[Bio] / FigKernelPackages / TemplateObject.pm Repository:
Log of /FigKernelPackages/TemplateObject.pm
Thu Dec 6 13:59:34 2007 UTC (12 years, 6 months ago) by parrello
Tue Jun 12 21:10:58 2007 UTC (12 years, 11 months ago) by paczian
Changes since 1.6: +5 -4 lines
changed the use of $cgi->start_html to writing the plain html, because the cgi method screws up the popup tooltip
Fri Nov 3 18:22:31 2006 UTC (13 years, 7 months ago) by parrello
Fixed missing headers in non-template mode.
Tue Oct 17 18:44:33 2006 UTC (13 years, 7 months ago) by parrello
Chamged a comment.
Thu Aug 10 07:30:00 2006 UTC (13 years, 9 months ago) by parrello
Fixed a bug in the template name generator.
Sun Jul 30 08:14:35 2006 UTC (13 years, 10 months ago) by parrello
Changes since 1.2: +40 -0 lines
Added "append" method for use in the button mode version of the protein page.
Fri Jul 28 04:36:59 2006 UTC (13 years, 10 months ago) by parrello
Changes since 1.1: +5 -1 lines
Added support for the location URL.
Fri Jul 28 02:01:33 2006 UTC (13 years, 10 months ago) by parrello
Diff to selected 1.4
Added to provide a more uniform interface for template and non-template pages.
