[Bio] / FigKernelPackages / UserDB.pm Repository:
Log of /FigKernelPackages/UserDB.pm
Added license words.
Mon Jan 10 22:54:18 2005 UTC (15 years, 1 month ago) by olson
Simple user database. Initializes state from assignments and annotations existing in the database.
