[Bio] / FigKernelPackages / Tracer.pm Repository:
Diff of /FigKernelPackages/Tracer.pm
revision 1.31, Thu Jan 5 21:41:14 2006 UTC revision 1.32, Thu Jan 5 22:26:54 2006 UTC
# Line 89  Line 89
89
90  =over 4  =over 4
91
92  =item 0 Error  =item Error 0
93
94  Message indicates an error that may lead to incorrect results or that has stopped the  Message indicates an error that may lead to incorrect results or that has stopped the
95  application entirely.  application entirely.
96
97  =item 1 Warning  =item Warning 1
98
99  Message indicates something that is unexpected but that probably did not interfere  Message indicates something that is unexpected but that probably did not interfere
100  with program execution.  with program execution.
101
102  =item 2 Notice  =item Notice 2
103
104  Message indicates the beginning or end of a major task.  Message indicates the beginning or end of a major task.
105
106  =item 3 Information  =item Information 3
107
108  Message indicates a subtask. In the FIG system, a subtask generally relates to a single  Message indicates a subtask. In the FIG system, a subtask generally relates to a single
109  genome. This would be a big loop that is not expected to execute more than 500 times or so.  genome. This would be a big loop that is not expected to execute more than 500 times or so.
110
111  =item 4 Detail  =item Detail 4
112
113  Message indicates a low-level loop iteration.  Message indicates a low-level loop iteration.
114
Legend:
Removed from v.1.31
changed lines
  Added in v.1.32
