[Bio] / FigKernelPackages / gjoalign2html.pm Repository:
Log of /FigKernelPackages/gjoalign2html.pm
Wed Dec 1 22:24:14 2010 UTC (9 years, 1 month ago) by fangfang
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, myrast_33, myrast_rel40, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.4: +18 -0 lines
SAS component
Tue Aug 25 23:52:44 2009 UTC (10 years, 4 months ago) by golsen
CVS Tags: rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928
Changes since 1.3: +90 -85 lines
Fix problem with line wrap in the alignment.
Change all #abc colors to #aabbcc for browser compatibility.
Thu Jun 25 01:19:29 2009 UTC (10 years, 6 months ago) by golsen
CVS Tags: rast_rel_2009_07_09
Changes since 1.2: +16 -8 lines
Add PNG format trees to fid_checked.cgi.  Add support elsewhere.  Some
code clean-up.  Some increases in flexibility.
Mon Apr 9 21:00:24 2007 UTC (12 years, 9 months ago) by golsen
Changes since 1.1: +132 -3 lines
Major change in the alignment and tree portions of fid_checked.
Nicer alignment display.
Clean-up of tree display and underlying libraries.
Caching of the alignment and tree so that display paramters and/or
assignments can be updated without recomputing the alignment and tree.
Wed Feb 21 18:15:51 2007 UTC (12 years, 10 months ago) by golsen
A package for displaying alignments in html.  Includes functions for
colorering by residue, coloring by consensus, appending unaligned
residues to a trimmed alignment, and more.
