[Bio] / FigKernelPackages / gjocolorlib.pm Repository:
Log of /FigKernelPackages/gjocolorlib.pm
Links to rast_rel_2009_07_09: (view) (download) (as text) (annotate)
Tue Jun 23 02:33:46 2009 UTC (10 years, 9 months ago) by golsen
CVS Tags: rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827
Changes since 1.2: +381 -1 lines
Added more named colors from X11, but these are almost certainly based on a
different assumption about gamma.
Tue Jun 23 01:53:37 2009 UTC (10 years, 9 months ago) by golsen
Fix a typo in a color name.
Sun Apr 8 21:36:16 2007 UTC (13 years ago) by overbeek
add Gary's compare genome stuff
