA_entry( @seq_entry, $from, $to [, $fix_id] )
  @entry  = subseq_RNA_entry( @seq_entry, $from, $to [, $fix_id] )
  $DNAseq = DNA_subseq(  $seq, $from, $to )
  $DNAseq = DNA_subseq( \$seq, $from, $to )
  $RNAseq = RNA_subseq(  $seq, $from, $to )
  $RNAseq = RNA_subseq( \$seq, $from, $to )
  @entry  = complement_DNA_entry( @seq_entry [, $fix_id] )
  @entry  = complement_RNA_entry( @seq_entry [, $fix_id] )
  $DNAseq = complement_DNA_seq( $NA_seq )
  $RNAseq = complement_RNA_seq( $NA_seq )
  $DNAseq = to_DNA_seq( $NA_seq )
  $RNAseq = to_RNA_seq( $NA_seq )
  $seq    = pack_seq( $sequence )        # modifies a copy
  $seq    = clean_ae_sequence( $seq )
  $aa_seq = aa_subseq( $seq, $from, $to )
  $aa = translate_seq( $nt, $met_start )
  $aa = translate_seq( $nt )
  $aa = translate_codon( $triplet );
User-supplied genetic code.  The supplied code needs to be complete in
RNA and/or DNA, and upper and/or lower case.  The program guesses based
on lysine and phenylalanine codons.
  $aa = translate_seq_with_user_code( $nt, $gen_code_hash, $met_start )
  $aa = translate_seq_with_user_code( $nt, $gen_code_hash )
Locations (= oriented intervals) are ( id, start, end ).
Intervals are ( id, left, right ).
  @intervals = read_intervals( \*FILEHANDLE )
  @intervals = read_oriented_intervals( \*FILEHANDLE )
  @intervals = standardize_intervals( @interval_refs ) # (id, left, right)
  @joined    = join_intervals( @interval_refs )
  @intervals = locations_2_intervals( @locations )
  $interval  = locations_2_intervals( $location  )
  @reversed  = reverse_intervals( @interval_refs )      # (id, end, start)
Convert GenBank locations to SEED locations
  @seed_locs = gb_location_2_seed( $contig, @gb_locs )
Read quality scores from a fasta-like file:
  @seq_entries = read_qual( )               #  STDIN
 \@seq_entries = read_qual( )               #  STDIN
  @seq_entries = read_qual( \*FILEHANDLE )
 \@seq_entries = read_qual( \*FILEHANDLE )
  @seq_entries = read_qual(  $filename )
 \@seq_entries = read_qual(  $filename )
Evaluate alignments:
  $fraction_diff = fraction_nt_diff( $seq1, $seq2, \%options )
  $fraction_diff = fraction_nt_diff( $seq1, $seq2 )
  $fraction_diff = fraction_nt_diff( $seq1, $seq2, $gap_weight )
  $fraction_diff = fraction_nt_diff( $seq1, $seq2, $gap_open, $gap_extend )
  ( $npos, $nid, $ndif, $ngap, $nopen, $tgap, $topen ) = interpret_nt_align( $seq1, $seq2 )
  ( $npos, $nid, $ndif, $ngap, $nopen, $tgap, $topen ) = interpret_aa_align( $seq1, $seq2 )
  @sims = oligomer_similarity( $seq1, $seq2, \%opts )
Guess type of a sequence:
  $type = guess_seq_type( $sequence )
  $bool = is_dna( $sequence )   # not RNA or prot
  $bool = is_rna( $sequence )   # not DNA or prot
  $bool = is_na( $sequence )    # nucleic acid, not prot
  $bool = is_prot( $sequence )  # not DNA or RNA
$sequence can be a sequence string, a reference to a sequence string,
or a [$id, $def, $seq] triple.
$type will be keyword 'DNA', 'RNA' or 'protein', or undef in case of error.
Verify the structure of an [ id, desc, sequence ] triple and
the structure of an array of sequence triples:
  $bool = is_sequence_triple( $triple )
  $bool = is_array_of_sequence_triples( \@triples )
=cut
use strict;
use Carp;
use Data::Dumper;
#  Exported global variables:
our @aa_1_letter_order;  # Alpha by 1 letter
our @aa_3_letter_order;  # PAM matrix order
our @aa_n_codon_order;
our %genetic_code;
our %genetic_code_with_U;
our %amino_acid_codons_DNA;
our %amino_acid_codons_RNA;
our %n_codon_for_aa;
our %reverse_genetic_code_DNA;
our %reverse_genetic_code_RNA;
our %DNA_letter_can_be;
our %RNA_letter_can_be;
our %one_letter_to_three_letter_aa;
our %three_letter_to_one_letter_aa;
require Exporter;
our @ISA = qw(Exporter);
our @EXPORT = qw(
        read_fasta
        read_next_fasta
        close_fasta
        read_fasta_seqs
        read_next_fasta_seq
        read_clustal_file
        read_clustal
        parse_fasta_title
        split_fasta_title
        split_id_def_org
        write_fasta
        print_seq_as_fasta
        print_gb_locus
        index_seq_list
        seq_entry_by_id
        seq_desc_by_id
        seq_data_by_id
        pack_alignment
        alignment_gap_mask
        pack_sequences
        subseq_DNA_entry
        subseq_RNA_entry
        DNA_subseq
        RNA_subseq
        complement_DNA_seq
        complement_RNA_seq
        to_DNA_seq
        to_RNA_seq
        pack_seq
        clean_ae_sequence
        aa_subseq
        translate_seq
        translate_codon
        read_intervals
        join_intervals
        reverse_intervals
        gb_location_2_seed
        read_qual
        fraction_nt_diff
        interpret_nt_align
        interpret_aa_align
        oligomer_similarity
our @EXPORT_OK = qw(
        @aa_1_letter_order
        @aa_3_letter_order
        @aa_n_codon_order
        %genetic_code
        %n_codon_for_aa
        %DNA_letter_can_be
        %RNA_letter_can_be
=head2 input_file_handle
Helper function for defining an input filehandle:
=over 4
=item 1
filehandle is passed through
=item 2
string is taken as file name to be openend
=item 3
undef or "" defaults to STDOUT
=back
    ( \*FH, $name, $close [, $file] ) = input_filehandle( $file );
=cut
sub input_filehandle
    my $file = shift;
    #  FILEHANDLE
    return ( $file, $file, 0 ) if ( ref( $file ) eq "GLOB" );
    #  Null string or undef
    return ( \*STDIN, "", 0 ) if ( ! defined( $file ) || ( $file eq "" ) );
    #  File name
    if ( ! ref( $file ) )
        my $fh;
        if    ( -f $file                       ) { }
        elsif (    $file =~ /^<(.+)$/ && -f $1 ) { $file = $1 }
        else { die "Could not find input file '$file'\n" }
        open( $fh, '<', $file ) || die "Could not open '$file' for input\n";
        return ( $fh, $file, 1 );
    #  Some other kind of reference; return the unused value
    return ( \*STDIN, undef, 0, $file );
=head2 read_fasta_seqs
Read fasta sequences from a filehandle (legacy interface; use read_fasta)
Save the contents in a list of refs to arrays:  (id, description, seq)
=cut
sub read_fasta_seqs { read_fasta( @_ ) }
=head2 read_fasta
Read fasta sequences.  Save the contents in a list of refs to arrays:
     $seq_entry = [ id, description, seq ]
    \@seq_entries = read_fasta( )               #  STDIN
    \@seq_entries = read_fasta( \*FILEHANDLE )
    \@seq_entries = read_fasta(  $filename )
     @seq_entries = read_fasta( \$string )      #  reference to file as string
    \@seq_entries = read_fasta( \$string )      #  reference to file as string
=cut
sub read_fasta
    my $dataR = ( $_[0] && ref $_[0] eq 'SCALAR' ) ?  $_[0] : slurp( @_ );
    $dataR && $$dataR or return wantarray ? () : [];
    my $is_fasta = $$dataR =~ m/^[\s\r]*>/;
    my @seqs = map { $_->[2] =~ tr/ \n\r\t//d; $_ }
               map { /^(\S+)([ \t]+([^\n\r]+)?)?[\n\r]+(.*)$/s ? [ $1, $3 || '', $4 || '' ] : () }
               split /[\n\r]+>[ \t]*/m, $$dataR;
    #  Fix the first sequence, if necessary
    if ( @seqs )
        if ( $is_fasta )
            $seqs[0]->[0] =~ s/^>//;  # remove > if present
        elsif ( @seqs == 1 )
            $seqs[0]->[1] =~ s/\s+//g;
            @{ $seqs[0] } = ( 'raw_seq', '', join( '', @{$seqs[0]} ) );
        else  #  First sequence is not fasta, but others are!  Throw it away.
            shift @seqs;
    wantarray ? @seqs : \@seqs;
=head2 slurp
A fast file reader:
     $dataR = slurp( )               #  \*STDIN
     $dataR = slurp( \*FILEHANDLE )  #  an open file handle
     $dataR = slurp(  $filename )    #  a file name
     $dataR = slurp( "<$filename" )  #  file with explicit direction
=head3 Note
It is faster to read lines by reading the file and splitting
than by reading the lines sequentially.  If space is not an
issue, this is the way to go.  If space is an issue, then lines
or records should be processed one-by-one (rather than loading
the whole input into a string or array).
