[Bio] / FigKernelPackages / Tracer.pm Repository:
Log of /FigKernelPackages/Tracer.pm
Links to caBIG-00-00-00: (view) (download) (as text) (annotate)
Tue Oct 18 17:42:48 2005 UTC (14 years, 3 months ago) by parrello
CVS Tags: caBIG-00-00-00
Changes since 1.27: +18 -10 lines
Diff to previous 1.27 , to selected 1.8
Changed to delete CRs instead of escaping them.
Sat Oct 15 07:57:10 2005 UTC (14 years, 3 months ago) by parrello
Changes since 1.26: +8 -7 lines
Diff to previous 1.26 , to selected 1.8
Enhanced escaping mechanism to convert CRs as well as LFs.
Wed Sep 14 13:09:53 2005 UTC (14 years, 4 months ago) by parrello
CVS Tags: caBIG-dataload-0
Changes since 1.25: +0 -1 lines
Diff to previous 1.25 , to selected 1.8
Removed an annoying trace message.
Tue Sep 13 20:04:25 2005 UTC (14 years, 4 months ago) by parrello
Changes since 1.24: +11 -11 lines
Diff to previous 1.24 , to selected 1.8
Fixed the problem with escaping that was creating backspaces in the Sprout data.
Tue Sep 13 05:39:07 2005 UTC (14 years, 4 months ago) by parrello
Diff to previous 1.23 , to selected 1.8
Tue Sep 13 05:36:12 2005 UTC (14 years, 4 months ago) by parrello
Changes since 1.22: +1 -0 lines
Diff to previous 1.22 , to selected 1.8
Added tracing to UnEscape.
Thu Sep 1 09:35:03 2005 UTC (14 years, 4 months ago) by parrello
Changes since 1.21: +10 -8 lines
Diff to previous 1.21 , to selected 1.8
Fixed some comments. Changed so that the stack trace appears at level 0 instead of level 1.
Tue Aug 16 20:21:51 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.20: +7 -4 lines
Diff to previous 1.20 , to selected 1.8
Converted the DebugMode function to use a password cookie instead of a FIG_Config parameter.
Mon Aug 15 21:23:17 2005 UTC (14 years, 5 months ago) by parrello
Diff to previous 1.19 , to selected 1.8
Mon Aug 15 18:49:04 2005 UTC (14 years, 5 months ago) by parrello
Diff to previous 1.18 , to selected 1.8
Rolled back the testing hack.
Mon Aug 15 17:10:27 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.17: +2 -2 lines
Diff to previous 1.17 , to selected 1.8
Mon Aug 15 17:05:51 2005 UTC (14 years, 5 months ago) by parrello
Diff to previous 1.16 , to selected 1.8
Hacked to turn on debug mode always.
Mon Aug 15 00:01:16 2005 UTC (14 years, 5 months ago) by parrello
Diff to previous 1.15 , to selected 1.8
Improved the error message for a failed GetFile call.
Mon Aug 8 20:06:25 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.14: +42 -1 lines
Diff to previous 1.14 , to selected 1.8
Added the new TICK method that can be used in place of the back-tick operator to insure environment-independent functioning.
Tue Jul 26 20:12:33 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.13: +20 -16 lines
Diff to previous 1.13 , to selected 1.8
Fixed some bugs in tracing.
Tue Jun 28 21:26:24 2005 UTC (14 years, 6 months ago) by parrello
CVS Tags: merge-trunktag-bobdev_news-2, merge-trunktag-bodev_news-3
Diff to previous 1.12 , to selected 1.8
Fixed tracing so that the category is no longer case-sensitive.
Thu Jun 23 23:21:09 2005 UTC (14 years, 6 months ago) by parrello
CVS Tags: merge-trunktag-bobdev_news-1
Changes since 1.11: +472 -455 lines
Diff to previous 1.11 , to selected 1.8
Added the ability to trace all categories using an asterisk in the category list for TSetup.
Mon Jun 13 09:34:52 2005 UTC (14 years, 7 months ago) by parrello
CVS Tags: Root-bobdev_news
Changes since 1.10: +148 -17 lines
Diff to previous 1.10 , to selected 1.8
Added OpenDir method for reading directories. Enhanced Open to allow return on error.
Thu Jun 9 05:36:30 2005 UTC (14 years, 7 months ago) by parrello
Changes since 1.9: +150 -15 lines
Wed May 4 03:05:12 2005 UTC (14 years, 8 months ago) by parrello
Changes since 1.8: +179 -49 lines
Wed Apr 6 00:11:50 2005 UTC (14 years, 9 months ago) by redwards
Changes since 1.7: +18 -4 lines
remove requirement for PageBuilder
Tue Apr 5 05:25:57 2005 UTC (14 years, 9 months ago) by parrello
Changes since 1.6: +40 -5 lines
Mon Mar 7 02:01:51 2005 UTC (14 years, 10 months ago) by parrello
Changes since 1.5: +74 -19 lines
no message
Fri Feb 25 18:38:49 2005 UTC (14 years, 10 months ago) by parrello
Changes since 1.4: +181 -10 lines
no message
Thu Jan 27 00:32:17 2005 UTC (14 years, 11 months ago) by parrello
Changes since 1.3: +8 -2 lines
no message
Mon Jan 24 07:05:56 2005 UTC (14 years, 11 months ago) by parrello
Changes since 1.2: +7 -7 lines
no message
Wed Jan 19 18:50:48 2005 UTC (15 years ago) by parrello
Changes since 1.1: +18 -18 lines
no message
Tue Jan 18 20:33:38 2005 UTC (15 years ago) by olson
Diff to selected 1.8
Moved from Sprout
