[Bio] / FigKernelPackages / Tracer.pm Repository:
Log of /FigKernelPackages/Tracer.pm
Links to rast_rel_2009_05_18: (view) (download) (as text) (annotate)
Revision 1.117 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Apr 2 01:13:32 2009 UTC (10 years, 9 months ago) by parrello
CVS Tags: rast_rel_2009_05_18
Changes since 1.116: +44 -1 lines
Diff to previous 1.116 , to selected 1.31
Added code for memory tracing.
Revision 1.116 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Feb 5 06:40:13 2009 UTC (10 years, 11 months ago) by parrello
CVS Tags: rast_rel_2009_03_26
Changes since 1.115: +9 -2 lines
Diff to previous 1.115 , to selected 1.31
Changed HTML tracing output to format multiple-line trace messages the same way the tracing console does.
Revision 1.115 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jan 19 20:50:17 2009 UTC (11 years ago) by parrello
CVS Tags: rast_rel_2009_02_05
Changes since 1.114: +281 -25 lines
Diff to previous 1.114 , to selected 1.31
Added a method to dump an object to the trace file. Removed the idiotic tool-header thing. Changed URL tracing to handle large parameter sets more gracefully. Added some utility methods for handling hashes, strings, and numbers. Fixed an error in the universal sorter. Added a utility method for get/set methods
Revision 1.114 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Oct 16 22:27:09 2008 UTC (11 years, 3 months ago) by olson
Changes since 1.113: +1 -1 lines
Diff to previous 1.113 , to selected 1.31
When tracing CGIs run at the command line, make the tracing code honor the TRACING envar.
Revision 1.113 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Oct 9 17:59:52 2008 UTC (11 years, 3 months ago) by parrello
Changes since 1.112: +27 -12 lines
Diff to previous 1.112 , to selected 1.31
Retooled for parallelism. Added ability to specify new trace modules in scripts.
Revision 1.112 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Oct 1 03:23:40 2008 UTC (11 years, 3 months ago) by parrello
CVS Tags: rast_rel_2008_10_09
Changes since 1.111: +3 -1 lines
Diff to previous 1.111 , to selected 1.31
Added the ability to default to forked mode in StandardSetup.
Revision 1.111 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Sep 30 15:20:36 2008 UTC (11 years, 3 months ago) by parrello
Changes since 1.110: +57 -5 lines
Diff to previous 1.110 , to selected 1.31
Added a new method for converting an options hash into a command line. Made tracing a little bit more thread-safe.
Revision 1.110 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Sep 23 21:48:27 2008 UTC (11 years, 3 months ago) by parrello
Changes since 1.109: +2 -2 lines
Diff to previous 1.109 , to selected 1.31
Clarified a comment.
Revision 1.109 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Sep 23 15:33:54 2008 UTC (11 years, 3 months ago) by parrello
Changes since 1.108: +136 -126 lines
Diff to previous 1.108 , to selected 1.31
Changed to ignore RSS messages at specified IP addresses. This is so Bill's Nagios tests won't get flagged.
Revision 1.108 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Sep 3 20:33:22 2008 UTC (11 years, 4 months ago) by parrello
Changes since 1.107: +39 -0 lines
Diff to previous 1.107 , to selected 1.31
Added a method to compare lists of strings.
Revision 1.107 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jul 7 19:58:47 2008 UTC (11 years, 6 months ago) by parrello
Changes since 1.106: +4 -0 lines
Diff to previous 1.106 , to selected 1.31
Fixed Warn to leave $@ intact.
Revision 1.106 - (view) (download) (as text) (annotate) - [select for diffs]
Fri May 16 08:32:02 2008 UTC (11 years, 8 months ago) by parrello
Changes since 1.105: +73 -19 lines
Diff to previous 1.105 , to selected 1.31
Fixed the feed so that it is thread-safe and changed it so that it can be used from Wiki pages.
Revision 1.105 - (view) (download) (as text) (annotate) - [select for diffs]
Wed May 14 09:09:25 2008 UTC (11 years, 8 months ago) by parrello
Changes since 1.104: +246 -205 lines
Diff to previous 1.104 , to selected 1.31
Added the Clean method. Moved some code around so that it makes more sense.
Revision 1.104 - (view) (download) (as text) (annotate) - [select for diffs]
Fri May 9 06:22:49 2008 UTC (11 years, 8 months ago) by parrello
Changes since 1.103: +11 -1 lines
Diff to previous 1.103 , to selected 1.31
Enhanced to memorize the command line in StandardSetup.
