[Bio] / FigKernelPackages / gjonewicklib.pm Repository:
Log of /FigKernelPackages/gjonewicklib.pm
Sat Mar 29 05:18:19 2008 UTC (11 years, 8 months ago) by golsen
Changes since 1.10: +21 -6 lines
Allow matched [ ... ] inside Newick tree comment.  This violates the standard,
but allows much more flexibility.  It is consistent with the treatment in
programs like PAUP*.
Mon Apr 9 21:00:24 2007 UTC (12 years, 8 months ago) by golsen
Major change in the alignment and tree portions of fid_checked.
Nicer alignment display.
Clean-up of tree display and underlying libraries.
Caching of the alignment and tree so that display paramters and/or
assignments can be updated without recomputing the alignment and tree.
Sun Feb 11 18:55:44 2007 UTC (12 years, 10 months ago) by golsen
Changes since 1.8: +545 -72 lines
Added much support for adding sequences to trees.  In particular, the
ability to extract a representative tree defined by the lineages that
originate near a tip, or the current root of the tree.  Also, rerooting
to a point on the branches between 2 nodes (which do not need to be
adjacent).
Sun Feb 11 18:25:48 2007 UTC (12 years, 10 months ago) by golsen
Changes since 1.7: +319 -16 lines
New functions for making big trees.
Fri Jan 12 23:45:29 2007 UTC (12 years, 11 months ago) by overbeek
Changes since 1.6: +188 -34 lines
new versions of gjo packages
Tue Dec 19 18:01:14 2006 UTC (12 years, 11 months ago) by golsen
Bug fix in passing a file handle reference to printer_plot_newick.
Tue Dec 19 17:32:48 2006 UTC (12 years, 11 months ago) by golsen
Changes since 1.4: +182 -10 lines
Add a few new routines to gjonewicklib.pm
Fri Dec 15 00:09:52 2006 UTC (13 years ago) by overbeek
Changes since 1.3: +10 -10 lines
add ability to insert sequences into a tree
Tue Jan 3 19:50:32 2006 UTC (13 years, 11 months ago) by overbeek
Changes since 1.2: +6 -1 lines
RAE: Correcting division by zero error
Added license words.
Wed Nov 30 08:44:26 2005 UTC (14 years ago) by golsen
Introduce a different tree printing routine to fid_checked.  This required
a new version of align_with_clustal.pl (= align_with_clustal_2.pl) and a
new tree utilities library (gjonewicklib.pm).
The new tree printer does not require deleting the extra lines (they are
not included in the first place).  This would probably allow some other
restructuring of the code in fid_checked, but I did the minimum.
The other reason for the changes (actually the real reason) is that it is
now possible to introduce midpoint rooting to the tree, and to reorder
the taxa so that the tree is MUCH easier to read (aesthetic tree order).
Also I'm changing it to use a second-generation tree from the alignment,
not just show the guide tree.