=cut
sub slurp
    my ( $fh, $close );
    if ( $_[0] && ref $_[0] eq 'GLOB' )
        $fh = shift;
    elsif ( $_[0] && ! ref $_[0] )
        my $file = shift;
        if    ( -f $file                       ) { }
        elsif (    $file =~ /^<(.*)$/ && -f $1 ) { $file = $1 }  # Explicit read
        else                                     { return undef }
        open( $fh, '<', $file ) or return undef;
        $close = 1;
    else
        $fh = \*STDIN;
        $close = 0;
    my $out = '';
    my $inc = 1048576;
    my $end =       0;
    my $read;
    while ( $read = read( $fh, $out, $inc, $end ) ) { $end += $read }
    close( $fh ) if $close;
    \$out;
=head2 read_fasta_0
Previous, 50% slower fasta reader:
=cut
sub read_fasta_0
    my ( $fh, $name, $close, $unused ) = input_filehandle( $_[0] );
    $unused && die "Bad reference type (" . ref( $unused ) . ") passed to read_fasta\n";
    my @seqs = ();
    my ($id, $desc, $seq) = ("", "", "");
    while ( <$fh> ) {
        chomp;
        if (/^>\s*(\S+)(\s+(.*))?$/) {        #  new id
            if ($id && $seq) { push @seqs, [ $id, $desc, $seq ] }
            ($id, $desc, $seq) = ($1, $3 ? $3 : "", "");
        else {
            tr/     0-9//d;
            $seq .= $_ ;
    if ( $id && $seq ) { push @seqs, [ $id, $desc, $seq ] }
    return wantarray ? @seqs : \@seqs;
=head2 read_next_fasta
Read one fasta sequence at a time from a file.  This is half as fast a
read_fasta(), but can handle an arbitrarily large file.  State information
is retained in hashes, so any number of streams can be interlaced.
      @entry = read_next_fasta()                # \*STDIN
     \@entry = read_next_fasta()                # \*STDIN
Where,
      @entry = ( $id, $description, $seq )
Longer, legacy name:
      @entry = read_next_fasta_seq()                # \*STDIN
     \@entry = read_next_fasta_seq()                # \*STDIN
When reading at the end of file, () is returned.
With a filename, reading past this will reopen the file at the beginning.
Beware: openning a filename, and not reading it to the end leaves the file
open, which can hit the file system limit for open files.  So, use
=cut
#  Reading always overshoots, so save next id and description
{   #  Use bare block to scope the header hash
    my %next_header;
    my %file_handle;
    my %close_file;
    sub close_fasta
        $_[0] or return 0;
        my $fh = $file_handle{ $_[0] }
            or return 0;
        if ( $close_file{ $fh } ) { close $fh; delete $close_file{ $fh } }
        delete $file_handle{ $_[0] };
        1;
    sub read_next_fasta_seq { read_next_fasta( @_ ) }
    sub read_next_fasta
        $_[0] ||= \*STDIN;               #  Undefined $_[0] fails with use warn
        my $fh = $file_handle{ $_[0] };
        if ( ! $fh )
            if ( ref $_[0] )
                return () if ref $_[0] ne 'GLOB';
                $fh = $_[0];
            else
                my $file = $_[0];
                if    ( -f $file                       ) { }
                elsif (    $file =~ /^<(.+)$/ && -f $1 ) { $file = $1 }  # Explicit read
                else                                     { return () }
                open( $fh, '<', $file ) or return ();
                $close_file{ $fh } = 1;
            $file_handle{ $_[0] } = $fh;
        my ( $id, $desc, $seq ) = ( undef, '', '' );
        if ( defined( $next_header{$fh} ) )
            ( $id, $desc ) = parse_fasta_title( $next_header{$fh} );
        else
            $next_header{$fh} = '';
        local $_;
        while ( <$fh> )
            chomp;
            if ( /^>/ )        #  new id
                $next_header{$fh} = $_;
                if ( defined($id) && $seq )
                    return wantarray ? ($id, $desc, $seq) : [$id, $desc, $seq]
                $seq = '';
            else
                tr/ \t\r//d;
                $seq .= $_;
        #  Done with file; there is no next header:
        delete $next_header{ $fh };
        #  Return last set of data:
            return wantarray ? ($id,$desc,$seq) : [$id,$desc,$seq]
        #  Or close everything out (returning the empty list tells caller
        #  that we are done)
        return ();
=head2 read_clustal_file
Read a clustal alignment from a file.
=cut
sub read_clustal_file { read_clustal( @_ ) }
=head2 read_clustal
Read a clustal alignment.
=cut
sub read_clustal {
    my ( $fh, undef, $close, $unused ) = input_filehandle( shift );
    $unused && die "Bad reference type (" . ref( $unused ) . ") passed to read_clustal_file\n";
    my ( %seq, @ids, $line );
    while ( defined( $line = <$fh> ) )
        ( $line =~ /^[A-Za-z0-9]/ ) or next;
        chomp $line;
        my @flds = split /\s+/, $line;
        if ( @flds == 2 )
            $seq{ $flds[0] } or push @ids, $flds[0];
            push @{ $seq{ $flds[0] } }, $flds[1];
    map { [ $_, "", join( "", @{$seq{$_}} ) ] } @ids;
=head2 parse_fasta_title
Parse a fasta file header to id and definition parts
     ($id, $def) = parse_fasta_title( $title )
     ($id, $def) = split_fasta_title( $title )
=cut
sub parse_fasta_title
    my $title = shift;
    chomp $title;
    return $title =~ /^>?\s*(\S+)(\s+(.*\S)?\s*)?$/ ? ( $1, $3 || '' )
         : $title =~ /^>/                           ? ( '', '' )
         :                                            ( undef, undef )
sub split_fasta_title { parse_fasta_title( @_ ) }
=head2 nr_def_as_id_def_org
Some functions to split fasta file def lines into [id, definition, organism]
These forms DO NOT want a > at the beinging of the line (it will become part
of the id).
=cut
#  @id_def_org = nr_def_as_id_def_org( $nr_id_def_line );
sub nr_def_as_id_def_org
    defined($_[0]) ? split_id_def_org( split /\001/, $_[0] ) : ();
=head2 split_id_def_org
  @id_def_org = split_id_def_org( @id_def_org_lines );
=cut
sub split_id_def_org
    map { ! defined( $_ )                           ? ()
        : ! /^\s*\S/                                ? ()
        : /^\s*(\S+)\s+(.*\S)\s+\[([^\[\]]+)\]\s*$/ ? [ $1, $2, $3 ]  # id def org
        : /^\s*(\S+)\s+\[([^\[\]]+)\]\s*$/          ? [ $1, '', $2 ]  # id     org
        : /^\s*(\S+)\s+(.*[^\]\s])\s*$/             ? [ $1, $2, '' ]  # id def
        : /^\s*(\S+)\s*$/                           ? [ $1, '', '' ]  # id
        :                                             split_id_def_org_2( $_ );
        } @_;
#  @id_def_org = split_id_def_org( @id_def_org_lines );
sub split_id_def_org_2
    local $_ = $_[0];
    s/^\s+//;
    s/\s+$//;
    # split into segments starting with [ or ]
    my @parts = grep { defined($_) && length($_) } split /([\]\[][^\]\[]*)/;
    my $n = 0;
    for ( my $i = @parts-1; $i > 0; $i-- )
        # a part starts with [ or ].
        if    ( $parts[$i] =~ /^\[/ )
            $n--;
            #  If the open bracket balances, and there
            #  is white space before, we are done
            if ( $n == 0 && $parts[$i-1] =~ s/\s+$// )
                my $def = join( '', @parts[  0 .. $i-1 ] );
                $parts[$i]       =~ s/^\[\s*//;  # remove open bracket
                $parts[@parts-1] =~ s/\s*\]$//;  # remove close bracket
                my $org = join( '', @parts[ $i .. @parts-1 ] );
                return $def =~ /^(\S+)\s+(\S.*)$/ ? [ $1, $2, $org ] : [ $def, '', $org ];
        elsif ( $parts[$i] =~ /^\]/ )
            $n++;
        else
            carp "Logic error in split_id_def_org_2()";
            return m/^(\S+)\s+(\S.*)$/ ? [ $1, $2, '' ] : [ $_, '', '' ];
    #  Fall through means that we failed to balance organism brackets
=head2 output_filehandle
Helper function for defining an output filehandle:
=over 4
=item 1
=item 2
=item 3
=back
    ( \*FH, $close [, $file] ) = output_filehandle( $file );
=cut
sub output_filehandle
    my $file = shift;
    return ( \*STDOUT, 0 ) if ( ! defined( $file ) || ( $file eq "" ) );
    #  FILEHANDLE
    return ( $file, 0 ) if ( ref( $file ) eq "GLOB" );
    return ( \*STDOUT, 0, $file ) if ref( $file );
    #  File name
    my $fh;
    open( $fh, '>', $file ) || die "Could not open output $file\n";
    return ( $fh, 1 );
=head2 print_seq_list_as_fasta
Legacy function for printing fasta sequence set:
=cut
sub print_seq_list_as_fasta { print_alignment_as_fasta( @_ ) }
=head2 print_alignment_as_fasta
Print list of sequence entries in fasta format.
Missing, undef or "" filename defaults to STDOUT.
=cut
sub print_alignment_as_fasta
    return &write_fasta(@_);
=head2 write_fasta
=cut
sub write_fasta
    my ( $fh, $close, $unused ) = output_filehandle( shift );
    ( unshift @_, $unused ) if $unused;
    ( ref( $_[0] ) eq "ARRAY" ) or confess "Bad sequence entry passed to print_alignment_as_fasta\n";
    #  Expand the sequence entry list if necessary:
    if ( ref( $_[0]->[0] ) eq "ARRAY" ) { @_ = @{ $_[0] } }
    foreach my $seq_ptr ( @_ ) { print_seq_as_fasta( $fh, @$seq_ptr ) }
=print_alignment_as_phylip
Print list of sequence entries in phylip format.
