[Bio] / FigKernelPackages / Subsystem.pm Repository:
Diff of /FigKernelPackages/Subsystem.pm
revision 1.24, Mon Aug 16 22:10:55 2004 UTC revision 1.25, Thu Aug 26 21:26:52 2004 UTC
# Line 1  Line 1
1
2  package Subsystem;  package Subsystem;
3
4    use Carp;
5  use FIG;  use FIG;
6
7  use FIGAttributes;  use FIGAttributes;
# Line 25  Line 26
26  canonical version of the subsystem information in the flat-files  canonical version of the subsystem information in the flat-files
27  kept in $FIG_Config::data/Subsystems.  kept in $FIG_Config::data/Subsystems.
28
29    =head2 Objects.
30
31    We define the following perl objects:
32
33    Subsystem: represents a subsystem. It can be read from disk and
34    written to disk, and manipulated via its methods when in memory.
35
36    If we were completely on the OO side of the world, we would also
37    define the following set of objects. However, we are not, so they are
38    only objects in a conceptual sense. They are implemented using the
39    basic perl datatypes.
40
41    Role: represents a single role. A role has a name and an abbreviation.
42
43    RoleSubset: represents a subset of available roles. A subset has a
44    name and a list of role names that comprise the subset.
45
46  =head2 Thoughts on locking  =head2 Thoughts on locking
47
48  It is currently dangerous for multiple users to modify spreadsheets at once.  It is currently dangerous for multiple users to modify spreadsheets at once.
# Line 62  Line 80
80
81  1 if subsystem is exchangable, 0 otherwise.  1 if subsystem is exchangable, 0 otherwise.
82
83  =item roles  =item roles
84
85  list of role names  List of role names.
86
87  =item role_index  =item role_index
88
# Line 97  Line 114
114
115  =item genome  =item genome
116
117  List (1-indexed, so element 0 is undef) of genome IDs.  List  of genome IDs.
118
119  =item variant_code  =item variant_code
120
121  List (1-indexed, so element 0 is undef) of variant codes.  List of variant codes.
122
123  =item genome_index  =item genome_index
124
125  Hash mapping from genome ID to genome index.  Hash mapping from genome ID to genome index.
126
 =item variant_code
127  =item spreadsheet  =item spreadsheet
128
129  Spreadsheet data. Structured as a list of rows, each of  which  Spreadsheet data. Structured as a list of rows, each of  which
# Line 123  Line 136
136
137  =back  =back
138
139    =head2  Methods
140
141    =over 4
142
143    =item index_cell
144
145    Create the subsystem_index entries for the given cell.
146    (NEW).
147
148    =item delete_role(name)
149
150    Delete the given role.
151
152    =item add_role(name, abbr)
153
154    Add a new role.
155
156    =item get_subset(name)
157
158    Returns a given subset. A subset is an object, implemented as a blessed array
159    of roles.
160
161    =item add_genome(genome_id, variant_code)
162
163    =item remove_genome(genome_id)
164
165    =back
166
167  =cut  =cut
168
169  =pod  =pod
# Line 146  Line 187
187      # For loading, the subsystem directory must already exist.      # For loading, the subsystem directory must already exist.
188      #      #
189
190      if (! -d $ssa_dir)      if (! -d $ssa_dir and not $create)
         if ($create)
             return create_subsystem($class, $name, $fig);
         else
191          {          {
192  #           warn "Subsystem $name does not exist\n";  #           warn "Subsystem $name does not exist\n";
193              return undef;              return undef;
194          }          }
195
196      my $self = {      my $self = {
197          dir => $ssa_dir,          dir => $ssa_dir,
# Line 167  Line 201
201
202      bless($self, $class);      bless($self, $class);
203
204        if ($create)
205        {
206            $self->create_subsystem();
207        }
208        else
209        {
210      $self->load();      $self->load();
211        }
212
213      return $self;      return $self;
214  }  }
# Line 196  Line 237
237      return $self;      return $self;
238  }  }
239
240    =pod
241
242    =head2 create_subsystem()
243
244    Create a new subsystem. This creates the subsystem directory in the
245    correct place ($FIG_Config::data/Subsystems), and populates it with
246    the correct initial data.
