[Bio] / FigKernelPackages / ffxtree.pm Repository:
Log of /FigKernelPackages/ffxtree.pm
Wed Dec 1 22:46:06 2010 UTC (8 years, 11 months ago) by fangfang
CVS Tags: rast_rel_2010_1206
Changes since 1.9: +17 -2 lines
update sas component
Wed Dec 1 22:45:39 2010 UTC (8 years, 11 months ago) by fangfang
removed dependency on gd_tree
Sat Nov 27 22:25:07 2010 UTC (8 years, 11 months ago) by fangfang
Changes since 1.7: +68 -0 lines
add make_cohesion_groups
Sat Nov 27 21:00:21 2010 UTC (8 years, 11 months ago) by fangfang
bug fix
Sat Nov 27 20:48:09 2010 UTC (8 years, 11 months ago) by fangfang
Changes since 1.5: +20 -2 lines
update option for showing branch support values
Sat Nov 27 05:06:35 2010 UTC (8 years, 11 months ago) by fangfang
highlight set of tips specified in $opts->{bold_set}
Sat Nov 27 01:10:30 2010 UTC (8 years, 11 months ago) by fangfang
Changes since 1.3: +4 -1 lines
update comment
Sat Nov 27 01:06:46 2010 UTC (8 years, 11 months ago) by fangfang
bug fix in likelihood evaluation
Sat Nov 27 00:25:26 2010 UTC (8 years, 11 months ago) by fangfang
Changes since 1.1: +1259 -349 lines
add tree_to_html
Wed Nov 17 19:48:01 2010 UTC (9 years ago) by fangfang
tree support
