[Bio] / FigKernelPackages / gjoalignandtree.pm Repository:
Log of /FigKernelPackages/gjoalignandtree.pm
Thu Nov 18 22:39:56 2010 UTC (9 years ago) by fangfang
CVS Tags: rast_rel_2010_1206
Diff to previous 1.6 , to selected 1.1
change to verify_db
Thu Nov 11 06:34:10 2010 UTC (9 years ago) by fangfang
correct arg sequence in extract_with_psiblast
Mon Nov 8 20:26:00 2010 UTC (9 years ago) by fangfang
Changes since 1.4: +14 -11 lines
add fract_cov option for trim_align_to_median_ends
Mon Nov 8 19:49:39 2010 UTC (9 years ago) by fangfang
handle the case in which all candidates have either start or end gaps in representative_for_profile
Sat Aug 21 17:43:32 2010 UTC (9 years, 3 months ago) by golsen
Changes since 1.2: +321 -45 lines
Updates and bug fixes.
Mon Apr 12 20:27:23 2010 UTC (9 years, 7 months ago) by fangfang
CVS Tags: rast_rel_2010_0526
fixed a small bug in representative_for_profile()
Mon Mar 8 21:43:51 2010 UTC (9 years, 9 months ago) by overbeek
support for alignments and trees