247
248    =cut
249
250  sub create_subsystem  sub create_subsystem
251  {  {
252      my($class, $name, $fig) = @_;      my($self) = @_;
253
254      return undef;      my $dir = $self->{dir};
255        my $fig = $self->{fig};
256
257        if (-d $dir)
258        {
259            warn "Not creating: Subsystem directory $dir already exists";
260            return;
261        }
262
263        $fig->verify_dir($dir);
264
265        #
266        # Initialize empty data structures.
267        #
268
269        $self->{genome} = [];
270        $self->{genome_index} = {};
271        $self->{variant_code} = [];
272
273        $self->{abbr} = {};
274        $self->{role_index} = {};
275        $self->{roles} = [];
276        $self->{role_abbrs} = [];
277
278        $self->{spreadsheet} = [];
279        $self->{spreadsheet_inv} = [];
280
281        $self->{col_subsets} = [];
282        $self->{col_subset_members} = {};
283
284        $self->{row_active_subset} = "All";
285        $self->{col_active_subset} = "All";
286
287        $self->{version} = 0;
288        $self->{exchangable} = 0;
289
290        $self->write_subsystem();
291  }  }
292
293  #  #
# Line 262  Line 349
349
350      if (!$skip_delete)      if (!$skip_delete)
351      {      {
352          $rdbH->SQL("DELETE FROM subsystem_index where subsystem = '$self->{name}'")          $self->delete_indices();
353      }      }
354
355      #      #
# Line 414  Line 501
501      $self->{roles} = [];      $self->{roles} = [];
502      $self->{role_abbrs} = [];      $self->{role_abbrs} = [];
503
504      my $i = 1;      my $i = 0;
505      for my $role (@roles)      for my $role (@roles)
506      {      {
507          my($abbr, $name) = split(/\t/, $role);          my($abbr, $name) = split(/\t/, $role);
# Line 437  Line 524
524      #      #
525      my($subsetsC, $subsetsR) = split(/\n\n/, $subsets);      my($subsetsC, $subsetsR) = split(/\n\n/, $subsets);
526
527      #      #
528      # Handle column subsets.      # Handle column subsets.
529      #      #
# Line 467  Line 553
553      {      {
554          my($name, @members) = split(/\s+/, $subset);          my($name, @members) = split(/\s+/, $subset);
555
556            #
557            # File format has members 1-based.
558            #
559
560            @members = map { $_ - 1 } @members;
561
562          push(@{$self->{col_subsets}}, $name);          push(@{$self->{col_subsets}}, $name);
563
564          #          #
# Line 496  Line 588
588
589      if ($subsetsR =~ /(\S+.*\S+)/)      if ($subsetsR =~ /(\S+.*\S+)/)
590      {      {
591          $self->{row_subset_active} = $1;          $self->{row_active_subset} = $1;
592      }      }
593      else      else
594      {      {
595          $self->{row_subset_active} = 'All';          $self->{row_active_subset} = 'All';
596      }      }
597  }  }
598
# Line 515  Line 607
607      $self->{genome_index} = {};      $self->{genome_index} = {};
608      $self->{variant_code} = [];      $self->{variant_code} = [];
609
610      my $i = 1;      my $nr = @{$self->{roles}};
611
612        my $i = 0;
613      while (<$fh>)      while (<$fh>)
614      {      {
615          chomp;          chomp;
616
617          my($genome, $variant_code, @row) = split(/\t/);          my($genome, $variant_code, @row) = split(/\t/, $_, $nr + 2);