Revision 1.103 - (view) (download) (as text) (annotate) - [select for diffs]
Fri May 9 04:21:45 2008 UTC (11 years, 8 months ago) by parrello
Changes since 1.102: +23 -10 lines
Diff to previous 1.102 , to selected 1.31
Changed to provide better support for StandardSetup.
Revision 1.102 - (view) (download) (as text) (annotate) - [select for diffs]
Thu May 8 22:52:30 2008 UTC (11 years, 8 months ago) by parrello
Changes since 1.101: +49 -32 lines
Diff to previous 1.101 , to selected 1.31
Made the RSS error feed more useful and generally prettier.
Revision 1.101 - (view) (download) (as text) (annotate) - [select for diffs]
Thu May 8 18:03:10 2008 UTC (11 years, 8 months ago) by parrello
Changes since 1.100: +28 -15 lines
Diff to previous 1.100 , to selected 1.31
Twiddled the RSS error feed to make it better.
Revision 1.100 - (view) (download) (as text) (annotate) - [select for diffs]
Thu May 8 14:38:44 2008 UTC (11 years, 8 months ago) by parrello
Changes since 1.99: +10 -4 lines
Diff to previous 1.99 , to selected 1.31
RSS feed now includes the referrer. Fixed so that level-0 messages display even if the category is turned off.
Revision 1.99 - (view) (download) (as text) (annotate) - [select for diffs]
Wed May 7 23:00:16 2008 UTC (11 years, 8 months ago) by parrello
Changes since 1.98: +184 -18 lines
Diff to previous 1.98 , to selected 1.31
Added the Warn method that creates an RSS2 sumnmary of a trace event. This method is automatically called by Confess, which means most crashes will generate an RSS entry.
Revision 1.98 - (view) (download) (as text) (annotate) - [select for diffs]
Thu May 1 07:52:10 2008 UTC (11 years, 8 months ago) by parrello
Changes since 1.97: +15 -12 lines
Diff to previous 1.97 , to selected 1.31
Fixed some formatting glitches.
Tue Apr 29 06:01:21 2008 UTC (11 years, 8 months ago) by parrello
Changes since 1.96: +252 -170 lines
Diff to previous 1.96 , to selected 1.31
Moved in SiteMeter code. Fixed pod docs.
Fri Apr 18 18:40:51 2008 UTC (11 years, 9 months ago) by gdpusch
CVS Tags: rast_rel_2008_04_23
Changes since 1.95: +1 -1 lines
Diff to previous 1.95 , to selected 1.31
Changed useless "warn" to useful "carp" in &Trace(). -- /gdp
Fri Apr 18 18:06:12 2008 UTC (11 years, 9 months ago) by gdpusch
Changes since 1.94: +4 -3 lines
Diff to previous 1.94 , to selected 1.31
Changed useless "warn" to useful "cluck" in &Trace(). -- /gdp
Tue Mar 11 21:04:56 2008 UTC (11 years, 10 months ago) by parrello
Changes since 1.93: +65 -3 lines
Diff to previous 1.93 , to selected 1.31
Changed tracing default to stderr.
Tue Feb 5 02:17:29 2008 UTC (11 years, 11 months ago) by parrello
Changes since 1.92: +1881 -1806 lines
Diff to previous 1.92 , to selected 1.31
Reorganized methods into sections.
Thu Dec 6 13:59:04 2007 UTC (12 years, 1 month ago) by parrello
Changes since 1.91: +72 -67 lines
Diff to previous 1.91 , to selected 1.31
Mon Aug 20 23:07:05 2007 UTC (12 years, 5 months ago) by parrello
Changes since 1.90: +14 -4 lines
Diff to previous 1.90 , to selected 1.31
Enhanced "Insure" to allow specification of a chmod value.
Mon Jul 16 19:44:02 2007 UTC (12 years, 6 months ago) by parrello
Changes since 1.89: +4 -3 lines
Diff to previous 1.89 , to selected 1.31
Fixed output format of HTML tracing.
Tue Jun 19 21:15:37 2007 UTC (12 years, 7 months ago) by parrello
Changes since 1.88: +6 -10 lines
Diff to previous 1.88 , to selected 1.31
Fixed a bug in Confess.
