[Bio] / FigKernelPackages / gjophylip.pm Repository:
Log of /FigKernelPackages/gjophylip.pm
Sun Jan 2 21:18:09 2011 UTC (9 years ago) by golsen
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.8: +3 -3 lines
Fix a cosmetic issue in the cleaning of sequences for PHYLIP.
Mon Dec 13 21:34:34 2010 UTC (9 years, 1 month ago) by fangfang
do not replace - in process_dna_alignment
Tue Dec 7 00:36:46 2010 UTC (9 years, 1 month ago) by golsen
Changes since 1.6: +30 -10 lines
Cleaner handling of external binary programs.
Wed Dec 1 22:24:39 2010 UTC (9 years, 1 month ago) by fangfang
CVS Tags: rast_rel_2010_1206
Changes since 1.5: +18 -0 lines
SAS component
Thu Sep 16 23:54:56 2010 UTC (9 years, 4 months ago) by golsen
CVS Tags: rast_rel_2010_0928
Changes since 1.4: +13 -4 lines
Add more options for to automated optimization of the coeficient of
variation in proml.
Fri Aug 27 23:35:36 2010 UTC (9 years, 5 months ago) by golsen
Changes since 1.3: +44 -6 lines
Add routine to optimize the coeficient of variation (and tree) in proml.
Sat Aug 21 17:17:29 2010 UTC (9 years, 5 months ago) by golsen
CVS Tags: rast_rel_2010_0827
Changes since 1.2: +1448 -488 lines
Many changes and improvements.  Add SeedAware ness.
Sun Sep 6 22:38:32 2009 UTC (10 years, 4 months ago) by golsen
CVS Tags: rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526
Changes since 1.1: +471 -140 lines
Add and/or update routines to support bootstrapping and bootstrap consensus
trees.
Fix some undefined values revealed by -w flag.
Sun Feb 11 18:48:53 2007 UTC (12 years, 11 months ago) by golsen
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_release_2008_09_29
The start of a package to provide perl inferfaces into programs in
Felsenstein's PHYLIP package.  Current support is for proml, protdist
and neighbor.
