[Bio] / FigKernelPackages / TransactionProcessor.pm Repository:
Log of /FigKernelPackages/TransactionProcessor.pm
Links to mgrast_rel_2008_0924: (view) (download) (as text) (annotate)
Thu Dec 6 13:59:34 2007 UTC (12 years ago) by parrello
Changes since 1.5: +21 -21 lines
Added license words.
Thu Aug 11 23:35:08 2005 UTC (14 years, 4 months ago) by parrello
Changes since 1.3: +24 -0 lines
Added a method for creating statistic categories.
Thu Aug 11 03:59:52 2005 UTC (14 years, 4 months ago) by parrello
Fixed a counter glitch.
Thu Aug 11 03:56:07 2005 UTC (14 years, 4 months ago) by parrello
Fixed an unintentional infinite recursive loop.
Thu Aug 11 03:09:41 2005 UTC (14 years, 4 months ago) by parrello
Converted the transaction processor to an object-oriented module in order to simplify the task of programming the ever-growing number of scripts that use them.