=cut
sub print_alignment_as_phylip {
    ( ref( $_[0] ) eq "ARRAY" ) or die die "Bad sequence entry passed to print_alignment_as_phylip\n";
    my @seq_list = ( ref( $_[0]->[0] ) eq "ARRAY" ) ? @{ $_[0] } : @_;
    my ( %id2, %used );
    my $maxlen = 0;
    foreach ( @seq_list )
        my ( $id, undef, $seq ) = @$_;
        #  Need a name that is unique within 10 characters
        my $id2 = substr( $id, 0, 10 );
        $id2 =~ s/_/ /g;  # PHYLIP sequence files accept spaces
        my $n = "0";
        while ( $used{ $id2 } )
            $n++;
            $id2 = substr( $id, 0, 10 - length( $n ) ) . $n;
        $used{ $id2 } = 1;
        $id2{ $id } = $id2;
                #  Prepare to pad sequences (should not be necessary, but ...)
        my $len = length( $seq );
        $maxlen = $len if ( $len > $maxlen );
    my $nseq = @seq_list;
    print $fh "$nseq  $maxlen\n";
        printf $fh "%-10s  %s%s\n", $id2{ $id },
                                    $seq,
                                    $len<$maxlen ? ("?" x ($maxlen-$len)) : "";
=head2 print_alignment_as_nexus
Print list of sequence entries in nexus format.
=cut
sub print_alignment_as_nexus {
    my $lbls = ( ref( $_[0] ) eq "HASH" ) ? shift : undef;
    ( ref( $_[0] ) eq "ARRAY" ) or die "Bad sequence entry passed to print_alignment_as_nexus\n";
    my %id2;
    my ( $maxidlen, $maxseqlen ) = ( 0, 0 );
    my ( $n1, $n2, $nt, $nu ) = ( 0, 0, 0, 0 );
        my $id2 = $lbls ? ( $lbls->{ $id } || $id ) : $id;
        if ( $id2 !~ /^[-+.0-9A-Za-z~_|]+$/ )
                $id2 =~ s/'/''/g;
                $id2 = qq('$id2');
        $id2{ $id } = $id2;
        my $idlen = length( $id2 );
        $maxidlen = $idlen if ( $idlen > $maxidlen );
        my $seqlen = length( $seq );
        $maxseqlen = $seqlen if ( $seqlen > $maxseqlen );
        $nt += $seq =~ tr/Tt//d;
        $nu += $seq =~ tr/Uu//d;
        $n1 += $seq =~ tr/ACGNacgn//d;
        $n2 += $seq =~ tr/A-Za-z//d;
    my $type = ( $n1 < 2 * $n2 ) ?  'protein' : ($nt>$nu) ? 'DNA' : 'RNA';
    print $fh <<"END_HEAD";
#NEXUS
BEGIN Data;
    Dimensions
        NTax=$nseq
        NChar=$maxseqlen
    Format
        DataType=$type
        Gap=-
        Missing=?
    Matrix
END_HEAD
        printf  $fh  "%-${maxidlen}s  %s%s\n",
                     $id2{ $id },
                     $seq,
                     $len<$maxseqlen ? ("?" x ($maxseqlen-$len)) : "";
    print $fh <<"END_TAIL";
END;
END_TAIL
=head2 print_seq_as_fasta
Print one sequence in fasta format to an open file.
print_seq_as_fasta() is meant more as a internal support routine than an
external interface.  To print a single sequence to a named file use:
     print_alignment_as_fasta( $filename, [ $id, $desc, $seq ] );
     print_alignment_as_fasta( $filename, [ $id,        $seq ] );
=cut
sub print_seq_as_fasta
    my $fh = ( ref $_[0] eq 'GLOB' ) ? shift : \*STDOUT;
    return if ( @_ < 2 ) || ( @_ > 3 ) || ! ( defined $_[0] && defined $_[-1] );
    #  Print header line
    print $fh  ( @_ == 3 && defined $_[1] && $_[1] =~ /\S/ ) ? ">$_[0] $_[1]\n" : ">$_[0]\n";
    #  Print sequence, 60 chars per line
    print $fh  join( "\n", $_[-1] =~ m/.{1,60}/g ), "\n";
=head2 print_gb_locus
Print one sequence in GenBank flat file format:
=cut
sub print_gb_locus {
    my ($fh, $loc, $def, $acc, $seq) = @_;
    my ($len, $i, $imax);
    my $istep = 10;
    $len = length($seq);
    printf $fh  "LOCUS       %-10s%7d bp\n", substr($loc,0,10), $len;
    print  $fh  "DEFINITION  " . substr(wrap_text($def,80,12), 12) . "\n";
    if ($acc) { print  $fh  "ACCESSION   $acc\n" }
    print  $fh "ORIGIN\n";
    for ($i = 1; $i <= $len; ) {
        printf $fh "%9d", $i;
        $imax = $i + 59; if ($imax > $len) { $imax = $len }
        for ( ; $i <= $imax; $i += $istep) {
            print $fh " " . substr($seq, $i-1, $istep);
        print $fh "\n";
    print $fh "//\n";
=head2 wrap_text
Return a string with text wrapped to defined line lengths:
     $wrapped_text = wrap_text( $str )                  # default len   =  80
     $wrapped_text = wrap_text( $str, $len )            # default ind   =   0
     $wrapped_text = wrap_text( $str, $len, $indent )   # default ind_n = ind
     $wrapped_text = wrap_text( $str, $len, $indent_1, $indent_n )
=cut
sub wrap_text {
    my ($str, $len, $ind, $indn) = @_;
    defined($str)  || die "wrap_text called without a string\n";
    defined($len)  || ($len  =   80);
    defined($ind)  || ($ind  =    0);
    ($ind  < $len) || die "wrap error: indent greater than line length\n";
    defined($indn) || ($indn = $ind);
    ($indn < $len) || die "wrap error: indent_n greater than line length\n";
    $str =~ s/\s+$//;
    $str =~ s/^\s+//;
    my ($maxchr, $maxchr1);
    my (@lines) = ();
    while ($str) {
        $maxchr1 = ($maxchr = $len - $ind) - 1;
        if ($maxchr >= length($str)) {
            push @lines, (" " x $ind) . $str;
            last;
        elsif ($str =~ /^(.{0,$maxchr1}\S)\s+(\S.*)$/) { # no expr in {}
            push @lines, (" " x $ind) . $1;
            $str = $2;
        elsif ($str =~ /^(.{0,$maxchr1}-)(.*)$/) {
            $str = $2;
        else {
            push @lines, (" " x $ind) . substr($str, 0, $maxchr);
            $str = substr($str, $maxchr);
        $ind = $indn;
    return join("\n", @lines);
=head2 index_seq_list
Build an index from seq_id to pointer to sequence entry: (id, desc, seq)
     my \%seq_ind  = index_seq_list(  @seq_list );
     my \%seq_ind  = index_seq_list( \@seq_list );
Usage example:
  my  @seq_list   = read_fasta_seqs(\*STDIN);  # list of pointers to entries
  my \%seq_ind    = index_seq_list(@seq_list); # hash from names to pointers
  my  @chosen_seq = @{%seq_ind{"contig1"}};    # extract one entry
=cut
sub index_seq_list {
    ( ref( $_[0] )      ne 'ARRAY' ) ? {}
  : ( ref( $_[0]->[0] ) ne 'ARRAY' ) ? { map { $_->[0] => $_ } @_ }
  :                                    { map { $_->[0] => $_ } @{ $_[0] } }
=head2 seq access methods
  Three routines to access all or part of sequence entry by id:
    \@seq_entry = seq_entry_by_id( \%seq_index, $seq_id );
=cut
sub seq_entry_by_id {
    (my $ind_ref = shift)  || die "No index supplied to seq_entry_by_id\n";
    (my $id      = shift)  || die "No id supplied to seq_entry_by_id\n";
    return wantarray ? @{ $ind_ref->{$id} } : $ind_ref->{$id};
sub seq_desc_by_id {
    (my $ind_ref = shift)  || die "No index supplied to seq_desc_by_id\n";
    (my $id      = shift)  || die "No id supplied to seq_desc_by_id\n";
    return ${ $ind_ref->{$id} }[1];
sub seq_data_by_id {
    (my $ind_ref = shift)  || die "No index supplied to seq_data_by_id\n";
    (my $id      = shift)  || die "No id supplied to seq_data_by_id\n";
    return ${ $ind_ref->{$id} }[2];
=head2 pack_alignment
Remove columns of alignment gaps from sequences:
Gap characters are defined below as '-', '~', '.', and ' '.
=cut
sub pack_alignment
    $_[0] && ( ref( $_[0] ) eq 'ARRAY' ) && @{$_[0]} && defined( $_[0]->[0] )
        or return ();
    my @seqs = ( ref( $_[0]->[0] ) eq 'ARRAY' ) ? @{$_[0] } : @_;
    @seqs or return wantarray ? () : [];
    my $mask  = gap_mask( $seqs[0]->[2] );
    foreach ( @seqs[ 1 .. (@seqs-1) ] )
        $mask |= gap_mask( $_->[2] );
    my $seq;
    my @seqs2 = map { $seq = $_->[2] & $mask;
                      $seq =~ tr/\000//d;
                      [ $_->[0], $_->[1], $seq ]
                @seqs;
    wantarray ? @seqs2 : \@seqs2;
=head2 alignment_gap_mask
Produce a packing mask for columns of alignment gaps in sequences.  Gap
columns are 0x00 characters, and all others are 0xFF.
=cut
sub alignment_gap_mask
        or return undef;
    @seqs or return undef;
    foreach ( @seqs[ 1 .. (@seqs-1) ] ) { $mask |= gap_mask( $_->[2] ) }
    $mask;
=head2 pack_alignment_by_mask
Pack a sequence alignment according to a mask, removing positions where
mask has 0x00 (or '-') characters
=cut
sub pack_alignment_by_mask
    my $mask = shift;
    defined $mask && ! ref( $mask ) && length( $mask )
        or return ();
    $mask =~ tr/-/\000/;      # Allow '-' as a column to be removed
    $mask =~ tr/\000/\377/c;  # Make sure that everything not null is 0xFF
        or return ();
    my $seq;
    my @seqs2 = map { $seq = $_->[2] & $mask;     # Apply mask to sequence
                      $seq =~ tr/\000//d;         # Delete null characters
                      [ $_->[0], $_->[1], $seq ]  # Rebuild sequence entries
                @seqs;
=head2 weight_alignment_by_mask
Weight a sequence alignment according to a mask of digits, 0-9.