Thu Jun 14 19:27:32 2007 UTC (12 years, 7 months ago) by olson
Changes since 1.87: +11 -3 lines
Diff to previous 1.87 , to selected 1.31
fix infinite loop in Confess
Mon Jun 11 17:34:16 2007 UTC (12 years, 7 months ago) by parrello
Changes since 1.86: +8 -1 lines
Diff to previous 1.86 , to selected 1.31
Updated to display the size of the tool_hdr file in Confess, and fixed so that only the individual package name needs to be specified, rather than the fully-qualified package name.
Fri May 18 19:27:17 2007 UTC (12 years, 8 months ago) by parrello
Changes since 1.85: +1 -1 lines
Diff to previous 1.85 , to selected 1.31
Fixed a bug in emergency tracing for non-file destinations.
Sat May 5 02:17:37 2007 UTC (12 years, 8 months ago) by parrello
Changes since 1.84: +1 -1 lines
Diff to previous 1.84 , to selected 1.31
Changed default trace level for StandardSetup back to 2.
Thu May 3 12:28:00 2007 UTC (12 years, 8 months ago) by parrello
Changes since 1.83: +31 -21 lines
Diff to previous 1.83 , to selected 1.31
Added support for double hyphens.
Fri Apr 27 22:13:57 2007 UTC (12 years, 8 months ago) by parrello
Changes since 1.82: +5 -0 lines
Diff to previous 1.82 , to selected 1.31
Added tracing of command-line options to StandardSetup.
Tue Apr 10 03:51:18 2007 UTC (12 years, 9 months ago) by parrello
Changes since 1.81: +7 -3 lines
Diff to previous 1.81 , to selected 1.31
Added an end-of-line-character option to PutLine.
Mon Feb 12 19:19:59 2007 UTC (12 years, 11 months ago) by parrello
Changes since 1.80: +4 -10 lines
Diff to previous 1.80 , to selected 1.31
Fixed a bad comment.
Fri Feb 9 22:53:22 2007 UTC (12 years, 11 months ago) by parrello
Changes since 1.79: +11 -3 lines
Diff to previous 1.79 , to selected 1.31
Added tracing. Made the new-line stripper in GetLine more robust.
Thu Nov 9 21:12:46 2006 UTC (13 years, 2 months ago) by parrello
Changes since 1.78: +2 -2 lines
Diff to previous 1.78 , to selected 1.31
Changed URL builder to use new ";" notation.
Fri Nov 3 17:00:38 2006 UTC (13 years, 2 months ago) by parrello
Changes since 1.77: +88 -0 lines
Diff to previous 1.77 , to selected 1.31
Added a method for applying URLs to a text column. Fixed a comment.
Sat Oct 7 13:21:08 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.76: +17 -6 lines
Diff to previous 1.76 , to selected 1.31
Added more tracing.
Fri Oct 6 15:39:58 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.75: +4 -2 lines
Diff to previous 1.75 , to selected 1.31
Learned a lot about how PERL times work.
Fri Oct 6 00:41:44 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.74: +1 -1 lines
Diff to previous 1.74 , to selected 1.31
Thu Oct 5 21:51:09 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.73: +35 -0 lines
Diff to previous 1.73 , to selected 1.31
Replaced use of DateTime module with Time::Local.
Tue Oct 3 12:04:50 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.72: +1 -1 lines
Diff to previous 1.72 , to selected 1.31
Fixed the tracing destination display shown by ScriptFinish.
Tue Oct 3 02:30:05 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.71: +329 -143 lines
Diff to previous 1.71 , to selected 1.31
Upgraded emergency tracing to work with command-line tools.
Mon Oct 2 06:34:57 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.70: +1 -2 lines
Diff to previous 1.70 , to selected 1.31
Mon Oct 2 04:41:46 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.69: +11 -4 lines
Diff to previous 1.69 , to selected 1.31
IPs are too fluid, so the emergency tracing now uses cookies.
Mon Oct 2 02:59:47 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.68: +308 -46 lines
Diff to previous 1.68 , to selected 1.31
Implemented a new IP-based file-controlled tracing system that can be activated from the test forms page.
Fri Sep 29 19:48:01 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.67: +18 -11 lines
Diff to previous 1.67 , to selected 1.31
Cleaned up tracing. Improved support for file tracing from CGI scripts.
Fri Sep 29 15:00:17 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.66: +10 -0 lines
Diff to previous 1.66 , to selected 1.31
Added a trace for query URIs.
Tue Sep 26 13:37:07 2006 UTC (13 years, 3 months ago) by parrello
Changes since 1.65: +10 -4 lines
Diff to previous 1.65 , to selected 1.31
Added the ability to write a raw string in the PutFile method.
