[Bio] / FigKernelPackages / TemplateObject.pm Repository:
Diff of /FigKernelPackages/TemplateObject.pm
revision 1.7, Tue Jun 12 21:10:58 2007 UTC revision 1.8, Thu Dec 6 13:59:34 2007 UTC
# Line 103  Line 103
103
104  =head3 new  =head3 new
105
106  C<< my $to = FIG_CGI->new($cgi, $type => $name, $request); >>      my $to = FIG_CGI->new($cgi, $type => $name, $request);
107
108  Construct a new template object for the current script.  Construct a new template object for the current script.
109
# Line 176  Line 176
176
177  =head3 mode  =head3 mode
178
179  C<< my $flag = $to->mode(); >>      my $flag = $to->mode();
180
181  Return TRUE if a template is active, else FALSE.  Return TRUE if a template is active, else FALSE.
182
# Line 191  Line 191
191
192  =head3 raw  =head3 raw
193
194  C<< my $flag = $to->raw(); >>      my $flag = $to->raw();
195
196  Return TRUE if we're accumulating raw HTML, else FALSE.  Return TRUE if we're accumulating raw HTML, else FALSE.
197
# Line 206  Line 206
206
207  =head3 add  =head3 add
208
209  C<< $to->add($name => $html); >>      $to->add($name => $html);
210
211  or  or
212
213  C<< $to->add($html); >>      $to->add($html);
214
215  Add HTML to the template data using the specified name. If a template is in effect, the  Add HTML to the template data using the specified name. If a template is in effect, the
216  data will be put into a variable hash. If raw HTML is being accumulated, the data will  data will be put into a variable hash. If raw HTML is being accumulated, the data will
# Line 256  Line 256
256
257  =head3 append  =head3 append
258
259  C<< $to->append($name, $html); >>      $to->append($name, $html);
260
261  Append HTML to a named variable. Unlike L</add>, this method will not destroy a  Append HTML to a named variable. Unlike L</add>, this method will not destroy a
262  variable's existing value; instead, it will concatenate the new data at the end of the  variable's existing value; instead, it will concatenate the new data at the end of the
# Line 296  Line 296
296
297  =head3 titles  =head3 titles
298
299  C<< to->titles($parameters); >>      to->titles($parameters);
300
301  If no template is in use, generate the plain SEED header. If a template is in  If no template is in use, generate the plain SEED header. If a template is in
302  use, get the version, peg ID, and message of the day for use in the template.  use, get the version, peg ID, and message of the day for use in the template.
# Line 366  Line 366
366
367  =head3 finish  =head3 finish
368
369  C<< my $webPage = $to->finish(); >>      my $webPage = $to->finish();
370
371  Format the template information into a web page. The HTML passed in by the L</add> methods  Format the template information into a web page. The HTML passed in by the L</add> methods
372  is assembled into the proper form and returned to the caller.  is assembled into the proper form and returned to the caller.
Legend:
Removed from v.1.7
changed lines
  Added in v.1.8
