[Bio] / FigKernelPackages / gjoparseblast.pm Repository:
Log of /FigKernelPackages/gjoparseblast.pm
Wed Aug 18 19:43:04 2010 UTC (9 years, 6 months ago) by golsen
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928
Fix two minor typographical errors in the documentation.
Fri Dec 18 19:32:15 2009 UTC (10 years, 2 months ago) by overbeek
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526
Changes since 1.6: +3 -0 lines
add as SAS components
Sat Apr 11 15:11:27 2009 UTC (10 years, 10 months ago) by golsen
CVS Tags: rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925
Changes since 1.5: +15 -13 lines
Fix to bug that caused failure in reading alignments with an entire row
of gaps.
Sun Mar 1 21:06:10 2009 UTC (10 years, 11 months ago) by overbeek
CVS Tags: rast_rel_2009_03_26
fix unitialized variable
Thu Feb 5 14:50:43 2009 UTC (11 years ago) by overbeek
Changes since 1.3: +49 -7 lines
fixes to support search for rRNAs
Sat Oct 25 18:14:45 2008 UTC (11 years, 3 months ago) by overbeek
CVS Tags: mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05
updates from Gary
Thu Mar 2 22:31:45 2006 UTC (13 years, 11 months ago) by golsen
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_release_2008_09_29
Bug fix in parse error message (blast outputs invalid query and database
sizes for unknown reasons, and this reports it).
Wed Jan 4 19:32:00 2006 UTC (14 years, 1 month ago) by golsen
Add a page for proposing a new PEG.  This is not complete, and the 'create'
button is currently functionless, but it is worth some feedback as to the
direction it is headed.
The page is linked from the graphical display of tblastn output in index.cgi
(click on the "Q" object in the figure) (intentionally obscure for now).
Add a new blast output parsing perl package.  This can read from a file,
a pipe or a text array of lines (D=STDIN).  It can collect all output
(possibly memory intensive), or it can deliver quanta of output by being
called repeatedly with the same HANDLE or ARRAY (which can be made very
memory light).  It maintains separate state information for each input,
so multiple open streams works (silly me).  [Note that this is for full
text output, not the tabular output.  The alignments are also returned.
If you don't want them, slice-up the output with map{}.  You also get
useful information such as query and subject definitions (not just ids),
and their lengths.  There are huge quantities of description in the file.
It should work with all recent versions of blastall, and all -p options,
with the possible exception of tblastx, but it might work on that too.]
This package is intended to replace, and extend, all of the functionality
previously achieved by piping output through the rationalize_blast script.
Because it no longer requires the script, the shell invocation is no
longer required.  And this works with pipes opened with '-|', so ....
It is currently used in index.cgi and propose_new_peg.cgi.