   @packed = weight_alignment_by_mask( $mask,  @align )
   @packed = weight_alignment_by_mask( $mask, \@align )
  \@packed = weight_alignment_by_mask( $mask,  @align )
  \@packed = weight_alignment_by_mask( $mask, \@align )
=cut
sub weight_alignment_by_mask
    my $mask = shift;
        or return ();
        or return ();
    my @seqs2 = map { [ $_->[0], $_->[1], weight_seq_by_mask_0( $mask, $_->[2] ) ] } @seqs;
#  Assume data are valid
sub weight_seq_by_mask_0
    my ( $mask, $seq ) = @_;
    #  Remove 0 weight columns, which is fast and easy:
    my $m0 = $mask;
    $m0 =~ tr/123456789/\377/;
    $m0 =~ tr/\377/\000/c;
    ( $mask &= $m0 ) =~ tr/\000//d;
    ( $seq  &= $m0 ) =~ tr/\000//d;
    #  If all remaining cols are weight 1, we are done:
    return $seq if $mask =~ /^1*$/;
    my @seq;
    for ( my $i = 0; $i < length( $mask ); $i++ )
        push @seq, substr( $seq, $i, 1 ) x substr( $mask, $i, 1 );
    join( '', @seq );
=head2 gap_mask
Make a mask in which gap characters ('-', '~', '.', and ' ') are converted
to 0x00, and all other characters to 0xFF.
      $mask = gap_mask( $seq )
=cut
sub gap_mask
    my $mask = shift;
    defined $mask or return '';
    $mask =~ tr/-~. /\000/;    #  Gap characters (might be extended)
    $mask =~ tr/\000/\377/c;   #  Non-gap characters
    $mask;
=head2 expand_sequence_by_mask
Expand sequences with the local gap character in a manner that reverses the
pack by mask function.
The columns to be added can be marked by '-' or "\000" in the mask.
=head3 Code Note
The function attempts to match the local gap character in the sequence.
$c0 and $c1 are the previous and next characters in the sequence being
expanded.  (($c0,$c1)=($c1,shift @s1))[0] updates the values and evaluates
to what was the next character, and becomes the new previous character.
The following really does print w, x, y, and z, one per line:
     ( $a, $b, @c ) = ("", split //, "wxyz");
     while ( defined $b ) { print( (($a,$b)=($b,shift @c))[0], "\n" ) }
=cut
sub expand_sequence_by_mask
    my ( $seq, $mask ) = @_;
    $mask =~ tr/-/\000/;  #  Allow hyphen or null in mask at added positions.
    my ( $c0, $c1, @s1 ) = ( '', split( //, $seq ), '' );
    join '', map { $_  ne "\000"            ? (($c0,$c1)=($c1,shift @s1))[0]
                 : $c0 eq '~' || $c1 eq '~' ? '~'
                 : $c0 eq '.' || $c1 eq '.' ? '.'
             split //, $mask;
=head2 pack_sequences
Remove all alignment gaps from sequences. This function minimally rewrites
sequence entries, saving memory if nothing else.
   @packed_seqs = pack_sequences(  @seqs )  # Also handles single sequence
=cut
sub pack_sequences
        or return ();
    my @seqs = map { $_->[2] =~ /[^A-Za-z*]/ ? [ @$_[0,1], pack_seq( $_->[2] ) ] : $_ }
=head2 Simple Sequence Manipulation
     @entry  = subseq_DNA_entry( @seq_entry, $from, $to [, $fix_id] );
    \@entry  = subseq_DNA_entry( @seq_entry, $from, $to [, $fix_id] );
     @entry  = subseq_RNA_entry( @seq_entry, $from, $to [, $fix_id] );
    \@entry  = subseq_RNA_entry( @seq_entry, $from, $to [, $fix_id] );
     @entry  = complement_DNA_entry( @seq_entry [, $fix_id] );
     @entry  = complement_RNA_entry( @seq_entry [, $fix_id] );
     $AAsub  = aa_subseq($AAseq, $from, $to);
     $DNAseq = complement_DNA_seq( $NA_seq );
     $RNAseq = complement_RNA_seq( $NA_seq );
     $DNAseq = to_DNA_seq( $NA_seq );
     $RNAseq = to_RNA_seq( $NA_seq );
=cut
sub subseq_DNA_entry
    my ($id, $desc, @rest) = @_;
    my $seq;
    ($id, $seq) = subseq_nt(1, $id, @rest);  # 1 is for DNA, not RNA
    wantarray ? ( $id, $desc, $seq ) : [ $id, $desc, $seq ];
sub subseq_RNA_entry
    my $seq;
    ($id, $seq) = subseq_nt(0, $id, @rest);  # 0 is for not DNA, i.e., RNA
sub subseq_nt {
    my ($DNA, $id, $seq, $from, $to, $fix_id) = @_;
    $fix_id ||= 0;     #  fix undef value
    my $len   = length($seq);
    if (         ( $from eq '$' ) || ( $from eq "" ) ) { $from = $len }
    if (! $to || ( $to   eq '$' ) || ( $to   eq "" ) ) { $to   = $len }
    my $left  = ( $from < $to ) ? $from : $to;
    my $right = ( $from < $to ) ? $to   : $from;
    if ( ( $right < 1 ) || ( $left > $len ) ) { return ($id, "") }
    if ( $right > $len ) { $right = $len }
    if ( $left  < 1    ) { $left  = 1 }
    $seq = substr($seq, $left-1, $right-$left+1);
    if ( $from > $to ) {
        $seq = reverse $seq;
        if ( $DNA ) {
            $seq =~ tr[ACGTUKMRSWYBDHVNacgtukmrswybdhvn]
                      [TGCAAMKYSWRVHDBNtgcaamkyswrvhdbn];
        else {
                      [UGCAAMKYSWRVHDBNugcaamkyswrvhdbn];
    if ( $fix_id ) {
        if ( ( $id =~ s/_(\d+)_(\d+)$// )
          && ( abs($2-$1)+1 == $len ) ) {
            if ( $1 <= $2 ) { $from += $1 - 1;         $to += $1 - 1 }
            else            { $from  = $1 + 1 - $from; $to  = $1 + 1 - $to }
        $id .= "_" . $from . "_" . $to;
    return ($id, $seq);
sub DNA_subseq
    my ( $seq, $from, $to ) = @_;
    my $len = ref( $seq ) eq 'SCALAR' ? length( $$seq )
                                      : length(  $seq );
    if ( ( $to   eq '$' ) || ( ! $to       ) ) { $to   = $len }
    if ( ( $right < 1 ) || ( $left > $len ) ) { return "" }
    my $subseq = ref( $seq ) eq 'SCALAR' ? substr( $$seq, $left-1, $right-$left+1 )
                                         : substr(  $seq, $left-1, $right-$left+1 );
    if ( $from > $to )
        $subseq = reverse $subseq;
        $subseq =~ tr[ACGTUKMRSWYBDHVNacgtukmrswybdhvn]
    $subseq;
sub RNA_subseq
                                      : length(  $seq );
    if ( $from > $to )
    $subseq;
sub aa_subseq
    my $len = ref( $seq ) eq 'SCALAR' ? length( $$seq ) : length(  $seq );
    $from = $from =~ /(\d+)/ && $1        ? $1 :    1;
    $to   = $to   =~ /(\d+)/ && $1 < $len ? $1 : $len;
    return '' if $from > $to;
    ref( $seq ) eq 'SCALAR' ? substr( $$seq, $from-1, $to-$from+1 )
                            : substr(  $seq, $from-1, $to-$from+1 );
sub complement_DNA_entry {
    my ($id, $desc, $seq, $fix_id) = @_;
    $fix_id ||= 0;     #  fix undef values
    wantarray || die "complement_DNA_entry requires array context\n";
    if ($fix_id) {
        if ($id =~ s/_(\d+)_(\d+)$//) {
            $id .= "_" . $2 . "_" . $1;
        else {
            $id .= "_" . length($seq) . "_1";
    return ($id, $desc, $seq);
sub complement_RNA_entry {
    if ($fix_id) {
        else {
sub complement_DNA_seq {
    my $seq = reverse shift;
    return $seq;
sub complement_RNA_seq {
    return $seq;
sub to_DNA_seq {
    my $seq = shift;
    $seq =~ tr/Uu/Tt/;
    return $seq;
sub to_RNA_seq {
    my $seq = shift;
    $seq =~ tr/Tt/Uu/;
    return $seq;
=head2 Sequence Cleaning Utilities
    $seqx = pack_seq($seq);
    $cleaned = clean_ae_sequence($seq);
    $utf8 = to7bit($seq);
    $ascii = to8bit($seq);
=cut
sub pack_seq {
    my $seq = shift;
    $seq =~ tr/A-Za-z*//cd;
    $seq;
sub clean_ae_sequence {
    local $_ = shift;
    $_ = to7bit($_);
    s/\+/1/g;
    s/[^0-9A-IK-NP-Za-ik-np-z~.-]/-/g;
    return $_;
sub to7bit {
    local $_ = shift;
    my ($o, $c);
    while (/\\([0-3][0-7][0-7])/) {
        $o = oct($1) % 128;
        $c = sprintf("%c", $o);
        s/\\$1/$c/g;
    return $_;
sub to8bit {
    local $_ = shift;
    my ($o, $c);
        $o = oct($1);
        s/\\$1/$c/g;
    return $_;
=head2 Protein Translation Utilities
Translate nucleotides to one letter protein:
     $seq = translate_seq( $seq [, $met_start] )
Translate a single triplet with "universal" genetic code.