618
619          next if $seen{$genome};          next if $seen{$genome};
620          $seen{$genome}++;          $seen{$genome}++;
621
622          my $j = 1;          my $j = 0;
623
624          $self->{genome}->[$i] = $genome;          $self->{genome}->[$i] = $genome;
625          $self->{genome_index}->{$genome} = $i;          $self->{genome_index}->{$genome} = $i;
626          $self->{variant_code}->[$i] = $variant_code;          $self->{variant_code}->[$i] = $variant_code;
627
628          for my $entry (@row)          my $thislen = @row;
629
630    #       if ($thislen != $nr)
631    #       {
632    #           warn "Genome $genome has wrong column count ($thislen != $nr)\n";
633    #           warn "<$_> $genome $variant_code '", join(":", @row), "'\n";
634    #       }
635
636            for my $j (0..$nr - 1)
637          {          {
638                my $entry = $row[$j];
639              my $e2 = [map("fig|$genome.peg.$_", split(/,/, $entry))];              my $e2 = [map("fig|$genome.peg.$_", split(/,/, $entry))];
640              $self->{spreadsheet}->[$i]->[$j] = $e2;              $self->{spreadsheet}->[$i]->[$j] = $e2;
641              $self->{spreadsheet_inv}->[$j]->[$i] = $e2;              $self->{spreadsheet_inv}->[$j]->[$i] = $e2;
# Line 545  Line 648
648
649  =pod  =pod
650
651    =head2 write_subsystem()
652
653    Write the subsystem to the disk.  Updates on-disk data with notes,
654    etc. Perform backups when necessary.
655
656    =cut
657
658    sub write_subsystem
659    {
660        my($self) = @_;
661
662        my $dir = $self->{dir};
663        my $fig = $self->{fig};
664
665        #
666        # We first move the existing spreadsheet and notes files (if present)
667        # to spreadsheet~ and notes~, and current state.
668        #
669
670        my $ss_file = "$dir/spreadsheet";
671        my $ss_bak = "$dir/spreadsheet~";
672        my $notes_file = "$dir/notes";
673        my $notes_bak = "$dir/notes~";
674
675        if (-f $ss_file)
676        {
677            rename($ss_file, $ss_bak);
678        }
679
680        if (-f $notes_file)
681        {
682            rename($notes_file, $notes_bak);
683        }
684
685        #
686        # Eval this whole chunk, so that if we get any fatal errors, we can
687        # roll back to the old saved data.
688        #
689
690        eval {
691            my $fh;
692            open($fh, ">$ss_file") or die "Cannot open $ss_file for writing: $!\n";
693            $self->write_spreadsheet($fh);
694            close($fh);
695
696            open($fh, ">$notes_file") or die "Cannot open $notes_file for writing: $!\n";
697            print $fh "$self->{notes}\n";
698            close($fh);
699
700            $self->update_curation_log();
701
702            #
703            # Write out the piddly stuff.
704            #
705
706            open($fh, ">$dir/EXCHANGABLE") or die "Cannot write $dir/EXCHANGABLE: $!\n";
707            print $fh "$self->{exchangable}\n";
708            close($fh);
709
710            #
711            # Process backup files. This is the smae process that determines when the
712            # version number should be bumped, so write the version file afterward.
