[Bio] / FigKernelPackages / gjoalignment.pm Repository:
Log of /FigKernelPackages/gjoalignment.pm
Sat Sep 18 16:26:24 2010 UTC (9 years, 5 months ago) by fangfang
CVS Tags: rast_rel_2010_0928
Changes since 1.32: +189 -0 lines
Diff to previous 1.32
Added align_with_mafft
Thu Sep 16 23:52:37 2010 UTC (9 years, 5 months ago) by golsen
Changes since 1.31: +30 -25 lines
Diff to previous 1.31
Fix the trim code.
Numerous small changes, including better clean-up of temp files.
Wed Sep 8 21:04:19 2010 UTC (9 years, 5 months ago) by golsen
Changes since 1.30: +146 -21 lines
Diff to previous 1.30
Work around a clustalw bug in profile alignment at inserts columns of
gaps into an alignment.
Add a clustal_profile_alignment() function.
Sun Aug 29 22:13:28 2010 UTC (9 years, 5 months ago) by golsen
Changes since 1.29: +240 -98 lines
Diff to previous 1.29
Much code clean-up and consolidation.
New version of add to alignment that does much better gap placement.
Sat Aug 21 17:21:11 2010 UTC (9 years, 6 months ago) by golsen
CVS Tags: rast_rel_2010_0827
Changes since 1.28: +173 -197 lines
Diff to previous 1.28
Many changes and improvements.  Fixed major add_to_alignment_v2 bug.
Now SeedAware.
Fri Dec 18 20:12:30 2009 UTC (10 years, 2 months ago) by overbeek
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526
Changes since 1.27: +1 -0 lines
Diff to previous 1.27
mark as SAS component
Sun Sep 6 22:38:32 2009 UTC (10 years, 5 months ago) by golsen
CVS Tags: rast_rel_2009_0925
Changes since 1.26: +60 -10 lines
Diff to previous 1.26
Add and/or update routines to support bootstrapping and bootstrap consensus
trees.
Fix some undefined values revealed by -w flag.
Tue Jun 30 21:36:42 2009 UTC (10 years, 7 months ago) by golsen
CVS Tags: rast_rel_2009_07_09
Changes since 1.25: +15 -19 lines
Diff to previous 1.25
Changes mostly in add_to_alignment.
Fri Jun 26 00:06:26 2009 UTC (10 years, 7 months ago) by golsen
Changes since 1.24: +1 -1 lines
Diff to previous 1.24
New super duper ala Peter T. Hooper paralog resolution interface.
Tue Jun 23 23:27:09 2009 UTC (10 years, 7 months ago) by golsen
Changes since 1.23: +215 -78 lines
Diff to previous 1.23
Add options to muscle, and set clustalw up for the same (though that is
not done yet).
Mon Jun 22 19:39:43 2009 UTC (10 years, 8 months ago) by overbeek
Diff to previous 1.22
fix mispelling
Mon Jun 22 19:35:59 2009 UTC (10 years, 8 months ago) by overbeek
Changes since 1.21: +31 -0 lines
Diff to previous 1.21
added stuff
Mon Jun 22 18:41:05 2009 UTC (10 years, 8 months ago) by golsen
Changes since 1.20: +25 -9 lines
Diff to previous 1.20
Fix trimming in add_to_alignment_v2.
Mon Jun 22 18:24:13 2009 UTC (10 years, 8 months ago) by golsen
Changes since 1.19: +311 -78 lines
Diff to previous 1.19
Add function add_to_alignment_v2().
Mon Apr 13 21:25:43 2009 UTC (10 years, 10 months ago) by golsen
CVS Tags: rast_rel_2009_05_18
Changes since 1.18: +15 -11 lines
Diff to previous 1.18
Slight clean-up of code.
Thu Jan 29 20:24:13 2009 UTC (11 years ago) by overbeek
Diff to previous 1.17
additions to support partitioning of sims
Thu Oct 30 04:54:38 2008 UTC (11 years, 3 months ago) by golsen
Changes since 1.16: +3 -3 lines
Diff to previous 1.16
Fixed a bug introduced into align_with_clustal() that caused it to return
[ id, seq ] pairs, rather than [ id, definition, seq ] in certain
circumstances.
Sat Oct 25 18:14:45 2008 UTC (11 years, 3 months ago) by overbeek
Changes since 1.15: +32 -7 lines
updates from Gary
Thu Aug 14 17:21:53 2008 UTC (11 years, 6 months ago) by golsen
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, rast_2008_0924, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_release_2008_09_29
Changes since 1.14: +15 -12 lines
Fix FIG dependencies so that it is FIG-aware, but not FIG-dependent.
Sat May 12 20:12:56 2007 UTC (12 years, 9 months ago) by overbeek
CVS Tags: rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07
Changes since 1.13: +5 -2 lines
add utilities for computing alignments
Tue Apr 10 03:49:06 2007 UTC (12 years, 10 months ago) by parrello
Fixed some compiler warnings.
Mon Apr 9 21:00:24 2007 UTC (12 years, 10 months ago) by golsen
Changes since 1.11: +3 -1 lines
Major change in the alignment and tree portions of fid_checked.
Nicer alignment display.
Clean-up of tree display and underlying libraries.
Caching of the alignment and tree so that display paramters and/or
assignments can be updated without recomputing the alignment and tree.
Mon Apr 9 00:39:43 2007 UTC (12 years, 10 months ago) by golsen
Changes since 1.10: +87 -12 lines
Add an align_with_clustal function to the module.
Sun Mar 18 17:25:19 2007 UTC (12 years, 11 months ago) by overbeek
add filter_figfams.pl
Sat Feb 24 01:33:07 2007 UTC (12 years, 11 months ago) by overbeek
Changes since 1.8: +31 -2 lines
fix to retrimming alignments
Wed Feb 21 17:05:18 2007 UTC (13 years ago) by overbeek
Changes since 1.7: +3 -0 lines
current versions of FigFam.pm
Sun Feb 11 22:37:11 2007 UTC (13 years ago) by overbeek
add PHOB.pm to support some phylogeny stuff
Wed Dec 20 20:43:54 2006 UTC (13 years, 2 months ago) by overbeek
Changes since 1.5: +9 -5 lines
bug fixes in adding to an alignment -- trimming was lost
Tue Dec 19 18:35:08 2006 UTC (13 years, 2 months ago) by golsen
Changes since 1.4: +15 -9 lines
Add more flexible interface for files: handle, name or default.
Fri Dec 15 00:09:52 2006 UTC (13 years, 2 months ago) by overbeek
Changes since 1.3: +60 -1 lines
add ability to insert sequences into a tree
Thu Dec 29 19:28:11 2005 UTC (14 years, 1 month ago) by golsen
Changes since 1.2: +16 -8 lines
Make attempt to add a duplicate id nonfatal.  Having the program die
in the middle of a large number of adds is annoying.
Increase flexibility on return data type (array or reference to array)
in the function library.
Make the calls by reference in the program.
Added license words.
Tue Jun 7 02:16:00 2005 UTC (14 years, 8 months ago) by golsen
Add a module with some routines for adding sequences to alignments.