     $aa  = translate_DNA_codon( $triplet )     # Does not rely on DNA
     $aa  = translate_uc_DNA_codon( $triplet )  # Does not rely on uc or DNA
User-supplied genetic code must be upper case index and match the
DNA versus RNA type of sequence
     $seq = translate_seq_with_user_code( $seq, $gen_code_hash [, $met_start] )
=cut
@aa_1_letter_order = qw( A C D E F G H I K L M N P Q R S T V W Y );  # Alpha by 1 letter
@aa_3_letter_order = qw( A R N D C Q E G H I L K M F P S T W Y V );  # PAM matrix order
@aa_n_codon_order  = qw( L R S A G P T V I C D E F H K N Q Y M W );
%genetic_code = (
    # DNA version
    TTT => 'F',  TCT => 'S',  TAT => 'Y',  TGT => 'C',
    TTC => 'F',  TCC => 'S',  TAC => 'Y',  TGC => 'C',
    TTA => 'L',  TCA => 'S',  TAA => '*',  TGA => '*',
    TTG => 'L',  TCG => 'S',  TAG => '*',  TGG => 'W',
    CTT => 'L',  CCT => 'P',  CAT => 'H',  CGT => 'R',
    CTC => 'L',  CCC => 'P',  CAC => 'H',  CGC => 'R',
    CTA => 'L',  CCA => 'P',  CAA => 'Q',  CGA => 'R',
    CTG => 'L',  CCG => 'P',  CAG => 'Q',  CGG => 'R',
    ATT => 'I',  ACT => 'T',  AAT => 'N',  AGT => 'S',
    ATC => 'I',  ACC => 'T',  AAC => 'N',  AGC => 'S',
    ATA => 'I',  ACA => 'T',  AAA => 'K',  AGA => 'R',
    ATG => 'M',  ACG => 'T',  AAG => 'K',  AGG => 'R',
    GTT => 'V',  GCT => 'A',  GAT => 'D',  GGT => 'G',
    GTC => 'V',  GCC => 'A',  GAC => 'D',  GGC => 'G',
    GTA => 'V',  GCA => 'A',  GAA => 'E',  GGA => 'G',
    GTG => 'V',  GCG => 'A',  GAG => 'E',  GGG => 'G',
    #  The following ambiguous encodings are not necessary,  but
    #  speed up the processing of some ambiguous triplets:
    TTY => 'F',  TCY => 'S',  TAY => 'Y',  TGY => 'C',
    TTR => 'L',  TCR => 'S',  TAR => '*',
                 TCN => 'S',
    CTY => 'L',  CCY => 'P',  CAY => 'H',  CGY => 'R',
    CTR => 'L',  CCR => 'P',  CAR => 'Q',  CGR => 'R',
    CTN => 'L',  CCN => 'P',               CGN => 'R',
    ATY => 'I',  ACY => 'T',  AAY => 'N',  AGY => 'S',
                 ACR => 'T',  AAR => 'K',  AGR => 'R',
                 ACN => 'T',
    GTY => 'V',  GCY => 'A',  GAY => 'D',  GGY => 'G',
    GTR => 'V',  GCR => 'A',  GAR => 'E',  GGR => 'G',
    GTN => 'V',  GCN => 'A',               GGN => 'G'
#  Add RNA by construction:
foreach ( grep { /T/ } keys %genetic_code )
    my $codon = $_;
    $codon =~ s/T/U/g;
    $genetic_code{ $codon } = lc $genetic_code{ $_ }
#  Add lower case by construction:
foreach ( keys %genetic_code )
    $genetic_code{ lc $_ } = lc $genetic_code{ $_ }
#  Construct the genetic code with selenocysteine by difference:
%genetic_code_with_U = %genetic_code;
$genetic_code_with_U{ TGA } = 'U';
$genetic_code_with_U{ tga } = 'u';
$genetic_code_with_U{ UGA } = 'U';
$genetic_code_with_U{ uga } = 'u';
%amino_acid_codons_DNA = (
         L  => [ qw( TTA TTG CTA CTG CTT CTC ) ],
         R  => [ qw( AGA AGG CGA CGG CGT CGC ) ],
         S  => [ qw( AGT AGC TCA TCG TCT TCC ) ],
         A  => [ qw( GCA GCG GCT GCC ) ],
         G  => [ qw( GGA GGG GGT GGC ) ],
         P  => [ qw( CCA CCG CCT CCC ) ],
         T  => [ qw( ACA ACG ACT ACC ) ],
         V  => [ qw( GTA GTG GTT GTC ) ],
         I  => [ qw( ATA ATT ATC ) ],
         C  => [ qw( TGT TGC ) ],
         D  => [ qw( GAT GAC ) ],
         E  => [ qw( GAA GAG ) ],
         F  => [ qw( TTT TTC ) ],
         H  => [ qw( CAT CAC ) ],
         K  => [ qw( AAA AAG ) ],
         N  => [ qw( AAT AAC ) ],
         Q  => [ qw( CAA CAG ) ],
         Y  => [ qw( TAT TAC ) ],
         M  => [ qw( ATG ) ],
         U  => [ qw( TGA ) ],
         W  => [ qw( TGG ) ],
         l  => [ qw( tta ttg cta ctg ctt ctc ) ],
         r  => [ qw( aga agg cga cgg cgt cgc ) ],
         s  => [ qw( agt agc tca tcg tct tcc ) ],
         a  => [ qw( gca gcg gct gcc ) ],
         g  => [ qw( gga ggg ggt ggc ) ],
         p  => [ qw( cca ccg cct ccc ) ],
         t  => [ qw( aca acg act acc ) ],
         v  => [ qw( gta gtg gtt gtc ) ],
         i  => [ qw( ata att atc ) ],
         c  => [ qw( tgt tgc ) ],
         d  => [ qw( gat gac ) ],
         e  => [ qw( gaa gag ) ],
         f  => [ qw( ttt ttc ) ],
         h  => [ qw( cat cac ) ],
         k  => [ qw( aaa aag ) ],
         n  => [ qw( aat aac ) ],
         q  => [ qw( caa cag ) ],
         y  => [ qw( tat tac ) ],
         m  => [ qw( atg ) ],
         u  => [ qw( tga ) ],
         w  => [ qw( tgg ) ],
        '*' => [ qw( TAA TAG TGA ) ]
%amino_acid_codons_RNA = (
         L  => [ qw( UUA UUG CUA CUG CUU CUC ) ],
         R  => [ qw( AGA AGG CGA CGG CGU CGC ) ],
         S  => [ qw( AGU AGC UCA UCG UCU UCC ) ],
         A  => [ qw( GCA GCG GCU GCC ) ],
         G  => [ qw( GGA GGG GGU GGC ) ],
         P  => [ qw( CCA CCG CCU CCC ) ],
         T  => [ qw( ACA ACG ACU ACC ) ],
         V  => [ qw( GUA GUG GUU GUC ) ],
         B  => [ qw( GAU GAC AAU AAC ) ],
         Z  => [ qw( GAA GAG CAA CAG ) ],
         I  => [ qw( AUA AUU AUC ) ],
         C  => [ qw( UGU UGC ) ],
         D  => [ qw( GAU GAC ) ],
         F  => [ qw( UUU UUC ) ],
         H  => [ qw( CAU CAC ) ],
         N  => [ qw( AAU AAC ) ],
         Y  => [ qw( UAU UAC ) ],
         M  => [ qw( AUG ) ],
         U  => [ qw( UGA ) ],
         W  => [ qw( UGG ) ],
         l  => [ qw( uua uug cua cug cuu cuc ) ],
         r  => [ qw( aga agg cga cgg cgu cgc ) ],
         s  => [ qw( agu agc uca ucg ucu ucc ) ],
         a  => [ qw( gca gcg gcu gcc ) ],
         g  => [ qw( gga ggg ggu ggc ) ],
         p  => [ qw( cca ccg ccu ccc ) ],
         t  => [ qw( aca acg acu acc ) ],
         v  => [ qw( gua gug guu guc ) ],
         b  => [ qw( gau gac aau aac ) ],
         z  => [ qw( gaa gag caa cag ) ],
         i  => [ qw( aua auu auc ) ],
         c  => [ qw( ugu ugc ) ],
         d  => [ qw( gau gac ) ],
         f  => [ qw( uuu uuc ) ],
         h  => [ qw( cau cac ) ],
         n  => [ qw( aau aac ) ],
         y  => [ qw( uau uac ) ],
         m  => [ qw( aug ) ],
         u  => [ qw( uga ) ],
         w  => [ qw( ugg ) ],
        '*' => [ qw( UAA UAG UGA ) ]
%n_codon_for_aa = map {
    $_ => scalar @{ $amino_acid_codons_DNA{ $_ } }
    } keys %amino_acid_codons_DNA;
%reverse_genetic_code_DNA = (
         A  => "GCN",  a  => "gcn",
         C  => "TGY",  c  => "tgy",
         D  => "GAY",  d  => "gay",
         E  => "GAR",  e  => "gar",
         F  => "TTY",  f  => "tty",
         G  => "GGN",  g  => "ggn",
         H  => "CAY",  h  => "cay",
         I  => "ATH",  i  => "ath",
         K  => "AAR",  k  => "aar",
         L  => "YTN",  l  => "ytn",
         M  => "ATG",  m  => "atg",
         N  => "AAY",  n  => "aay",
         P  => "CCN",  p  => "ccn",
         Q  => "CAR",  q  => "car",
         R  => "MGN",  r  => "mgn",
         S  => "WSN",  s  => "wsn",
         T  => "ACN",  t  => "acn",
         U  => "TGA",  u  => "tga",
         V  => "GTN",  v  => "gtn",
         W  => "TGG",  w  => "tgg",
         X  => "NNN",  x  => "nnn",
         Y  => "TAY",  y  => "tay",
        '*' => "TRR"
%reverse_genetic_code_RNA = (
         C  => "UGY",  c  => "ugy",
         F  => "UUY",  f  => "uuy",
         I  => "AUH",  i  => "auh",
         L  => "YUN",  l  => "yun",
         M  => "AUG",  m  => "aug",
         U  => "UGA",  u  => "uga",
         V  => "GUN",  v  => "gun",
         W  => "UGG",  w  => "ugg",
         Y  => "UAY",  y  => "uay",
        '*' => "URR"
%DNA_letter_can_be = (
    A => ["A"],                 a => ["a"],
    B => ["C", "G", "T"],       b => ["c", "g", "t"],
    C => ["C"],                 c => ["c"],