Tue Sep 19 19:28:48 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.64: +167 -24 lines
Diff to previous 1.64 , to selected 1.31
Added a method to trace CGI parameters.
Thu Sep 14 23:06:00 2006 UTC (13 years, 4 months ago) by parrello
Changes since 1.63: +9 -3 lines
Diff to previous 1.63 , to selected 1.31
Updated the script utilities to allow for URL templates.
Thu Aug 24 21:18:56 2006 UTC (13 years, 4 months ago) by parrello
Diff to previous 1.62 , to selected 1.31
Fixed a bug in CompareLists.
Thu Aug 24 07:58:29 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.61: +68 -0 lines
Diff to previous 1.61 , to selected 1.31
Added a method to compare sorted lists.
Fri Jul 28 02:03:04 2006 UTC (13 years, 5 months ago) by parrello
Changes since 1.60: +7 -7 lines
Diff to previous 1.60 , to selected 1.31
Changed a PageBuilder call to use the new signature.
Thu Jul 20 03:41:00 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.59: +46 -17 lines
Diff to previous 1.59 , to selected 1.31
Added a PutFile method. Changed GetFile to use the local Open method.
Sat Jul 1 03:14:09 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.58: +78 -0 lines
Diff to previous 1.58 , to selected 1.31
Added a method to send SMS to a phone using Clickatell.
Thu Jun 29 19:02:48 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.57: +1 -1 lines
Diff to previous 1.57 , to selected 1.31
This time for sure!
Thu Jun 29 19:00:28 2006 UTC (13 years, 6 months ago) by parrello
Diff to previous 1.56 , to selected 1.31
Fixed SetPermissions bug.
Thu Jun 29 18:50:59 2006 UTC (13 years, 6 months ago) by parrello
Changes since 1.55: +1 -0 lines
Diff to previous 1.55 , to selected 1.31
Added tracing to find the permissions bug.
Sun Jun 18 09:55:24 2006 UTC (13 years, 7 months ago) by parrello
Diff to previous 1.54 , to selected 1.31
Added "CommaFormat" method.
Sun Jun 18 07:40:23 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.53: +38 -0 lines
Diff to previous 1.53 , to selected 1.31
Added a safe percentage function.
Sun Jun 18 05:13:54 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.52: +6 -6 lines
Diff to previous 1.52 , to selected 1.31
Upgraded "AddToListMap" so that it can handle a list of new values.
Wed Jun 14 01:12:42 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.51: +4 -3 lines
Diff to previous 1.51 , to selected 1.31
Fixed a loop bug in SetPermissions.
Wed Jun 14 01:08:46 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.50: +1 -1 lines
Diff to previous 1.50 , to selected 1.31
Wed Jun 14 01:00:41 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.49: +4 -2 lines
Diff to previous 1.49 , to selected 1.31
Added better tracing to SetPermissions.
Wed Jun 14 00:54:59 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.48: +72 -30 lines
Diff to previous 1.48 , to selected 1.31
Made SetPermissions a little more sophisticated.
Thu Jun 8 13:54:49 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.47: +1 -0 lines
Diff to previous 1.47 , to selected 1.31
Thu Jun 8 13:52:23 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.46: +1 -0 lines
Diff to previous 1.46 , to selected 1.31
Fixed a missing use.
Thu Jun 8 13:42:24 2006 UTC (13 years, 7 months ago) by parrello
Changes since 1.45: +88 -0 lines
Diff to previous 1.45 , to selected 1.31
Added a method to set permissions.
Mon May 8 20:37:02 2006 UTC (13 years, 8 months ago) by parrello
Changes since 1.44: +1 -1 lines
Diff to previous 1.44 , to selected 1.31
Exported the ChDir function.
Wed Apr 26 17:57:00 2006 UTC (13 years, 8 months ago) by parrello
Changes since 1.43: +48 -9 lines
Diff to previous 1.43 , to selected 1.31
Added some new options to the StandardSetup method.
Mon Apr 24 21:05:17 2006 UTC (13 years, 9 months ago) by parrello
Changes since 1.42: +33 -1 lines
Diff to previous 1.42 , to selected 1.31
Added some new file-manipulation methods.
Wed Mar 29 19:41:02 2006 UTC (13 years, 9 months ago) by parrello
Changes since 1.41: +24 -1 lines
Diff to previous 1.41 , to selected 1.31
Added a background flag for nohup scripts.