713            #
714
715            $self->update_backups();
716
717            open($fh, ">$dir/VERSION") or die "Cannot write $dir/EXCHANGABLE: $!\n";
718            print $fh "$self->{exchangable}\n";
719            close($fh);
720
721        };
722
723        if ($@ ne "")
724        {
725            warn "Spreadsheet write failed, reverting to backup. Error was\n$@\n";
726        }
727
728    }
729
730    sub update_curation_log
731    {
732        my($self) = @_;
733
734        my $fh;
735        my $file = "$self->{dir}/curation.log";
736
737        my $now = time;
738        my $user = $self->{fig}->get_user();
739
740        if (-f $file)
741        {
742            open($fh, ">>$file") or die "Cannot open $file for writing: $!\n";
743        }
744        else
745        {
746            open($fh, ">$file") or die "Cannot open $file for writing: $!\n";
747            print $fh "$now\t$user\tstarted\n";
748        }
749        print $fh "$now\t$user\tupdated\n";
750        close($fh);
751    }
752
753    sub update_backups
754    {
755        my($self) = @_;
756
757        my $dir = $self->{dir};
758        my $fig = $self->{fig};
759
760        my $ss_file = "$dir/spreadsheet";
761        my $ss_bak = "$dir/spreadsheet~";
762        my $notes_file = "$dir/notes";
763        my $notes_bak = "$dir/notes~";
764
765        my $ss_diff = abs((-s $ss_file) - (-s $ss_bak));
766        my $notes_diff = abs((-s $notes_file) - (-s $notes_bak));
767
768        if ($ss_diff > 10 or $notes_diff > 10)
769        {
770            $self->make_backup();
771        }
772    }
773
774    sub make_backup
775    {
776        my($self) = @_;
777
778        my $dir = $self->{dir};
779        my $bak = "$dir/Backup";
780
781        $self->{fig}->verify_dir($bak);
782
783        my $ts = time;
784
785        rename("$dir/spreadsheet~", "$bak/spreadsheet.$ts");
786        rename("$dir/notes~", "$bak/notes.$ts");
787        $self->{version}++;
788    }
789
790
791
792    =pod
793
794    =head1 write_spreadsheet($fh)
795
796    Write the spreadsheet for this subsystem to filehandle $fh.
797
798    =cut
799
800    sub write_spreadsheet
801    {
802        my($self, $fh) = @_;
803
804        $self->_write_roles($fh);
805        print $fh "//\n";
806
807        $self->_write_subsets($fh);
808        print $fh "//\n";
809
810        $self->_write_spreadsheet($fh);
811    }
812
813    sub _write_roles
814    {
815        my($self, $fh) = @_;
816
817        my(@roles, @abbrs);
818
819        @roles = $self->get_roles();
820        @abbrs = $self->get_abbrs();
821
822        while (@roles)
823        {
824            my $role = shift(@roles);
825            my $abbr = shift(@abbrs);
826
827            print $fh "$abbr\t$role\n";
828        }
829    }
830
831    sub _write_subsets
832    {
833        my($self, $fh) = @_;
834
835        for my $sub ($self->get_subset_names())
836        {
837            my @members= $self->get_subset($sub);
838
839            #
840            # member list on disk is 1-based
841            #
842
843            @members = map { $_ + 1 } @members;
844            print $fh join("\t", $sub, @members), "\n";
845        }
846        print $fh "All\n";
847
848        #
849        # separator
850        #
851
852        print $fh "\n";
853
854        #
855        # genome subsets.
856        #
857
858        print $fh "All\n";
859    }
860
861    sub _write_spreadsheet
862    {
863        my($self, $fh) = @_;
864
865        my(@genomes);
866
867        @genomes= $self->get_genomes();
868
869        for (my $i = 0; $i < @genomes; $i++)
870        {
871            my $genome = $genomes[$i];
872            my $vc = $self->get_variant_code($i);
873
874            my $row = $self->get_row($i);
875
876            if ($vc eq "")