    D => ["A", "G", "T"],       d => ["a", "g", "t"],
    G => ["G"],                 g => ["g"],
    H => ["A", "C", "T"],       h => ["a", "c", "t"],
    K => ["G", "T"],            k => ["g", "t"],
    M => ["A", "C"],            m => ["a", "c"],
    N => ["A", "C", "G", "T"],  n => ["a", "c", "g", "t"],
    R => ["A", "G"],            r => ["a", "g"],
    S => ["C", "G"],            s => ["c", "g"],
    T => ["T"],                 t => ["t"],
    U => ["T"],                 u => ["t"],
    V => ["A", "C", "G"],       v => ["a", "c", "g"],
    W => ["A", "T"],            w => ["a", "t"],
    Y => ["C", "T"],            y => ["c", "t"]
%RNA_letter_can_be = (
    B => ["C", "G", "U"],       b => ["c", "g", "u"],
    D => ["A", "G", "U"],       d => ["a", "g", "u"],
    H => ["A", "C", "U"],       h => ["a", "c", "u"],
    K => ["G", "U"],            k => ["g", "u"],
    N => ["A", "C", "G", "U"],  n => ["a", "c", "g", "u"],
    T => ["U"],                 t => ["u"],
    U => ["U"],                 u => ["u"],
    W => ["A", "U"],            w => ["a", "u"],
    Y => ["C", "U"],            y => ["c", "u"]
%one_letter_to_three_letter_aa = (
         A  => "Ala", a  => "Ala",
         B  => "Asx", b  => "Asx",
         C  => "Cys", c  => "Cys",
         D  => "Asp", d  => "Asp",
         E  => "Glu", e  => "Glu",
         F  => "Phe", f  => "Phe",
         G  => "Gly", g  => "Gly",
         H  => "His", h  => "His",
         I  => "Ile", i  => "Ile",
         K  => "Lys", k  => "Lys",
         L  => "Leu", l  => "Leu",
         M  => "Met", m  => "Met",
         N  => "Asn", n  => "Asn",
         P  => "Pro", p  => "Pro",
         Q  => "Gln", q  => "Gln",
         R  => "Arg", r  => "Arg",
         S  => "Ser", s  => "Ser",
         T  => "Thr", t  => "Thr",
         U  => "Sec", u  => "Sec",
         V  => "Val", v  => "Val",
         W  => "Trp", w  => "Trp",
         X  => "Xxx", x  => "Xxx",
         Y  => "Tyr", y  => "Tyr",
         Z  => "Glx", z  => "Glx",
%three_letter_to_one_letter_aa = (
     ALA  => "A",   Ala  => "A",   ala  => "a",
     ARG  => "R",   Arg  => "R",   arg  => "r",
     ASN  => "N",   Asn  => "N",   asn  => "n",
     ASP  => "D",   Asp  => "D",   asp  => "d",
     ASX  => "B",   Asx  => "B",   asx  => "b",
     CYS  => "C",   Cys  => "C",   cys  => "c",
     GLN  => "Q",   Gln  => "Q",   gln  => "q",
     GLU  => "E",   Glu  => "E",   glu  => "e",
     GLX  => "Z",   Glx  => "Z",   glx  => "z",
     GLY  => "G",   Gly  => "G",   gly  => "g",
     HIS  => "H",   His  => "H",   his  => "h",
     ILE  => "I",   Ile  => "I",   ile  => "i",
     LEU  => "L",   Leu  => "L",   leu  => "l",
     LYS  => "K",   Lys  => "K",   lys  => "k",
     MET  => "M",   Met  => "M",   met  => "m",
     PHE  => "F",   Phe  => "F",   phe  => "f",
     PRO  => "P",   Pro  => "P",   pro  => "p",
     SEC  => "U",   Sec  => "U",   sec  => "u",
     SER  => "S",   Ser  => "S",   ser  => "s",
     THR  => "T",   Thr  => "T",   thr  => "t",
     TRP  => "W",   Trp  => "W",   trp  => "w",
     TYR  => "Y",   Tyr  => "Y",   tyr  => "y",
     VAL  => "V",   Val  => "V",   val  => "v",
     XAA  => "X",   Xaa  => "X",   xaa  => "x",
     XXX  => "X",   Xxx  => "X",   xxx  => "x",
sub translate_seq
    my $seq = shift;
    $seq =~ tr/-//d;        #  remove gaps
    my @codons = $seq =~ m/(...?)/g;  #  Will try to translate last 2 nt
    #  A second argument that is true forces first amino acid to be Met
    my @met;
    if ( ( shift @_ ) && ( my $codon1 = shift @codons ) )
        push @met, ( $codon1 =~ /[a-z]/ ? 'm' : 'M' );
    join( '', @met, map { translate_codon( $_ ) } @codons )
=pod
=cut
sub translate_DNA_codon { translate_codon( @_ ) }
sub translate_uc_DNA_codon { translate_codon( uc $_[0] ) }
sub translate_codon
    my $codon = shift;
    $codon =~ tr/Uu/Tt/;     #  Make it DNA
    #  Try a simple lookup:
    my $aa;
    if ( $aa = $genetic_code{ $codon } ) { return $aa }
    #  Attempt to recover from mixed-case codons:
    $codon = ( $codon =~ /^.[a-z]/ ) ? lc $codon : uc $codon;
    #  The code defined above catches simple N, R and Y ambiguities in the
    #  third position.  Other codons (e.g., GG[KMSWBDHV], or even GG) might
    #  be unambiguously translated by converting the last position to N and
    #  seeing if this is in the code table:
    my $N = ( $codon =~ /^.[a-z]/ ) ? 'n' : 'N';
    if ( $aa = $genetic_code{ substr($codon,0,2) . $N } ) { return $aa }
    #  Test that codon is valid for an unambiguous aa:
    my $X = ( $codon =~ /^.[a-z]/ ) ? 'x' : 'X';
    if ( $codon !~ m/^[ACGTMY][ACGT][ACGTKMRSWYBDHVN]$/i
      && $codon !~ m/^YT[AGR]$/i     #  Leu YTR
      && $codon !~ m/^MG[AGR]$/i     #  Arg MGR
        return $X;
    #  Expand all ambiguous nucleotides to see if they all yield same aa.
    my @n1 = @{ $DNA_letter_can_be{ substr( $codon, 0, 1 ) } };
    my $n2 =                        substr( $codon, 1, 1 );
    my @n3 = @{ $DNA_letter_can_be{ substr( $codon, 2, 1 ) } };
    my @triples = map { my $n12 = $_ . $n2; map { $n12 . $_ } @n3 } @n1;
    my $triple = shift @triples;
    $aa = $genetic_code{ $triple };
    $aa or return $X;
    foreach $triple ( @triples ) { return $X if $aa ne $genetic_code{$triple} }
    return $aa;
=pod
  Translate with a user-supplied genetic code to translate a sequence.
  Diagnose the use of upper versus lower, and T versus U in the supplied
  code, and transform the supplied nucleotide sequence to match.
     $aa = translate_seq_with_user_code( $nt, \%gen_code )
     $aa = translate_seq_with_user_code( $nt, \%gen_code, $start_with_met )
  Modified 2007-11-22 to be less intrusive in these diagnoses by sensing
  the presence of both versions in the user code.
=cut
sub translate_seq_with_user_code
    my $seq = shift;
    $seq =~ tr/-//d;     #  remove gaps  ***  Why?
    my $gc = shift;      #  Reference to hash of code
    if (! $gc || ref($gc) ne "HASH")
        print STDERR "translate_seq_with_user_code needs genetic code hash as second argument.";
        return undef;
    #  Test code support for upper vs lower case:
    my ( $TTT, $UUU );
    if    ( $gc->{AAA} && ! $gc->{aaa} )   #  Uppercase only code table
        $seq = uc $seq;     #  Uppercase sequence
        ( $TTT, $UUU ) = ( 'TTT', 'UUU' );
    elsif ( $gc->{aaa} && ! $gc->{AAA} )   #  Lowercase only code table
        $seq = lc $seq;     #  Lowercase sequence
        ( $TTT, $UUU ) = ( 'ttt', 'uuu' );
    elsif ( $gc->{aaa} )
    else
        print STDERR "User-supplied genetic code does not have aaa or AAA\n";
        return undef;
    #  Test code support for U vs T:
    my $ambigs;
    if    ( $gc->{$UUU} && ! $gc->{$TTT} )  # RNA only code table
        $seq =~ tr/Tt/Uu/;
        $ambigs = \%RNA_letter_can_be;
    elsif ( $gc->{$TTT} && ! $gc->{$UUU} )  # DNA only code table
        $seq =~ tr/Uu/Tt/;
        $ambigs = \%DNA_letter_can_be;
    else
        my $t = $seq =~ tr/Tt//;
        my $u = $seq =~ tr/Uu//;
        $ambigs = ( $t > $u ) ? \%DNA_letter_can_be : \%RNA_letter_can_be;
    #  We can now do the codon-by-codon translation:
    my @codons = $seq =~ m/(...?)/g;  #  will try to translate last 2 nt
    #  A third argument that is true forces first amino acid to be Met
    my @met;
    join( '', @met, map { translate_codon_with_user_code( $_, $gc, $ambigs ) } @codons )
=head3 translate_codon_with_user_code
Translate with user-supplied genetic code hash.  No error check on the code.
