[Bio] / FigKernelPackages / WikiTools.pm Repository:
Log of /FigKernelPackages/WikiTools.pm
Fri Jul 11 01:00:54 2008 UTC (11 years, 7 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_release_2008_09_29
Changes since 1.4: +8 -2 lines
Fixed table generator to remove line-feeds that would break the table.
Thu May 1 07:53:03 2008 UTC (11 years, 9 months ago) by parrello
CVS Tags: rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21
Changes since 1.3: +44 -1 lines
Added a method that loads a module from the Wiki CPAN stash.
Tue Apr 29 06:02:18 2008 UTC (11 years, 9 months ago) by parrello
Changes since 1.2: +1 -4 lines
Backed out bad idea of changing Tmpl to Template when Wikifying template names.
Sun Mar 23 15:49:54 2008 UTC (11 years, 11 months ago) by parrello
CVS Tags: rast_rel_2008_04_23
Changes since 1.1: +6 -2 lines
Fixed Table method to create a header row.
Tue Feb 5 02:24:28 2008 UTC (12 years ago) by parrello
Added to provide an interface to the new Wiki.
