Log of /FigKernelPackages/UserData.pm
Parent Directory
Revision
1.6 -
view)
download)
as text)
annotate)
[select for diffs]
Thu Dec 6 13:59:34 2007 UTC (12 years ago) by
parrello
Branch:
MAIN
CVS Tags:
HEAD,
mgrast_dev_02212011,
mgrast_dev_02222011,
mgrast_dev_03252011,
mgrast_dev_03312011,
mgrast_dev_04012011,
mgrast_dev_04052011,
mgrast_dev_04082011,
mgrast_dev_04132011,
mgrast_dev_05262011,
mgrast_dev_06072011,
mgrast_dev_08022011,
mgrast_dev_08112011,
mgrast_dev_10262011,
mgrast_dev_12152011,
mgrast_rel_2008_0625,
mgrast_rel_2008_0806,
mgrast_rel_2008_0917,
mgrast_rel_2008_0919,
mgrast_rel_2008_0923,
mgrast_rel_2008_0924,
mgrast_rel_2008_1110,
mgrast_rel_2008_1110_v2,
mgrast_release_3_0,
mgrast_release_3_0_1,
mgrast_release_3_0_2,
mgrast_release_3_0_3,
mgrast_release_3_0_4,
mgrast_release_3_1_0,
mgrast_release_3_1_1,
mgrast_release_3_1_2,
mgrast_version_3_2,
myrast_33,
myrast_rel40,
rast_2008_0924,
rast_rel_2008_04_23,
rast_rel_2008_06_16,
rast_rel_2008_06_18,
rast_rel_2008_07_21,
rast_rel_2008_08_07,
rast_rel_2008_09_29,
rast_rel_2008_09_30,
rast_rel_2008_10_09,
rast_rel_2008_10_29,
rast_rel_2008_11_24,
rast_rel_2008_12_18,
rast_rel_2009_02_05,
rast_rel_2009_03_26,
rast_rel_2009_05_18,
rast_rel_2009_07_09,
rast_rel_2009_0925,
rast_rel_2010_0118,
rast_rel_2010_0526,
rast_rel_2010_0827,
rast_rel_2010_0928,
rast_rel_2010_1206,
rast_rel_2011_0119,
rast_rel_2011_0928,
rast_rel_2014_0729,
rast_rel_2014_0912,
rast_release_2008_09_29
Changes since
1.5: +19 -19 lines
Diff to
previous 1.5
Revision
1.4 -
view)
download)
as text)
annotate)
[select for diffs]
Wed Dec 7 19:38:22 2005 UTC (14 years ago) by
golsen
Branch:
MAIN
CVS Tags:
caBIG-05Apr06-00,
caBIG-13Feb06-00
Changes since
1.3: +1 -1 lines
Diff to
previous 1.3
Don't mean to be pedantic, but I figured that I might as well add newlines
at the end of text files that lack one. Identified with a script:
/bin/sh -O extglob -c 'for f in */*.@(c|css|html|js|pl|pm|py|TXT); do perl -e '"'"'while(<>) {$s = ! /\n$/} exit $s'"'"' $f || echo $f; done'
fixed with a script:
/bin/sh
for file in _list_; do echo "" >> $file; done
This form allows you to request diffs between any two revisions of this file.
For each of the two "sides" of the diff,
select a symbolic revision name using the selection box, or choose
'Use Text Field' and enter a numeric revision.