Should only be called through translate_seq_with_user_code.
     $aa = translate_codon_with_user_code( $triplet, \%code, \%ambig_table )
=over 4
=item $triplet
speaks for itself
=item \%code
ref to the hash with the codon translations
=item \%ambig_table
ref to hash with lists of nucleotides for each ambig code
=back
=cut
sub translate_codon_with_user_code
    my ( $codon, $gc, $ambigs ) = @_;
    my $aa;
    if ( $aa = $gc->{ $codon } ) { return $aa }
    if ( $aa = $gc->{ lc $codon } ) { return( $gc->{ $codon } = $aa ) }
    if ( $aa = $gc->{ uc $codon } ) { return( $gc->{ $codon } = $aa ) }
    $codon = ( $codon =~ /[a-z]/ ) ? lc $codon : uc $codon;
    my $X = ( $codon =~ /[a-z]/ ) ? 'x' : 'X';
    if ( $codon =~ m/^[ACGTU][ACGTU]$/i )  # Add N?
        $codon .= ( $codon =~ /[a-z]/ ) ? 'n' : 'N';
    #  This makes assumptions about the user code, but tranlating ambiguous
    #  codons is really a bit off the wall to start with:
    elsif ( $codon !~ m/^[ACGTUMY][ACGTU][ACGTUKMRSWYBDHVN]$/i ) # Valid?
        return( $gc->{ $codon } = $X );
    my @n1 = @{ $ambigs->{ substr( $codon, 0, 1 ) } };
    my @n3 = @{ $ambigs->{ substr( $codon, 2, 1 ) } };
    $aa = $gc->{ $triple } || $gc->{ lc $triple } || $gc->{ uc $triple };
    $aa or return( $gc->{ $codon } = $X );
        return( $gc->{ $codon } = $X ) if $aa ne ( $gc->{$triple} || $gc->{lc $triple} || $gc->{uc $triple} );
    return( $gc->{ $codon } = $aa );
=head2 read_intervals
Read a list of intervals from a file.
Allow id_start_end, or id \s start \s end formats
=cut
sub read_intervals {
    my $fh = shift;
    my @intervals = ();
    while (<$fh>) {
        chomp;
           /^(\S+)_(\d+)_(\d+)(\s.*)?$/        #  id_start_end       WIT2
        || /^(\S+)_(\d+)-(\d+)(\s.*)?$/        #  id_start-end       ???
        || /^(\S+)=(\d+)=(\d+)(\s.*)?$/        #  id=start=end       Badger
        || /^(\S+)\s+(\d+)\s+(\d+)(\s.*)?$/    #  id \s start \s end
        || next;
        #  Matched a pattern.  Store reference to (id, left, right):
        push @intervals, ($2 < $3) ? [ $1, $2+0, $3+0 ]
                                   : [ $1, $3+0, $2+0 ];
    return @intervals;
=head2 standardize_intervals
Convert a list of intervals to read [ id, left_end, right_end ].
=cut
sub standardize_intervals {
    map { ( $_->[1] < $_->[2] ) ? $_ : [ $_->[0], $_->[2], $_->[1] ] } @_;
=head2 join_intervals
Take the union of a list of intervals
=cut
sub join_intervals {
    my @ordered = sort { $a->[0] cmp $b->[0]   # first by id
                      || $a->[1] <=> $b->[1]   # next by left end
                      || $b->[2] <=> $a->[2]   # finally longest first
                       } @_;
    my @joined = ();
    my $n_int = @ordered;
    my ($cur_id)    = "";
    my ($cur_left)  = -1;
    my ($cur_right) = -1;
    my ($new_id, $new_left, $new_right);
    for (my $i = 0; $i < $n_int; $i++) {
        ($new_id, $new_left, $new_right) = @{$ordered[$i]};  # get the new data
        if ( ( $new_id ne $cur_id)          # if new contig
          || ( $new_left > $cur_right + 1)  #    or not touching previous
           ) {                              # push the previous interval
            if ($cur_id) { push (@joined, [ $cur_id, $cur_left, $cur_right ]) }
            $cur_id = $new_id;              # update the current interval
            $cur_left = $new_left;
            $cur_right = $new_right;
        elsif ($new_right > $cur_right) {   # extend the right end if necessary
    if ($cur_id) { push (@joined, [$cur_id, $cur_left, $cur_right]) }
    return @joined;
=head2 locations_2_intervals
Split location strings to oriented intervals.
=cut
sub locations_2_intervals {
    my @intervals = map { /^(\S+)_(\d+)_(\d+)(\s.*)?$/
                        } @_;
    return wantarray ? @intervals : $intervals[0];
=head2 read_oriented_intervals
Read a list of oriented intervals from a file.
=cut
sub read_oriented_intervals {
    my $fh = shift;
    my @intervals = ();
    while (<$fh>) {
        chomp;
        || next;
        #  Matched a pattern.  Store reference to (id, start, end):
        push @intervals, [ $1, $2+0, $3+0 ];
    return @intervals;
=head2 reverse_intervals
Reverse the orientation of a list of intervals
=cut
sub reverse_intervals {
    map { [ $_->[0], $_->[2], $_->[1] ] } @_;
=head2 gb_location_2_seed
=cut
sub gb_location_2_seed
    my $contig = shift @_;
    $contig or die "First arg of gb_location_2_seed must be contig_id\n";
    map { join( ',', gb_loc_2_seed_2( $contig, $_ ) ) || undef } @_
sub gb_loc_2_seed_2
    my ( $contig, $loc ) = @_;
    if ( $loc =~ /^(\d+)\.\.(\d+)$/ )
        join( '_', $contig, $1, $2 )
    elsif ( $loc =~ /^join\((.*)\)$/ )
        $loc = $1;
        my $lvl = 0;
        for ( my $i = length( $loc )-1; $i >= 0; $i-- )
            for ( substr( $loc, $i, 1 ) )
                /,/ && ! $lvl and substr( $loc, $i, 1 ) = "\t";
                /\(/          and $lvl--;
                /\)/          and $lvl++;
        $lvl == 0 or print STDERR "Paren matching error: $loc\n" and die;
        map { gb_loc_2_seed_2( $contig, $_ ) } split /\t/, $loc
    elsif ( $loc =~ /^complement\((.*)\)$/ )
        map { s/_(\d+)_(\d+)$/_$2_$1/; $_ }
        reverse
        gb_loc_2_seed_2( $contig, $1 )
    else
=head2 read_qual
Save the contents in a list of refs to arrays: [ $id, $descript, \@qual ]
=cut
sub read_qual {
    $unused && die "Bad reference type (" . ref( $unused ) . ") passed to read_qual\n";
    my @quals = ();
    my ($id, $desc, $qual) = ("", "", []);
    while ( <$fh> ) {
        chomp;
            if ($id && @$qual) { push @quals, [ $id, $desc, $qual ] }
            ($id, $desc, $qual) = ($1, $3 ? $3 : "", []);
        else {
            push @$qual, split;
    return wantarray ? @quals : \@quals;
=head2 fraction_nt_diff
Fraction difference for an alignment of two nucleotide sequences in terms of
number of differing residues, number of gaps, and number of gap opennings.
or
     $fraction_diff = fraction_nt_diff( $seq1, $seq2, $gap_wgt )
     $fraction_diff = fraction_nt_diff( $seq1, $seq2, $open_wgt, $extend_wgt )
Options:
      gap      => $gap_wgt          # Gap open and extend weight (D = 0.5)
      open     => $open_wgt         # Gap openning weight (D = gap_wgt)
      extend   => $extend_wgt       # Gap extension weight (D = open_wgt)
      t_gap    => $term_gap_wgt     # Terminal open and extend weight
      t_open   => $term_open_wgt    # Terminal gap open weight (D = open_wgt)
      t_extend => $term_extend_wgt  # Terminal gap extend weight (D = extend_wgt)
Default gap open and gap extend weights are 1/2.  Beware that
     $fraction_diff = fraction_nt_diff( $seq1, $seq2, 1 )
and
     $fraction_diff = fraction_nt_diff( $seq1, $seq2, 1, 0 )
are different.  The first has equal openning and extension weights, whereas
the second has an openning weight of 1, and and extension weight of 0 (it
only penalizes the number of runs of gaps).
=cut
sub fraction_nt_diff
    my ( $npos, $nid, $ndif, $ngap, $nopen, $tgap, $topen ) = interpret_nt_align( @_[0,1] );
    my $diff_scr;
    if ( ref( $_[2] ) eq 'HASH' )
        my $opts = $_[2];
        my $gap_open    = defined $opts->{ open }     ? $opts->{ open }
                        : defined $opts->{ gap }      ? $opts->{ gap }
                        : 0.5;
        my $gap_extend  = defined $opts->{ extend }   ? $opts->{ extend }
                        : $gap_open;
        my $term_open   = defined $opts->{ t_open }   ? $opts->{ t_open }
                        : defined $opts->{ t_gap }    ? $opts->{ t_gap }
                        : $gap_open;
        my $term_extend = defined $opts->{ t_extend } ? $opts->{ t_extend }
                        : $gap_extend;
        $nopen -= $topen;
        $ngap  -= $tgap;
        $diff_scr = $ndif + $gap_open  * $nopen + $gap_extend  * ($ngap-$nopen)
                          + $term_open * $topen + $term_extend * ($tgap-$topen);
    else
        my $gap_open   = defined( $_[2] ) ? $_[2] : 0.5;
        my $gap_extend = defined( $_[3] ) ? $_[3] : $gap_open;
        $diff_scr = $ndif + $gap_open * $nopen + $gap_extend * ($ngap-$nopen);
    my $ttl_scr = $nid + $diff_scr;
    $ttl_scr ? $diff_scr / $ttl_scr : undef
=head2 interpret_nt_align
Interpret an alignment of two nucleotide sequences in terms of: useful
aligned positions (unambiguous, and not a common gap), number of identical
residues, number of differing residues, number of gaps, and number of gap
opennings.