877            {
878                $vc = "0";
879            }
880            print $fh "$genome\t$vc";
881
882            for my $entry (@$row)
883            {
884                my(@p);
885
886                for my $peg (@$entry)
887                {
888                    if ($peg =~ /fig\|$genome\.peg\.(\d+)$/)
889                    {
890                        push(@p, $1);
891                    }
892                    else
893                    {
894                        warn "Bad peg $peg in cell for $genome";
895                    }
896                }
897                print $fh "\t", join(",", @p);
898            }
899            print $fh "\n";
900        }
901    }
902
903
904    =pod
905
906  =head1 get_genomes  =head1 get_genomes
907
908  =cut  =cut
# Line 555  Line 913
913
914      my $glist = $self->{genome};      my $glist = $self->{genome};
915
916      return @$glist[1..$#$glist];      return @$glist;
917  }  }
918
919  =pod  =pod
# Line 570  Line 928
928
929      my $glist = $self->{variant_code};      my $glist = $self->{variant_code};
930
931      return @$glist[1..$#$glist];      return @$glist;
932    }
933
934    sub get_variant_code
935    {
936        my($self, $gidx) = @_;
937        return $self->{variant_code}->[$gidx];
938  }  }
939
940
941  sub get_variant_code_for_genome  sub get_variant_code_for_genome
942  {  {
943      my($self, $genome) = @_;      my($self, $genome) = @_;
# Line 587  Line 952
952
953      my $rlist = $self->{roles};      my $rlist = $self->{roles};
954
955      return @$rlist[1..$#$rlist];      return @$rlist;
956    }
957
958    sub get_abbrs
959    {
960        my($self) = @_;
961
962        my $rlist = $self->{role_abbrs};
963
964        return @$rlist;
965  }  }
966
967  sub get_row :scalar  sub get_row :scalar
# Line 715  Line 1089
1089      }      }
1090  }  }
1091
1092  sub get_name :scalar  #
1093    # Subset support
1094    #
1095
1096    sub get_subset_names
1097  {  {
1098      my($self) = @_;      my($self) = @_;
     return $self->{name};
1099
1100        return @{$self->{col_subsets}};
1101    }
1102
1103  sub get_version :scalar  sub get_subset
1104  {  {
1105      my($self) = @_;      my($self, $subname) = @_;
1106      return $self->{version};      return @{$self->{col_subset_members}->{$subname}};
1107    }
1108
1109    =pod
1110
1111    =head2 set_subset($name, $members)
1112
1113    Create a subset with the given name and members.
1114
1115    $members is a list of role names.
1116
1117    =cut
1118
1119    sub set_subset
1120    {
1121        my($self, $subname, $list) = @_;
1122
1123        my $nl = [map { $self->get_role_index($_) } @$list];
1124
1125        $self->_set_subset($subname, $nl);
1126    }
1127
1128    =pod
1129
1130    =head2 _set_subset($name, $members)
1131
1132    Create a subset with the given name and members.
1133
1134    Internal version  - here, members is a list of role indices.
1135
1136    =cut
1137
1138    sub _set_subset
1139    {
1140        my($self, $subname, $list) = @_;
1141        $self->{col_subset_members}->{$subname} = $list;
1142    }
1143
1144    #
1145    # Role manipulation.
1146    #
1147
1148
1149    =pod
1150
1151    =head1 set_roles($role_list)
1152
1153    Set the list of roles. C<$role_list> is a list of tuples C<[$role_name, $abbreviation]>.
1154
1155    If a role already exists, it is used. If it does not exist, it is created empty.
1156
1157    =cut
1158
1159    sub set_roles
1160    {
1161        my($self, $roles) = @_;
1162
1163        #
1164        # We do this by first creating a new spreadsheet.
1165        #
1166        # It is easiest to do this by manipulating the inverted spreadsheet
1167        # (role-major), and then creating the non-inverted spreadsheet from it.
