[Bio] / FigKernelPackages / ToCall.pm Repository:
Log of /FigKernelPackages/ToCall.pm
Fri Jan 25 04:05:38 2008 UTC (12 years, 1 month ago) by gdpusch
Changes since 1.9: +4 -3 lines
Clarified error msg for missing PEG FASTA file. -- /gdp
Sun Nov 18 15:09:30 2007 UTC (12 years, 3 months ago) by overbeek
fixes to find_poss_subsys_instances.cgi
Fri Sep 14 18:10:21 2007 UTC (12 years, 5 months ago) by overbeek
Changes since 1.7: +35 -3 lines
fixes to ToCal.pm
Thu May 24 21:05:37 2007 UTC (12 years, 9 months ago) by olson
Changes since 1.6: +2 -2 lines
use FIGV
Fri Apr 27 19:14:35 2007 UTC (12 years, 10 months ago) by overbeek
Changes since 1.5: +1 -3 lines
fixes to rapid propagation
Fri Sep 1 16:10:24 2006 UTC (13 years, 6 months ago) by overbeek
Changes since 1.4: +3 -1 lines
Fixed backwards test for formatdb invocation. -- /gdp
Fri Sep 1 14:58:47 2006 UTC (13 years, 6 months ago) by overbeek
Changes since 1.3: +8 -3 lines
Added check for non-null query-seqs in &candidate_orfs(). -- /gdp
Fri Jun 16 13:20:22 2006 UTC (13 years, 8 months ago) by overbeek
Changes since 1.2: +6 -0 lines
just add comments to ToCall.pm
Tue May 30 02:50:58 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.1: +29 -0 lines
fixs to rapid propagation
Mon May 29 18:07:44 2006 UTC (13 years, 9 months ago) by overbeek
set up find_neighbors to handle existing genomes