  $npos  = total aligned positons (= $nid + $ndif + $ngap)
  $nid   = number of positions with identical nucleotides (ignoring case)
  $ndif  = number of positions with differing nucleotides
  $ngap  = number of positions with gap in one sequence but not the other
  $nopen = number of runs of gaps
  $tgap  = number of gaps in runs adjacent to a terminus
  $topen = number of alignment ends with gaps
Some of the methods might seem overly complex, but are necessary for cases
in which the gaps switch strands in the alignment:
     seq1  ---ACGTGAC--TTGCAGAG
     seq2  TTT---TGACGG--GCAGGG
     mask  00000011110000111111
     npos  = 20
     nid   =  9
     ndif  =  1
     ngap  = 10
     nopen =  4
     tgap  =  3
     topen =  1
Although there are 4 gap opennings, there are only 2 runs in the mask,
and the terminal run is length 6, not 3.  (Why handle these?  Because
pairs of sequences from a multiple sequence alignment can look like this.)
=cut
sub interpret_nt_align
    #  Remove alignment columns that are not informative:
    my ( $s1, $s2 ) = useful_nt_align( @_[0,1] );
    my $nmat = length( $s1 );          # Useful alignment length
    my $m1 = $s1;
    $m1 =~ tr/ACGT/\377/;              # Nucleotides to all 1 bits
    $m1 =~ tr/\377/\000/c;             # Others (gaps) to null byte
    my $m2 = $s2;
    $m2 =~ tr/ACGT/\377/;              # Nucleotides to all 1 bits
    $m2 =~ tr/\377/\000/c;             # Others (gaps) to null byte
    $m1 &= $m2;                        # Gap in either sequence becomes null
    $s1 &= $m1;                        # Apply mask to sequence 1
    $s2 &= $m1;                        # Apply mask to sequence 2
    my $nopen = @{[ $s1 =~ /\000+/g ]}   # Gap opens in sequence 1
              + @{[ $s2 =~ /\000+/g ]};  # Gap opens in sequence 2
    my ( $tgap, $topen ) = ( 0, 0 );
    if ( $s1 =~ /^(\000+)/ || $s2 =~ /^(\000+)/ ) { $tgap += length( $1 ); $topen++ }
    if ( $s1 =~ /(\000+)$/ || $s2 =~ /(\000+)$/ ) { $tgap += length( $1 ); $topen++ }
    $s1 =~ tr/\000//d;                 # Remove nulls (former gaps)
    $s2 =~ tr/\000//d;                 # Remove nulls (former gaps)
    my $ngap = $nmat - length( $s1 );  # Total gaps
    my $xor = $s1 ^ $s2;               # xor of identical residues is null byte
    my $nid = ( $xor =~ tr/\000//d );  # Count the nulls (identical residues)
    my $ndif = $nmat - $nid - $ngap;
    ( $nmat, $nid, $ndif, $ngap, $nopen, $tgap, $topen )
sub useful_nt_align
    my ( $s1, $s2 ) = map { uc $_ } @_;
    $s1 =~ tr/U/T/;         # Convert U to T
    my $m1 = $s1;
    $m1 =~ tr/ACGT-/\377/;  # Allowed symbols to hex FF byte
    $m1 =~ tr/\377/\000/c;  # All else to null byte
    $s2 =~ tr/U/T/;         # Convert U to T
    my $m2 = $s2;
    $m2 =~ tr/ACGT-/\377/;  # Allowed symbols to hex FF byte
    $m2 =~ tr/\377/\000/c;  # All else to null byte
    $m1 &= $m2;             # Invalid in either sequence becomes null
    $s1 =~ tr/\000//d;      # Delete nulls in sequence 1
    $s2 =~ tr/\000//d;      # Delete nulls in sequence 2
    ( $s1, $s2 )
=head2 interpret_aa_align
Interpret an alignment of two protein sequences in terms of: useful
openings.
     ( $nmat, $nid, $ndif, $ngap, $nopen, $tgap, $topen ) = interpret_aa_align( $seq1, $seq2 )
  $nmat  = total aligned positons (= $nid + $ndif + $ngap)
  $nid   = number of positions with identical amino acids (ignoring case)
  $ndif  = number of positions with differing amino acids
=cut
sub interpret_aa_align
    my ( $s1, $s2 ) = useful_aa_align( @_[0,1] );
    my $m1 = $s1;
    $m1 =~ tr/ACDEFGHIKLMNPQRSTUVWY/\377/;  # Amino acids to all 1 bits
    my $m2 = $s2;
    $m2 =~ tr/ACDEFGHIKLMNPQRSTUVWY/\377/;  # Amino acids to all 1 bits
#  Remove alignment columns with a nonvalid character or shared gaps
sub useful_aa_align
    defined( $_[0] ) && defined( $_[1] ) or return ();
    my $m1 = my $s1 = uc $_[0];
    my $m2 = my $s2 = uc $_[1];
    #  Valid characters in seq1 and seq2
    $m1 =~ tr/ACDEFGHIKLMNPQRSTUVWY-/\377/; $m1 =~ tr/\377/\000/c;
    $m2 =~ tr/ACDEFGHIKLMNPQRSTUVWY-/\377/; $m2 =~ tr/\377/\000/c;
    $m1 &= $m2;             # Valid in seq1 and seq2
    #  Shared gaps
    my $m3 = $s1; $m3 =~ tr/-/\000/; $m3 =~ tr/\000/\377/c;
    my $m4 = $s2; $m4 =~ tr/-/\000/; $m4 =~ tr/\000/\377/c;
    #  Valid and not shared gap;
    $m1 &= $m3 | $m4;
    ( $s1, $s2 );
=head2 oligomer_similarity
Return the fraction identity for oligomers over a range of lengths
=cut
sub oligomer_similarity
    my ( $seq1, $seq2, $opts ) = @_;
    $seq1 && $seq2 or return ();
    $seq1 = $seq1->[2] if ref( $seq1 ) eq 'ARRAY';
    $seq2 = $seq2->[2] if ref( $seq2 ) eq 'ARRAY';
    $opts && ref( $opts ) eq 'HASH' or ( $opts = {} );
    my $min = $opts->{ min } || $opts->{ max } || 2;
    my $max = $opts->{ max } || $min;
    return () if $max < $min;
    #  Remove shared gaps
    my $mask1 = gap_mask( $seq1 );
    my $mask2 = gap_mask( $seq2 );
    my $mask  = $mask1 | $mask2;
    $seq1     = $seq1 & $mask;          # Apply mask to sequence
    $seq1     =~ tr/\000//d;     # Delete null characters
    $seq2     = $seq2 & $mask;          # Apply mask to sequence
    $seq2     =~ tr/\000//d;     # Delete null characters
    #  Remove terminal gaps
    $mask  = $mask1 & $mask2;
    my $n1 = $mask =~ /^(\000+)/ ? length( $1 ) : 0;
    my $n2 = $mask =~ /(\000+)$/ ? length( $1 ) : 0;
    if ( $n1 || $n2 )
        my $len = length( $seq1 ) - ( $n1 + $n2 );
        $seq1 = substr( $seq1, $n1, $len );
        $seq2 = substr( $seq2, $n1, $len );
    #  Find the runs of identity
    my $xor = $seq1 ^ $seq2;           # xor of identical residues is null byte
    # Runs with one or more identities
    my %cnt;
    foreach ( $xor =~ m/(\000+)/g ) { $cnt{ length($_) }++ }
    map { my $n = $_;
          my $ttl = 0;
          for ( grep { $_ >= $n } keys %cnt ) { $ttl += $cnt{$_} * ( $_ - ($n-1) ) }
          my $nmax = length( $xor ) - ($n-1);
          $nmax > 0 ? $ttl / $nmax : undef;
        } ( $min .. $max );
=head2 Guess Type of a Sequence
  $sequence can be a string, a reference to a string, or an id_def_seq triple.
  $type will be a keyword: 'DNA', 'RNA' or 'protein', or '' in case of error.
=cut
sub guess_seq_type
    local $_ = ( !      $_[0]               ) ?   undef
             : ( ! ref( $_[0] )             ) ?   $_[0]
             : (   ref( $_[0] ) eq 'SCALAR' ) ? ${$_[0]}
             : (   ref( $_[0] ) eq 'ARRAY'  ) ?   $_[0]->[2]
             :                                    undef;
    return '' unless $_;
    my $nt = tr/ACGNTUacgntu//;                                # nucleotides
    my $aa = tr/ACDEFGHIKLMNPQRSTVWXYacdefghiklmnpqrstvwxy//;  # amino acids
    return '' unless $nt + $aa > 10;
    return  $nt < 0.75 * $aa  ? 'protein'    # amino acids > nucleotides
          : tr/EFILPQefilpq// ? ''           # nonnucleotides are very bad
          : tr/Uu// > tr/Tt// ? 'RNA'
          :                     'DNA';
sub is_dna  { guess_seq_type( $_[0] ) eq 'DNA' }
sub is_rna  { guess_seq_type( $_[0] ) eq 'RNA' }
sub is_na   { guess_seq_type( $_[0] ) =~ /^.NA$/ }
sub is_prot { guess_seq_type( $_[0] ) =~ /^prot/ }
=head2 Is (Array Of) Sequence Triple
=cut
sub is_sequence_triple
    local $_ = shift;
    $_ && ( ref($_) eq 'ARRAY' )
       && ( @$_ == 3 )
       && defined( $_->[0] )
       && defined( $_->[2] );
sub is_array_of_sequence_triples
    local $_ = $_[0];
    $_ && ref( $_ ) eq 'ARRAY' && @$_ == grep { is_sequence_triple( $_ ) } @$_;
1;