Wed Mar 15 21:59:29 2006 UTC (13 years, 10 months ago) by parrello
Changes since 1.40: +3 -1 lines
Diff to previous 1.40 , to selected 1.31
Added ability to override default trace level in StandardScript.
Wed Mar 15 21:55:08 2006 UTC (13 years, 10 months ago) by parrello
Changes since 1.39: +9 -2 lines
Diff to previous 1.39 , to selected 1.31
Fixed so that if the temporary directory is unavailable, the StandardScript method will echo trace to standard output only.
Fri Feb 24 19:45:29 2006 UTC (13 years, 10 months ago) by parrello
Changes since 1.38: +2 -1 lines
Diff to previous 1.38 , to selected 1.31
Fixed a comment.
Wed Feb 22 11:02:18 2006 UTC (13 years, 11 months ago) by parrello
Changes since 1.37: +10 -2 lines
Diff to previous 1.37 , to selected 1.31
Changed default tracing method to append a user name or PID to the name of the trace file.
Fri Feb 17 00:26:23 2006 UTC (13 years, 11 months ago) by parrello
Changes since 1.36: +28 -1 lines
Diff to previous 1.36 , to selected 1.31
Added a method to create directories when they don't exist.
Sun Jan 15 21:27:33 2006 UTC (14 years ago) by parrello
Changes since 1.35: +77 -16 lines
Diff to previous 1.35 , to selected 1.31
Added a help facility to "StandardSetup".
Wed Jan 11 19:26:45 2006 UTC (14 years ago) by parrello
Changes since 1.34: +146 -8 lines
Diff to previous 1.34 , to selected 1.31
Added some script development utilities.
Fri Jan 6 05:34:21 2006 UTC (14 years ago) by parrello
Diff to previous 1.33 , to selected 1.31
Fri Jan 6 00:41:48 2006 UTC (14 years ago) by parrello
Changes since 1.32: +7 -6 lines
Diff to previous 1.32 , to selected 1.31
Fixed tracing setup to clear existing categories before setting up new ones.
Thu Jan 5 22:26:54 2006 UTC (14 years ago) by parrello
Changes since 1.31: +5 -5 lines
Diff to previous 1.31
Fixed an error in the documentation.
Revision 1.31 - (view) (download) (as text) (annotate) - [selected]
Thu Jan 5 21:41:14 2006 UTC (14 years ago) by parrello
Changes since 1.30: +173 -12 lines
Diff to previous 1.30
Added the StandardSetup method to simplify and standardize processing of command-line parameters.
Changes since 1.29: +17 -0 lines
Diff to previous 1.29 , to selected 1.31
Added license words.
Wed Nov 23 17:53:52 2005 UTC (14 years, 2 months ago) by parrello
Changes since 1.28: +14 -4 lines
Diff to previous 1.28 , to selected 1.31
Fixed some comments.
Added a constant that can be used as an EOF trailer.
Fixed "Strip" to work when an undefined value is input.
Tue Oct 18 17:42:48 2005 UTC (14 years, 3 months ago) by parrello
CVS Tags: caBIG-00-00-00
Changes since 1.27: +18 -10 lines
Diff to previous 1.27 , to selected 1.31
Changed to delete CRs instead of escaping them.
Sat Oct 15 07:57:10 2005 UTC (14 years, 3 months ago) by parrello
Changes since 1.26: +8 -7 lines
Diff to previous 1.26 , to selected 1.31
Enhanced escaping mechanism to convert CRs as well as LFs.
Wed Sep 14 13:09:53 2005 UTC (14 years, 4 months ago) by parrello
CVS Tags: caBIG-dataload-0
Changes since 1.25: +0 -1 lines
Diff to previous 1.25 , to selected 1.31
Removed an annoying trace message.
Tue Sep 13 20:04:25 2005 UTC (14 years, 4 months ago) by parrello
Changes since 1.24: +11 -11 lines
Diff to previous 1.24 , to selected 1.31
Fixed the problem with escaping that was creating backspaces in the Sprout data.
Tue Sep 13 05:39:07 2005 UTC (14 years, 4 months ago) by parrello
Diff to previous 1.23 , to selected 1.31
Tue Sep 13 05:36:12 2005 UTC (14 years, 4 months ago) by parrello
Changes since 1.22: +1 -0 lines
Diff to previous 1.22 , to selected 1.31
Added tracing to UnEscape.
