[Bio] / FigKernelPackages / UserDB.pm Repository:
Log of /FigKernelPackages/UserDB.pm
Mon Dec 5 19:06:30 2005 UTC (13 years, 11 months ago) by olson
Added license words.
Mon Jan 10 22:54:18 2005 UTC (14 years, 10 months ago) by olson
Simple user database. Initializes state from assignments and annotations existing in the database.
