[Bio] / FigKernelPackages / Tracer.pm Repository:
Diff of /FigKernelPackages/Tracer.pm
revision 1.48, Thu Jun 8 13:54:49 2006 UTC revision 1.49, Wed Jun 14 00:54:59 2006 UTC
# Line 2012  Line 2012
2012
2013  =head3 SetPermissions  =head3 SetPermissions
2014
2015  C<< Tracer::SetPermissions($dirName, $group, $mask); >>  C<< Tracer::SetPermissions($dirName, $group, $mask, %otherMasks); >>
2016
2017  Set the permissions for a directory and all the files and folders inside it.  Set the permissions for a directory and all the files and folders inside it.
2018  In addition, the group ownership will be changed to the specified value.  In addition, the group ownership will be changed to the specified value.
# Line 2036  Line 2036
2036  permission bits of any file or directory that does not already have them  permission bits of any file or directory that does not already have them
2037  set to 1.  set to 1.
2038
2039    =item otherMasks
2040
2041    Map of search patterns to permission masks. If a directory name matches
2042    one of the patterns, that directory and all its members and subdirectories
2043    will be assigned the new pattern. For example, the following would
2044    assign 01664 to most files, but would use 01777 for directories named C<tmp>.
2045
2046        Tracer::SetPermissions($dirName, 'fig', 01664, '^tmp$' => 01777);
2047
2048    The list is ordered, so the following would use 0777 for C<tmp1> and
2049    0666 for C<tmp>, C<tmp2>, or C<tmp3>.
2050
2051        Tracer::SetPermissions($dirName, 'fig', 01664, '^tmp1' => 0777,
2052                                                       '^tmp' => 0666);
2053
2054    Note that the pattern matches are all case-insensitive, and only directory
2055    names are matched, not file names.
2056
2057  =back  =back
2058
2059  =cut  =cut
2060
2061  sub SetPermissions {  sub SetPermissions {
2062      # Get the parameters.      # Get the parameters.
2063      my ($dirName, $group, $mask) = @_;      my ($dirName, $group, $mask, @otherMasks) = @_;
2064      # Set up for error recovery.      # Set up for error recovery.
2065      eval {      eval {
2066            # Switch to the specified directory.
2067          ChDir($dirName);          ChDir($dirName);
2068          # Get the group ID.          # Get the group ID.
2069          my $gid = getgrnam($group);          my $gid = getgrnam($group);
# Line 2056  Line 2075
2075          while (scalar(@dirs) > 0) {          while (scalar(@dirs) > 0) {
2076              # Get the current directory.              # Get the current directory.
2077              my $dir = pop @dirs;              my $dir = pop @dirs;
2078              # Get all its non-hidden members.              # Check for a match to one of the specified directory names. To do
2079                # that, we need to pull the individual part of the name off of the
2080                # whole path.
2081                my $simpleName = $dir;
2082                if ($dir =~ m!/(.+)$!) {
2083                    $simpleName = $1;
2084                }
2085                # Search for a match.
2086                my $match = 0;
2087                my $i;
2088                for ($i = 0; $i < $#otherMasks && ! $match; $i += 2) {
2089                    my $pattern = $otherMasks[$i];
2090                    if ($simpleName =~ /$pattern/i) {
2091                        $match = 1;
2092                    }
2093                }
2094                # Check for a match.
2095                if ($match && $otherMasks[$i+1] != $mask) {
2096                    # This directory matches one of the incoming patterns, and it's
2097                    # a different mask, so we process it recursively with that mask.
2098                    SetPermissions($dir, $group, $otherMasks[$i+1], @otherMasks);
2099                } else {
2100                    # Here we can process normally. Get all of the non-hidden members.
2101              my @submems = OpenDir($dir, 1);              my @submems = OpenDir($dir, 1);
2102              for my $submem (@submems) {              for my $submem (@submems) {
2103                  # Get the full name.                  # Get the full name.
# Line 2090  Line 2131
2131                  }                  }
2132              }              }
2133          }          }
2134            }
2135          Trace("$lookCount files and directories processed, $fixCount fixed.") if T(2);          Trace("$lookCount files and directories processed, $fixCount fixed.") if T(2);
2136      };      };
2137      # Check for an error.      # Check for an error.
Legend:
Removed from v.1.48
changed lines
  Added in v.1.49