Thu Sep 1 09:35:03 2005 UTC (14 years, 4 months ago) by parrello
Changes since 1.21: +10 -8 lines
Diff to previous 1.21 , to selected 1.31
Fixed some comments. Changed so that the stack trace appears at level 0 instead of level 1.
Tue Aug 16 20:21:51 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.20: +7 -4 lines
Diff to previous 1.20 , to selected 1.31
Converted the DebugMode function to use a password cookie instead of a FIG_Config parameter.
Mon Aug 15 21:23:17 2005 UTC (14 years, 5 months ago) by parrello
Diff to previous 1.19 , to selected 1.31
Mon Aug 15 18:49:04 2005 UTC (14 years, 5 months ago) by parrello
Diff to previous 1.18 , to selected 1.31
Rolled back the testing hack.
Mon Aug 15 17:10:27 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.17: +2 -2 lines
Diff to previous 1.17 , to selected 1.31
Mon Aug 15 17:05:51 2005 UTC (14 years, 5 months ago) by parrello
Diff to previous 1.16 , to selected 1.31
Hacked to turn on debug mode always.
Mon Aug 15 00:01:16 2005 UTC (14 years, 5 months ago) by parrello
Diff to previous 1.15 , to selected 1.31
Improved the error message for a failed GetFile call.
Mon Aug 8 20:06:25 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.14: +42 -1 lines
Diff to previous 1.14 , to selected 1.31
Added the new TICK method that can be used in place of the back-tick operator to insure environment-independent functioning.
Tue Jul 26 20:12:33 2005 UTC (14 years, 5 months ago) by parrello
Changes since 1.13: +20 -16 lines
Diff to previous 1.13 , to selected 1.31
Fixed some bugs in tracing.
Tue Jun 28 21:26:24 2005 UTC (14 years, 6 months ago) by parrello
CVS Tags: merge-trunktag-bobdev_news-2, merge-trunktag-bodev_news-3
Diff to previous 1.12 , to selected 1.31
Fixed tracing so that the category is no longer case-sensitive.
Thu Jun 23 23:21:09 2005 UTC (14 years, 7 months ago) by parrello
CVS Tags: merge-trunktag-bobdev_news-1
Changes since 1.11: +472 -455 lines
Diff to previous 1.11 , to selected 1.31
Added the ability to trace all categories using an asterisk in the category list for TSetup.
Mon Jun 13 09:34:52 2005 UTC (14 years, 7 months ago) by parrello
CVS Tags: Root-bobdev_news
Changes since 1.10: +148 -17 lines
Diff to previous 1.10 , to selected 1.31
Added OpenDir method for reading directories. Enhanced Open to allow return on error.
Thu Jun 9 05:36:30 2005 UTC (14 years, 7 months ago) by parrello
Changes since 1.9: +150 -15 lines
Diff to previous 1.9 , to selected 1.31
Wed May 4 03:05:12 2005 UTC (14 years, 8 months ago) by parrello
Changes since 1.8: +179 -49 lines
Diff to previous 1.8 , to selected 1.31
Wed Apr 6 00:11:50 2005 UTC (14 years, 9 months ago) by redwards
Changes since 1.7: +18 -4 lines
Diff to previous 1.7 , to selected 1.31
remove requirement for PageBuilder
Tue Apr 5 05:25:57 2005 UTC (14 years, 9 months ago) by parrello
Changes since 1.6: +40 -5 lines
Diff to previous 1.6 , to selected 1.31
Mon Mar 7 02:01:51 2005 UTC (14 years, 10 months ago) by parrello
Changes since 1.5: +74 -19 lines
Diff to previous 1.5 , to selected 1.31
no message
Fri Feb 25 18:38:49 2005 UTC (14 years, 10 months ago) by parrello
Changes since 1.4: +181 -10 lines
Diff to previous 1.4 , to selected 1.31
no message
Thu Jan 27 00:32:17 2005 UTC (14 years, 11 months ago) by parrello
Changes since 1.3: +8 -2 lines
Diff to previous 1.3 , to selected 1.31
no message
Mon Jan 24 07:05:56 2005 UTC (14 years, 11 months ago) by parrello
Changes since 1.2: +7 -7 lines
Diff to previous 1.2 , to selected 1.31
no message
Wed Jan 19 18:50:48 2005 UTC (15 years ago) by parrello
Changes since 1.1: +18 -18 lines
Diff to previous 1.1 , to selected 1.31
no message
Tue Jan 18 20:33:38 2005 UTC (15 years ago) by olson
Diff to selected 1.31
Moved from Sprout
