[Bio] / FigKernelPackages / UserDB.pm Repository:
Log of /FigKernelPackages/UserDB.pm
Links to mgrast_dev_08112011: (view) (download) (as text) (annotate)
Mon Dec 5 19:06:30 2005 UTC (14 years, 4 months ago) by olson
Added license words.
Mon Jan 10 22:54:18 2005 UTC (15 years, 2 months ago) by olson
Simple user database. Initializes state from assignments and annotations existing in the database.
