[Bio] / FigKernelPackages / UnvSubsys.pm Repository:
Log of /FigKernelPackages/UnvSubsys.pm
Fri Mar 14 16:52:48 2008 UTC (11 years, 10 months ago) by paczian
Changes since 1.19: +1 -0 lines
Diff to previous 1.19
added missing "use HTML;"
Thu Dec 6 13:59:34 2007 UTC (12 years, 1 month ago) by parrello
Changes since 1.18: +29 -29 lines
Diff to previous 1.18
Wed Nov 29 15:19:19 2006 UTC (13 years, 2 months ago) by olson
Changes since 1.17: +7 -1 lines
Diff to previous 1.17
Rollup commit of 48hr changes.
Added add_virtual_genome to Subsystem.pm to support UnvSubsys doing
the right thing when handed a FIGV.
Added propagation of 48hr_job thru the various link generation scripts in order for protein.cgi/display_subsys.cgi
to properly show virtual genomes.
Fri Nov 3 15:53:51 2006 UTC (13 years, 2 months ago) by paarmann
Changes since 1.16: +31 -1 lines
Diff to previous 1.16
added get_ssa_pretty()
Tue Jan 31 04:09:13 2006 UTC (13 years, 11 months ago) by overbeek
Changes since 1.15: +1 -0 lines
fix of clustering
Changes since 1.14: +17 -0 lines
Added license words.
Mon Nov 28 22:41:16 2005 UTC (14 years, 2 months ago) by parrello
Changes since 1.13: +45 -1 lines
Added functions to handle subsystem diagrams.
Wed Oct 12 21:54:12 2005 UTC (14 years, 3 months ago) by olson
CVS Tags: caBIG-00-00-00
Changes since 1.12: +2 -3 lines
add missing argument to active_genomes
Wed Oct 12 02:47:56 2005 UTC (14 years, 3 months ago) by parrello
Changes since 1.11: +787 -189 lines
Upgraded documentation.
Converted to use Sprout as well as SEED.
Wed Sep 28 17:21:54 2005 UTC (14 years, 4 months ago) by overbeek
CVS Tags: caBIG-dataload-0
Changes since 1.10: +10 -6 lines
minor fix to display_subsys.cgi
Tue Sep 27 00:58:27 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.9: +3 -17 lines
fixes to HOPSS
Wed Sep 21 16:32:42 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.8: +13 -1 lines
fix bad bug in display_subsys
Tue Sep 20 16:58:48 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.7: +21 -2 lines
add ability to invoke display_subsys.cgi with colored pegs
Sun Sep 18 14:11:22 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.6: +62 -8 lines
fixes on showing subsystems
Sun Sep 18 01:20:28 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.5: +58 -4 lines
fixes to display_subsys.cgi
Thu Sep 15 14:33:49 2005 UTC (14 years, 4 months ago) by parrello
Changes since 1.4: +156 -156 lines
Converted tabs to spaces.
Mon Sep 12 20:45:51 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.3: +173 -3 lines
first real version of display_subsys.cgi
Mon Sep 12 14:53:13 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.2: +43 -1 lines
display_subsys.cgi that works
Mon Sep 12 02:39:37 2005 UTC (14 years, 4 months ago) by overbeek
Changes since 1.1: +94 -5 lines
commit incomplete, bug ridden display_subsys.cgi
Sun Sep 11 23:44:46 2005 UTC (14 years, 4 months ago) by overbeek
add UnvSubsys.pm
