[Bio] / FigKernelPackages / gjonewicklib.pm Repository:
Log of /FigKernelPackages/gjonewicklib.pm
Sun Oct 3 23:03:57 2010 UTC (9 years, 2 months ago) by golsen
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, myrast_33, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.24: +1 -2 lines
Diff to previous 1.24
Change behavior of reroot_tree() to ignore distance if there is only one
node.
Sat Oct 2 00:01:10 2010 UTC (9 years, 2 months ago) by golsen
Changes since 1.23: +753 -286 lines
Diff to previous 1.23
Added reroot_tree() and several functions to support it.
General code clean-up and efficiency modifications.
Sat Sep 18 20:10:10 2010 UTC (9 years, 2 months ago) by golsen
CVS Tags: rast_rel_2010_0928
Changes since 1.22: +18 -4 lines
Diff to previous 1.22
Fix descriptions of read_tree and read_trees.
Fri Aug 27 23:34:33 2010 UTC (9 years, 3 months ago) by golsen
Changes since 1.21: +187 -0 lines
Diff to previous 1.21
Add routines to make random trees:
  random_equibranch_tree
  random_ultrametric_tree
Sat Aug 21 17:12:51 2010 UTC (9 years, 3 months ago) by golsen
CVS Tags: rast_rel_2010_0827
Changes since 1.20: +15 -17 lines
Diff to previous 1.20
Handle a few more bad conditions in a graceful manner.
Sat Aug 14 23:58:51 2010 UTC (9 years, 3 months ago) by golsen
Changes since 1.19: +44 -2 lines
Diff to previous 1.19
Add routine to produce a standard "name" for a tree, allowing direct
comparision for same topology.
Tue Apr 13 20:33:16 2010 UTC (9 years, 7 months ago) by golsen
CVS Tags: rast_rel_2010_0526
Changes since 1.18: +1 -2 lines
Diff to previous 1.18
Fixed bug introduced yesterday (a spurious newline).
Mon Apr 12 20:27:23 2010 UTC (9 years, 7 months ago) by fangfang
Changes since 1.17: +2 -1 lines
Diff to previous 1.17
fixed a small bug in representative_for_profile()
Tue Nov 24 21:22:46 2009 UTC (10 years ago) by olson
CVS Tags: rast_rel_2010_0118
Changes since 1.16: +2 -0 lines
Diff to previous 1.16
Add more modules to the SAS toolkit.
Tue Sep 8 01:59:24 2009 UTC (10 years, 3 months ago) by golsen
CVS Tags: rast_rel_2009_0925
Changes since 1.15: +38 -13 lines
Add ability to put internal node labels in printer plot trees.
(requires dy >= 2).
Reworked the details of subtree order in aesthetic_newick_tree(). It now
looks better in the case of mulitfurcations.
Sun Sep 6 22:38:32 2009 UTC (10 years, 3 months ago) by golsen
Changes since 1.14: +29 -1 lines
Add and/or update routines to support bootstrapping and bootstrap consensus
trees.
Fix some undefined values revealed by -w flag.
Tue Jul 7 22:14:22 2009 UTC (10 years, 5 months ago) by golsen
CVS Tags: rast_rel_2009_07_09
Changes since 1.13: +188 -181 lines
Improved tree printer-plot graphics. Total redesign.
Wed Jul 1 00:08:52 2009 UTC (10 years, 5 months ago) by golsen
Changes since 1.12: +315 -58 lines
Modifications to support line-drawing character set in tree printer plots.
Mon Jun 22 19:14:50 2009 UTC (10 years, 5 months ago) by golsen
Changes since 1.11: +200 -47 lines
Add functions for midpoint rooting of tree in branch.  Add some additional
error checking on trees.
Sat Mar 29 05:18:19 2008 UTC (11 years, 8 months ago) by golsen
Changes since 1.10: +21 -6 lines
Allow matched [ ... ] inside Newick tree comment.  This violates the standard,
but allows much more flexibility.  It is consistent with the treatment in
programs like PAUP*.
Mon Apr 9 21:00:24 2007 UTC (12 years, 8 months ago) by golsen
Major change in the alignment and tree portions of fid_checked.
Nicer alignment display.
Clean-up of tree display and underlying libraries.
Caching of the alignment and tree so that display paramters and/or
assignments can be updated without recomputing the alignment and tree.
Sun Feb 11 18:55:44 2007 UTC (12 years, 10 months ago) by golsen
Changes since 1.8: +545 -72 lines
Added much support for adding sequences to trees.  In particular, the
ability to extract a representative tree defined by the lineages that
originate near a tip, or the current root of the tree.  Also, rerooting
to a point on the branches between 2 nodes (which do not need to be
adjacent).
Sun Feb 11 18:25:48 2007 UTC (12 years, 10 months ago) by golsen
Changes since 1.7: +319 -16 lines
New functions for making big trees.
Fri Jan 12 23:45:29 2007 UTC (12 years, 10 months ago) by overbeek
Changes since 1.6: +188 -34 lines
new versions of gjo packages
Tue Dec 19 18:01:14 2006 UTC (12 years, 11 months ago) by golsen
Bug fix in passing a file handle reference to printer_plot_newick.
Tue Dec 19 17:32:48 2006 UTC (12 years, 11 months ago) by golsen
Changes since 1.4: +182 -10 lines
Add a few new routines to gjonewicklib.pm
Fri Dec 15 00:09:52 2006 UTC (12 years, 11 months ago) by overbeek
Changes since 1.3: +10 -10 lines
add ability to insert sequences into a tree
Tue Jan 3 19:50:32 2006 UTC (13 years, 11 months ago) by overbeek
Changes since 1.2: +6 -1 lines
RAE: Correcting division by zero error
Added license words.
Wed Nov 30 08:44:26 2005 UTC (14 years ago) by golsen
Introduce a different tree printing routine to fid_checked.  This required
a new version of align_with_clustal.pl (= align_with_clustal_2.pl) and a
new tree utilities library (gjonewicklib.pm).
The new tree printer does not require deleting the extra lines (they are
not included in the first place).  This would probably allow some other
restructuring of the code in fid_checked, but I did the minimum.
The other reason for the changes (actually the real reason) is that it is
now possible to introduce midpoint rooting to the tree, and to reorder
the taxa so that the tree is MUCH easier to read (aesthetic tree order).
Also I'm changing it to use a second-generation tree from the alignment,
not just show the guide tree.
