Links to HEAD: | (view) (download) (as text) (annotate) |
Links to rast_rel_2010_1206: | (view) (download) (as text) (annotate) |
Sticky Tag: |
Changed a "die" to a "confess".
Updates for auxiliary role filtering.
Fixed race condition while checking the emergency tracing file.
Fixed so that the ETracing parameter overrides the environment variable.
Took out hacks.
Emergency hack to test error tracking.
Modified so that errors will appear in the trace file by default.
Added ability to turn off automatic CGI parm trace in ETracing method.
Added Google Analytics.
Finished up the Sapling server methods.
Fixed an HTML error in the trace output.
Added new functions to support the seed viewer debug console.
Fixed run-time warning in GetHopeReactions.
Added code for memory tracing.
Changed HTML tracing output to format multiple-line trace messages the same way the tracing console does.
Added a method to dump an object to the trace file. Removed the idiotic tool-header thing. Changed URL tracing to handle large parameter sets more gracefully. Added some utility methods for handling hashes, strings, and numbers. Fixed an error in the universal sorter. Added a utility method for get/set methods
When tracing CGIs run at the command line, make the tracing code honor the TRACING envar.
Retooled for parallelism. Added ability to specify new trace modules in scripts.
Added the ability to default to forked mode in StandardSetup.
Added a new method for converting an options hash into a command line. Made tracing a little bit more thread-safe.
Clarified a comment.
Changed to ignore RSS messages at specified IP addresses. This is so Bill's Nagios tests won't get flagged.
Added a method to compare lists of strings.
Fixed Warn to leave $@ intact.
Fixed the feed so that it is thread-safe and changed it so that it can be used from Wiki pages.
Added the Clean method. Moved some code around so that it makes more sense.
Enhanced to memorize the command line in StandardSetup.
Changed to provide better support for StandardSetup.
Made the RSS error feed more useful and generally prettier.
Twiddled the RSS error feed to make it better.
RSS feed now includes the referrer. Fixed so that level-0 messages display even if the category is turned off.
Added the Warn method that creates an RSS2 sumnmary of a trace event. This method is automatically called by Confess, which means most crashes will generate an RSS entry.
Fixed some formatting glitches.
Moved in SiteMeter code. Fixed pod docs.
Changed useless "warn" to useful "carp" in &Trace(). -- /gdp
Changed useless "warn" to useful "cluck" in &Trace(). -- /gdp
Changed tracing default to stderr.
Reorganized methods into sections.
Enhanced "Insure" to allow specification of a chmod value.
Fixed output format of HTML tracing.
Fixed a bug in Confess.
fix infinite loop in Confess
Updated to display the size of the tool_hdr file in Confess, and fixed so that only the individual package name needs to be specified, rather than the fully-qualified package name.
Fixed a bug in emergency tracing for non-file destinations.
Changed default trace level for StandardSetup back to 2.
Added support for double hyphens.
Added tracing of command-line options to StandardSetup.
Added an end-of-line-character option to PutLine.
Fixed a bad comment.
Added tracing. Made the new-line stripper in GetLine more robust.
Changed URL builder to use new ";" notation.
Added a method for applying URLs to a text column. Fixed a comment.
Added more tracing.
Learned a lot about how PERL times work.
Replaced use of DateTime module with Time::Local.
Fixed the tracing destination display shown by ScriptFinish.
Upgraded emergency tracing to work with command-line tools.
IPs are too fluid, so the emergency tracing now uses cookies.
Implemented a new IP-based file-controlled tracing system that can be activated from the test forms page.
Cleaned up tracing. Improved support for file tracing from CGI scripts.
Added a trace for query URIs.
Added the ability to write a raw string in the PutFile method.
Added a method to trace CGI parameters.
Updated the script utilities to allow for URL templates.
Fixed a bug in CompareLists.
Added a method to compare sorted lists.
Changed a PageBuilder call to use the new signature.
Added a PutFile method. Changed GetFile to use the local Open method.
Added a method to send SMS to a phone using Clickatell.
This time for sure!
Fixed SetPermissions bug.
Added tracing to find the permissions bug.
Added "CommaFormat" method.
Added a safe percentage function.
Upgraded "AddToListMap" so that it can handle a list of new values.
Fixed a loop bug in SetPermissions.
Added better tracing to SetPermissions.
Made SetPermissions a little more sophisticated.
Fixed a missing use.
Added a method to set permissions.
Exported the ChDir function.
Added some new options to the StandardSetup method.
Added some new file-manipulation methods.
Added a background flag for nohup scripts.
Added ability to override default trace level in StandardScript.
Fixed so that if the temporary directory is unavailable, the StandardScript method will echo trace to standard output only.
Fixed a comment.
Changed default tracing method to append a user name or PID to the name of the trace file.
Added a method to create directories when they don't exist.
Added a help facility to "StandardSetup".
Added some script development utilities.
Fixed tracing setup to clear existing categories before setting up new ones.
Fixed an error in the documentation.
Added the StandardSetup method to simplify and standardize processing of command-line parameters.
Added license words.
Fixed some comments. Added a constant that can be used as an EOF trailer. Fixed "Strip" to work when an undefined value is input.
Changed to delete CRs instead of escaping them.
Enhanced escaping mechanism to convert CRs as well as LFs.
Removed an annoying trace message.
Fixed the problem with escaping that was creating backspaces in the Sprout data.
Added tracing to UnEscape.
Fixed some comments. Changed so that the stack trace appears at level 0 instead of level 1.
Converted the DebugMode function to use a password cookie instead of a FIG_Config parameter.
Rolled back the testing hack.
Hacked to turn on debug mode always.
Improved the error message for a failed GetFile call.
Added the new TICK method that can be used in place of the back-tick operator to insure environment-independent functioning.
Fixed some bugs in tracing.
Fixed tracing so that the category is no longer case-sensitive.
Added the ability to trace all categories using an asterisk in the category list for TSetup.
Added OpenDir method for reading directories. Enhanced Open to allow return on error.
remove requirement for PageBuilder
no message
no message
no message
no message
no message
Moved from Sprout
MCS Webmaster | ViewVC Help |
Powered by ViewVC 1.0.3 |
