[Bio] / FigKernelPackages / gjoalign2html.pm Repository:
Log of /FigKernelPackages/gjoalign2html.pm
Links to mgrast_rel_2008_0806: (view) (download) (as text) (annotate)
Mon Apr 9 21:00:24 2007 UTC (12 years, 8 months ago) by golsen
Changes since 1.1: +132 -3 lines
Major change in the alignment and tree portions of fid_checked.
Nicer alignment display.
Clean-up of tree display and underlying libraries.
Caching of the alignment and tree so that display paramters and/or
assignments can be updated without recomputing the alignment and tree.
Wed Feb 21 18:15:51 2007 UTC (12 years, 9 months ago) by golsen
A package for displaying alignments in html.  Includes functions for
colorering by residue, coloring by consensus, appending unaligned
residues to a trimmed alignment, and more.