1168        #
1169
1170        my $oldss = $self->{spreadsheet};
1171        my $oldssinv = $self->{spreadsheet_inv};
1172
1173        my $ss = [];
1174        my $ssinv = [];
1175
1176        my $g = $self->{genome};
1177        my $ng = @$g;
1178
1179        my $old_roles = $self->{role_index};
1180
1181        my @role_index_conversion;
1182
1183
1184        $self->{abbr} = {};
1185        $self->{role_index} = {};
1186        $self->{roles} = [];
1187        $self->{role_abbrs} = [];
1188
1189
1190        for (my $idx = 0; $idx < @$roles; $idx++)
1191        {
1192            my $role = $roles->[$idx]->[0];
1193            my $abbr = $roles->[$idx]->[1];
1194
1195            my $old_idx = $old_roles->{$role};
1196
1197            if (defined($old_idx))
1198            {
1199                print "Found old idx $old_idx for $role $idx\n";
1200                print $oldssinv->[$old_idx];
1201                $ssinv->[$idx] = $oldssinv->[$old_idx];
1202
1203                $role_index_conversion[$old_idx] = $idx;
1204            }
1205            else
1206            {
1207                print "Did not find old role for $role $idx\n";
1208                print Dumper($old_roles);
1209                my $l = [];
1210                for (my $j = 0; $j < $ng; $j++)
1211                {
1212                    $l->[$j] = [];
1213                }
1214
1215                $ssinv->[$idx] = $l;
1216            }
1217
1218            #
1219            # While we're here, update the new role and abbrev indexes
1220            #
1221            $self->{role_index}->{$role} = $idx;
1222            $self->{abbr}->{$abbr} = $role;
1223            $self->{roles}->[$idx] = $role;
1224            $self->{role_abbrs}->[$idx] = $abbr;
1225        }
1226
1227        #
1228        # Now create the uninverted spreadsheet.
1229        #
1230
1231        for (my $gidx = 0; $gidx < $ng; $gidx++)
1232        {
1233            my $row = [];
1234            $ss->[$gidx] = $row;
1235            for (my $ridx = 0; $ridx < @$roles; $ridx++)
1236            {
1237                $row->[$ridx] = $ssinv->[$ridx]->[$gidx];
1238            }
1239        }
1240
1241        $self->{spreadsheet} = $ss;
1242        $self->{spreadsheet_inv} = $ssinv;
1243
1244        #
1245        # Fix up the subsets.
1246        #
1247
1248
1249        for my $subset ($self->get_subset_names())
1250        {
1251            my $n = [];
1252            for my $idx ($self->get_subset($subset))
1253            {
1254                my $new = $role_index_conversion[$idx];
1255                if (defined($new))
1256                {
1257                    push(@$n, $new);
1258                }
1259            }
1260            $self->_set_subset($subset, $n);
1261        }
1262
1263    }
1264
1265    =pod
1266
1267    =head1 C<add_role($role, $abbr)>
1268
1269    Add the given role to the spreadsheet.
1270
1271    This causes a new column to be added, with empty values in each cell.
1272
1273    We do nothing if the role is already present.
1274
1275    Return the index of the new role.
1276
1277    =cut
1278
1279    sub add_role
1280    {
1281        my($self, $role, $abbr) = @_;
1282
1283        if (defined($self->get_role_index($role)))
1284        {
1285            warn "Role $role already present\n";
1286            return undef;
1287        }
1288
1289        #
1290        # Add to the roles list. It goes at the end.
1291        #
1292
1293        my $idx = @{$self->{roles}};
1294        $self->{roles}->[$idx] = $role;
1295        $self->{role_abbrs}->[$idx] = $abbr;
1296        $self->{role_index}->{$role} = $idx;
1297        $self->{abbr}->{$abbr} = $role;
1298
1299        #
1300        # Update the spreadsheet.
1301        # On the standard one, we have to go through all the rows adding
1302        # a columnt to each.
1303        #
1304        # On the inverted one, we add a column with [] in each entry.
1305        #
1306
1307        my $ng = @{$self->{genome}};
1308        my $newcol = [];
1309
1310        for (my $i = 0; $i < $ng; $i++)
1311        {
1312            my $cell = [];
1313            # print "nr: Adding cell $cell for gidx=$i ridx=$idx\n";
1314            $self->{spreadsheet}->[$i]->[$idx] = $cell;
1315            $newcol->[$i] = $cell;
1316        }
1317
1318        $self->{spreadsheet_inv}->[$idx] = $newcol;
1319
1320        return $idx;
1321    }
1322
1323    =pod
1324
1325    =head1 remove_role($role)
1326
1327    Remove the role from the spreadsheet.
1328
1329    We do nothing if the role is not present.
1330
1331    =cut
1332
1333    sub remove_role
1334    {
1335        my($self, $role) = @_;
1336
1337        my $idx = $self->get_role_index($role);
1338        if (!defined($idx))
1339        {
1340            warn "Role $role not present\n";
1341            return undef;
1342        }
1343
1344        #
1345        # Remove from the roles list.
