[Bio] / FigKernelPackages / UserData.pm Repository:
Log of /FigKernelPackages/UserData.pm
Links to rast_rel_2008_09_29: (view) (download) (as text) (annotate)
Thu Dec 6 13:59:34 2007 UTC (12 years, 2 months ago) by parrello
Changes since 1.5: +19 -19 lines
Tue Feb 21 10:57:13 2006 UTC (14 years ago) by parrello
Changes since 1.4: +209 -204 lines
Reorganized the comments to make them easier to navigate.
Wed Dec 7 19:38:22 2005 UTC (14 years, 2 months ago) by golsen
Don't mean to be pedantic, but I figured that I might as well add newlines
at the end of text files that lack one.  Identified with a script:
/bin/sh -O extglob -c 'for f in */*.@(c|css|html|js|pl|pm|py|TXT); do perl -e '"'"'while(<>) {$s = ! /\n$/} exit $s'"'"' $f || echo $f; done'
fixed with a script:
/bin/sh
for file in _list_; do echo "" >> $file; done
Added license words.
Wed Nov 23 17:55:49 2005 UTC (14 years, 3 months ago) by parrello
Changes since 1.1: +248 -33 lines
Finished implementation.
Mon Nov 7 20:26:40 2005 UTC (14 years, 3 months ago) by parrello
CVS Tags: caBIG-00-00-00
Diff to selected 1.4
Added with documentation.
