[Bio] / FigKernelPackages / gjocolorlib.pm Repository:
Log of /FigKernelPackages/gjocolorlib.pm
Mon Dec 6 20:10:13 2010 UTC (9 years, 3 months ago) by golsen
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.6: +839 -866 lines
Added support for luma (HSY color definitions).
Changed all code so that html colors are sRGB.
Added support for a few specific values of gamma.
Revised WWW and SVG defined colors.
Revised much of the code.
Fri Sep 17 23:59:35 2010 UTC (9 years, 6 months ago) by overbeek
CVS Tags: rast_rel_2010_0928, rast_rel_2010_1206
fixes to gray
Fri Sep 17 23:53:15 2010 UTC (9 years, 6 months ago) by overbeek
gary to gray
Fri Sep 17 23:50:54 2010 UTC (9 years, 6 months ago) by golsen
Changes since 1.3: +12 -0 lines
Add gray2html
Tue Jun 23 02:33:46 2009 UTC (10 years, 9 months ago) by golsen
CVS Tags: rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827
Changes since 1.2: +381 -1 lines
Added more named colors from X11, but these are almost certainly based on a
different assumption about gamma.
Tue Jun 23 01:53:37 2009 UTC (10 years, 9 months ago) by golsen
Fix a typo in a color name.
Sun Apr 8 21:36:16 2007 UTC (12 years, 11 months ago) by overbeek
add Gary's compare genome stuff
