[Bio] / FigKernelPackages / clustaltree.pm Repository:
Log of /FigKernelPackages/clustaltree.pm
Fri Jun 26 00:06:26 2009 UTC (10 years, 9 months ago) by golsen
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
New super duper ala Peter T. Hooper paralog resolution interface.
Thu Jun 25 01:19:29 2009 UTC (10 years, 9 months ago) by golsen
Changes since 1.1: +31 -11 lines
Add PNG format trees to fid_checked.cgi.  Add support elsewhere.  Some
code clean-up.  Some increases in flexibility.
Mon Apr 9 21:51:56 2007 UTC (12 years, 11 months ago) by golsen
A rudimentary package to make a clustalw tree.  The intent is to put the
command line scripts align_with_clustal.pl and align_with_clustal_2.pl
into a package.
