[Bio] / FigKernelPackages / ffxtree.pm Repository:
Log of /FigKernelPackages/ffxtree.pm
Mon Mar 21 05:56:19 2011 UTC (8 years, 11 months ago) by fangfang
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_release_3_0_3, myrast_33
Changes since 1.22: +8 -6 lines
Diff to previous 1.22
replace newick_subtree with rooted_newick_subtree
Fri Mar 18 16:27:57 2011 UTC (8 years, 11 months ago) by fangfang
Changes since 1.21: +5 -5 lines
Diff to previous 1.21
parallel bootstrap support for phyml and raxml
Fri Mar 18 16:17:56 2011 UTC (8 years, 11 months ago) by fangfang
Changes since 1.20: +4 -4 lines
Diff to previous 1.20
differentiating temp file names for parallel support
Wed Mar 9 17:34:50 2011 UTC (8 years, 11 months ago) by fangfang
CVS Tags: mgrast_release_3_0_1, mgrast_release_3_0_2
Changes since 1.19: +11 -17 lines
Diff to previous 1.19
improved performance for distances_from_tip, 0.15s for trees with 4000 tips
Mon Mar 7 16:24:44 2011 UTC (8 years, 11 months ago) by fangfang
Changes since 1.18: +117 -3 lines
Diff to previous 1.18
add more options for cohension groups
add distances_from_tip
Fri Feb 25 14:30:54 2011 UTC (8 years, 11 months ago) by fangfang
Changes since 1.17: +6 -1 lines
Diff to previous 1.17
add more options for fasttree
Fri Feb 25 03:17:18 2011 UTC (8 years, 11 months ago) by fangfang
Changes since 1.16: +3 -3 lines
Diff to previous 1.16
fix bug in peg link
Fri Feb 25 02:44:33 2011 UTC (8 years, 11 months ago) by fangfang
Changes since 1.15: +4 -3 lines
add peg link for pubseed
Sun Feb 6 07:53:15 2011 UTC (9 years ago) by fangfang
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011
Changes since 1.14: +5 -2 lines
update tree_to_html
Tue Feb 1 03:56:44 2011 UTC (9 years ago) by fangfang
Changes since 1.13: +195 -25 lines
add option for inserting linked text for tree tips
Wed Dec 29 21:50:04 2010 UTC (9 years, 1 month ago) by fangfang
CVS Tags: rast_rel_2011_0119
Changes since 1.12: +3 -0 lines
update
Mon Dec 27 00:05:36 2010 UTC (9 years, 1 month ago) by fangfang
switch to fasta format for fasttree
Mon Dec 13 22:04:54 2010 UTC (9 years, 2 months ago) by fangfang
Changes since 1.10: +15 -9 lines
bug fix for dna alignment
Wed Dec 1 22:46:06 2010 UTC (9 years, 2 months ago) by fangfang
CVS Tags: rast_rel_2010_1206
Changes since 1.9: +17 -2 lines
update sas component
Wed Dec 1 22:45:39 2010 UTC (9 years, 2 months ago) by fangfang
removed dependency on gd_tree
Sat Nov 27 22:25:07 2010 UTC (9 years, 2 months ago) by fangfang
Changes since 1.7: +68 -0 lines
add make_cohesion_groups
Sat Nov 27 21:00:21 2010 UTC (9 years, 2 months ago) by fangfang
bug fix
Sat Nov 27 20:48:09 2010 UTC (9 years, 2 months ago) by fangfang
Changes since 1.5: +20 -2 lines
update option for showing branch support values
Sat Nov 27 05:06:35 2010 UTC (9 years, 2 months ago) by fangfang
highlight set of tips specified in $opts->{bold_set}
Sat Nov 27 01:10:30 2010 UTC (9 years, 2 months ago) by fangfang
Changes since 1.3: +4 -1 lines
update comment
Sat Nov 27 01:06:46 2010 UTC (9 years, 2 months ago) by fangfang
bug fix in likelihood evaluation
Sat Nov 27 00:25:26 2010 UTC (9 years, 2 months ago) by fangfang
Changes since 1.1: +1259 -349 lines
add tree_to_html
Wed Nov 17 19:48:01 2010 UTC (9 years, 3 months ago) by fangfang
tree support