1346        #
1347
1348        my $abbr = $self->{role_abbrs}->[$idx];
1349
1350        splice(@{$self->{roles}}, $idx, 1);
1351        splice(@{$self->{role_abbrs}}, $idx, 1);
1352        delete $self->{role_index}->{$role};
1353        delete $self->{abbr}->{$abbr};
1354
1355        #
1356        # Update the spreadsheet.
1357        # On the standard one, we have to go through all the rows removing
1358        # the column from each.
1359        #
1360        # On the inverted one, we just remove the column.
1361        #
1362
1363        my $ng = @{$self->{genome}};
1364        my $newcol = [];
1365
1366        for (my $i = 0; $i < $ng; $i++)
1367        {
1368            splice(@{$self->{spreadsheet}->[$i]}, $idx, 1);
1369        }
1370
1371        splice(@{$self->{spreadsheet_inv}}, $idx, 1);
1372
1373        #
1374        # We need to rewrite the subsets. if $idx was present in one, it is
1375        # removed. Any index >$idx is decremented.
1376        #
1377
1378        for my $subset ($self->get_subset_names())
1379        {
1380            my @n;
1381
1382            for my $sidx ($self->get_subset($subset))
1383            {
1384                if ($sidx < $idx)
1385                {
1386                    push(@n, $sidx);
1387                }
1388                elsif ($sidx > $idx)
1389                {
1390                    push(@n, $sidx - 1);
1391                }
1392            }
1393
1394            $self->_set_subset($subset, [@n]);
1395        }
1396    }
1397
1398    =pod
1399
1400    =head1 C<add_genome($genome, $abbr)>
1401
1402    Add the given genome to the spreadsheet.
1403
1404    This causes a new row to be added, with empty values in each cell.
1405
1406    We do nothing if the genome is already present.
1407
1408    Return the index of the new genome.
1409
1410    =cut
1411
1412    sub add_genome
1413    {
1414        my($self, $genome) = @_;
1415
1416        my $idx = $self->get_genome_index($genome);
1417        if (defined($idx))
1418        {
1419            warn "Genome $genome already present\n";
1420            return $idx;
1421        }
1422
1423        #
1424        # Add to the genomes list. It goes at the end.
1425        #
1426
1427        my $idx = @{$self->{genome}};
1428        $self->{genome}->[$idx] = $genome;
1429        $self->{genome_index}->{$genome} = $idx;
1430
1431        #
1432        # Update the spreadsheet.
1433        # On the inverted one, we have to go through all the columns adding
1434        # a row to each.
1435        #
1436        # On the regular one, we add a row with [] in each entry.
1437        #
1438
1439        my $nr = @{$self->{roles}};
1440        my $newrow = [];
1441
1442        for my $i (0.. $nr - 1)
1443        {
1444            my $cell = [];
1445            # print "ng: Adding cell $cell for gidx=$idx ridx=$i\n";
1446            $self->{spreadsheet_inv}->[$i]->[$idx] = $cell;
1447            $newrow->[$i] = $cell;
1448        }
1449
1450        $self->{spreadsheet}->[$idx] = $newrow;
1451
1452        return $idx;
1453    }
1454
1455    =pod
1456
1457    =head1 remove_genome($genome)
1458
1459    Remove the genome from the spreadsheet.
1460
1461    We do nothing if the genome is not present.
1462
1463    =cut
1464
1465    sub remove_genome
1466    {
1467        my($self, $genome) = @_;
1468
1469        my $idx = $self->get_genome_index($genome);
1470        if (!defined($idx))
1471        {
1472            warn "Genome $genome not present\n";
1473            return undef;
1474        }
1475
1476        #
1477        # Remove from the genomes list.
