[Bio] / FigKernelPackages / WikiTools.pm Repository:
Log of /FigKernelPackages/WikiTools.pm
Sun Mar 15 23:58:24 2009 UTC (10 years, 11 months ago) by parrello
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Fixed a glitch in list rendering.
Thu Feb 5 06:41:21 2009 UTC (11 years ago) by parrello
Changes since 1.6: +3 -1 lines
Changed to use new FIG_Config parameters for locating the WebAppBackend database.
Mon Jan 19 20:52:21 2009 UTC (11 years, 1 month ago) by parrello
CVS Tags: rast_rel_2009_02_05
Changes since 1.5: +338 -277 lines
Refactored so that other objects can be created to render output in different formats. Moved in a utility for creating Wiki-aware WebApplication objects.
Fri Jul 11 01:00:54 2008 UTC (11 years, 7 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_release_2008_09_29
Changes since 1.4: +8 -2 lines
Fixed table generator to remove line-feeds that would break the table.
Thu May 1 07:53:03 2008 UTC (11 years, 9 months ago) by parrello
CVS Tags: rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21
Changes since 1.3: +44 -1 lines
Added a method that loads a module from the Wiki CPAN stash.
Tue Apr 29 06:02:18 2008 UTC (11 years, 9 months ago) by parrello
Changes since 1.2: +1 -4 lines
Backed out bad idea of changing Tmpl to Template when Wikifying template names.
Sun Mar 23 15:49:54 2008 UTC (11 years, 11 months ago) by parrello
CVS Tags: rast_rel_2008_04_23
Changes since 1.1: +6 -2 lines
Fixed Table method to create a header row.
Tue Feb 5 02:24:28 2008 UTC (12 years ago) by parrello
Added to provide an interface to the new Wiki.
