Parent Directory
Revision Log
minor fixes
package TBLstuff; use Data::Dumper; use Carp; sub current_features_of { my($fig,$genome,@types) = @_; if (! @types) { @types = ('peg','rna') } my @curr_features = (); foreach my $type (@types) { foreach my $fid ($fig->all_features($genome,$type)) { my $loc = $fig->feature_location($fid); my @aliases = $fig->feature_aliases($fid); push(@curr_features,[$type,$loc,{ id => $fid, aliases => \@aliases }]); } } return wantarray ? @curr_features : \@curr_features; } sub flat_tbl_to_features { my(@files) = @_; my @features = (); foreach my $file (@files) { if (open(TMP,"<$file")) { while (defined($_ = <TMP>)) { chomp; my($fid,$loc,@aliases) = split(/\t/,$_); if ($fid && ($fid =~ /^fig\|\d+\.\d+\.([a-zA-Z]+)/)) { push(@features,[$1,$loc,{ id => $fid, aliases => \@aliases }]); } } close(TMP); } } return wantarray ? @features : \@features; } sub compare_sets_of_features { my($fig,$set1,$set2) = @_; my @set1 = map { my($contig,$beg,$end) = $fig->boundaries_of($_->[1]); my($left,$right) = sort { $a <=> $b } ($beg,$end); [1,$_,$contig,$beg,$end,$left,$right,&frame($_->[0],$beg,$end)] } @$set1; my @set2 = map { my($contig,$beg,$end) = $fig->boundaries_of($_->[1]); my($left,$right) = sort { $a <=> $b } ($beg,$end); [2,$_,$contig,$beg,$end,$left,$right,&frame($_->[0],$beg,$end)] } @$set2; my @merged = sort { ($a->[1]->[0] cmp $b->[1]->[0]) or # type ($a->[2] cmp $b->[2]) or # contig ($a->[7] <=> $b->[7]) or # frame ($a->[5] <=> $b->[5]) # left coord } (@set1,@set2); my @output; my $x = shift @merged; while ($x) { # print STDERR "Looking at ",&Dumper($x); if (! (@merged && &comparable($x,$merged[0]))) { # print STDERR "not comparable\n"; push(@output,['', $x->[2], # contig $x->[3] + $x->[4], # mid*2 ($x->[0] == 1) ? ($x,undef) : (undef,$x) ] ); $x = shift @merged; } else { my $y = shift @merged; # print STDERR "comparable",&Dumper($y); if ($x->[1]->[0] eq 'peg') { if ($x->[4] == $y->[4]) # if ends match { my $relation = ($x->[3] == $y->[3]) ? 'same' : 'diff-start'; push(@output,[$relation, $x->[2], # contig $x->[3] + $x->[4], # mid*2 ($x->[0] < $y->[0]) ? ($x,$y) : ($y,$x) # entries ]); $x = shift @merged; } else { ($x,$y) = ($y,$x) if ($x->[6] > $y->[6]); # flip if $y is longer push(@output,['', $x->[2], # contig $x->[3] + $x->[4], # mid*2 ($x->[0] == 1) ? ($x,undef) : (undef,$x) ] ); $x = $y; } } elsif (&correspond($x,$y)) { my $relation = (($x->[3] == $y->[3]) && ($x->[4] == $y->[4])) ? 'same' : 'diff-ends'; push(@output,[$relation, $x->[2], # contig $x->[3] + $x->[4], # mid*2 ($x->[0] < $y->[0]) ? ($x,$y) : ($y,$x) # entries ]); $x = shift @merged; } else { ($x,$y) = ($y,$x) if ($x->[6] > $y->[6]); # flip if $y is longer push(@output,['', $x->[2], # contig $x->[3] + $x->[4], # mid*2 ($x->[0] == 1) ? ($x,undef) : (undef,$x) ] ); $x = $y; } } } return wantarray ? @output : \@output; } sub comparable { my($x,$y) = @_; return (($x->[0] != $y->[0]) && # diff sets ($x->[1]->[0] eq $y->[1]->[0]) && # same type ($x->[2] eq $y->[2]) && # same contig ($x->[7] == $y->[7])); # same frame } sub correspond { my($x,$y) = @_; # testing if two non-pegs overlap enough my $overlap = 1 + &FIG::min($x->[6],$y->[6]) - &FIG::max($x->[5],$y->[5]); my $maxln = &FIG::max(($x->[6] - $x->[5])+1, (($y->[6] - $y->[5])+1)); return ($overlap >= (0.8 * $maxln)); } sub frame { my($type,$beg,$end) = @_; if ($type eq 'peg') { return (($end % 3)+1) * ($end <=> $beg); } else { return ($end <=> $beg); } } 1;
MCS Webmaster | ViewVC Help |
Powered by ViewVC 1.0.3 |
