[Bio] / FigKernelPackages / gjoalignandtree.pm Repository:
Log of /FigKernelPackages/gjoalignandtree.pm
Sat Feb 19 17:51:25 2011 UTC (9 years ago) by golsen
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, myrast_33, myrast_rel40
Changes since 1.15: +4 -3 lines
Minor consistency improvements in options, and remove redundancy in getting
the query (write to file, then read from the file).
Wed Feb 16 22:42:49 2011 UTC (9 years ago) by fangfang
Changes since 1.14: +6 -4 lines
more flexibility for option n_thread in extract_with_psiblast
Wed Dec 29 22:24:17 2010 UTC (9 years, 1 month ago) by fangfang
CVS Tags: rast_rel_2011_0119
Changes since 1.13: +5 -6 lines
update options
Wed Dec 29 21:50:32 2010 UTC (9 years, 1 month ago) by fangfang
Changes since 1.12: +16 -4 lines
update the report hash extract_with_psiblast returns
Mon Dec 27 00:17:33 2010 UTC (9 years, 1 month ago) by fangfang
update
Mon Dec 27 00:04:35 2010 UTC (9 years, 1 month ago) by fangfang
Changes since 1.10: +8 -7 lines
update default options
Sun Dec 26 21:48:56 2010 UTC (9 years, 1 month ago) by fangfang
Changes since 1.9: +12 -6 lines
add options for min fraction coverage for extract_with_psiblast
Tue Dec 7 00:36:46 2010 UTC (9 years, 2 months ago) by golsen
Changes since 1.8: +10 -2 lines
Cleaner handling of external binary programs.
Mon Dec 6 19:55:51 2010 UTC (9 years, 2 months ago) by golsen
Changes since 1.7: +303 -33 lines
Many minor changes and improvements.
Major improvements in blastpgpn().
Thu Nov 18 22:39:56 2010 UTC (9 years, 3 months ago) by fangfang
CVS Tags: rast_rel_2010_1206
change to verify_db
Thu Nov 11 06:34:10 2010 UTC (9 years, 3 months ago) by fangfang
correct arg sequence in extract_with_psiblast
Mon Nov 8 20:26:00 2010 UTC (9 years, 3 months ago) by fangfang
Changes since 1.4: +14 -11 lines
add fract_cov option for trim_align_to_median_ends
Mon Nov 8 19:49:39 2010 UTC (9 years, 3 months ago) by fangfang
handle the case in which all candidates have either start or end gaps in representative_for_profile
Sat Aug 21 17:43:32 2010 UTC (9 years, 6 months ago) by golsen
Changes since 1.2: +321 -45 lines
Updates and bug fixes.
Mon Apr 12 20:27:23 2010 UTC (9 years, 10 months ago) by fangfang
CVS Tags: rast_rel_2010_0526
fixed a small bug in representative_for_profile()
Mon Mar 8 21:43:51 2010 UTC (9 years, 11 months ago) by overbeek
support for alignments and trees
