[Bio] / FigKernelPackages / gjocolorlib.pm Repository:
Log of /FigKernelPackages/gjocolorlib.pm
Fri Sep 17 23:59:35 2010 UTC (9 years, 6 months ago) by overbeek
CVS Tags: rast_rel_2010_0928, rast_rel_2010_1206
fixes to gray
Fri Sep 17 23:53:15 2010 UTC (9 years, 6 months ago) by overbeek
gary to gray
Fri Sep 17 23:50:54 2010 UTC (9 years, 6 months ago) by golsen
Changes since 1.3: +12 -0 lines
Add gray2html
Tue Jun 23 02:33:46 2009 UTC (10 years, 9 months ago) by golsen
CVS Tags: rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827
Changes since 1.2: +381 -1 lines
Added more named colors from X11, but these are almost certainly based on a
different assumption about gamma.
Tue Jun 23 01:53:37 2009 UTC (10 years, 9 months ago) by golsen
Fix a typo in a color name.
Sun Apr 8 21:36:16 2007 UTC (13 years ago) by overbeek
Diff to selected 1.5
add Gary's compare genome stuff