1478        #
1479
1480        splice(@{$self->{genome}}, $idx, 1);
1481        splice(@{$self->{variant_code}}, $idx, 1);
1482
1483        delete $self->{genome_index}->{$genome};
1484
1485        #
1486        # Update the spreadsheet.
1487        # On the inverted one, we have to go through all the columns removing
1488        # the row from each.
1489        #
1490        # On the standard one, we just remove the row.
1491        #
1492
1493        my $nr = @{$self->{roles}};
1494
1495        for my $i (0 .. $nr - 1)
1496        {
1497            splice(@{$self->{spreadsheet_inv}->[$i]}, $idx, 1);
1498        }
1499
1500        splice(@{$self->{spreadsheet}}, $idx, 1);
1501
1502    }
1503
1504    sub get_name :scalar
1505    {
1506        my($self) = @_;
1507        return $self->{name};
1508    }
1509
1510
1511    sub get_version :scalar
1512    {
1513        my($self) = @_;
1514        return $self->{version};
1515  }  }
1516
1517  sub get_curator :scalar  sub get_curator :scalar
# Line 734  Line 1520
1520      return $self->{curator};      return $self->{curator};
1521  }  }
1522
1523    #
1524    # Subsystem copying logic
1525    #
1526
1527    =pod
1528
1529    =head2 add_to_subsystem($subsystem_name, $columns, $notes_flag)
1530
1531    Merge the given columns from $subsystem_name into this subsystem. Append the
1532    notes from the subsystem if $notes_flag is true.
1533
1534    =cut
1535
1536    sub add_to_subsystem
1537    {
1538        my($self, $subsystem_name, $cols, $add_notes) = @_;
1539
1540        my $ss = $self->{fig}->get_subsystem($subsystem_name);
1541
1542        if (!$ss)
1543        {
1544            warn "Cannot open subsystem '$subsystem_name' to copy from";
1545            return;
1546        }
1547
1548        #
1549        # Merge the data from the other subsystem.
1550        #
1551        # First we assure ourselves that we have the appropriate roles. While
1552        # we do this, build the list of row indices (in this subsystem) that
1553        # map to the roles we are adding.
1554        #
1555
1556        #
1557        # local_roles[$his_role] = $my_role (map from other role idx to local role idx)
1558        #
1559
1560        my @local_roles;
1561
1562        #
1563        # his_roles = list of role indices corresponding to the remote roles.
1564        #
1565        my @his_roles;
1566
1567        for my $his_role (@$cols)
1568        {
1569            my $idx = $self->get_role_index($his_role);
1570            my $his_idx = $ss->get_role_index($his_role);
1571
1572            if (!defined($his_idx))
1573            {
1574                confess "Cannot map his role $his_role\n";
1575            }
1576            push(@his_roles, $his_idx);
1577
1578            if (!defined($idx))
1579            {
1580                my $his_abbr = $ss->get_role_abbr($his_idx);
1581
1582                $idx = $self->add_role($his_role, $his_abbr);
1583                print "Adding missing role $his_role idx=$idx\n";
1584            }
1585            else
1586            {
1587                print "Found existing role $his_role idx=$idx\n";
1588            }
1589
1590
1591            $local_roles[$his_idx] = $idx;
1592        }
1593
1594        #
1595        # Similar scan to ensure that we have rows for the genomes
1596        # that are in the other subsystem.
1597        #
1598
1599        my @local_genomes;
1600
1601        my @his_genomes = $ss->get_genomes();
1602
1603        for my $his_idx (0..@his_genomes - 1)
1604        {
1605            my $genome = $his_genomes[$his_idx];
1606
1607            my $my_idx = $self->get_genome_index($genome);
1608
1609            if (!defined($my_idx))
1610            {
1611                #
1612                # Not there, need to add.
1613                #
1614
1615                $my_idx = $self->add_genome($genome);
1616                print "Adding missing genome $genome idx=$my_idx\n";
1617            }
1618            else
1619            {
1620                print "Found existing genome $genome idx=$my_idx\n";
1621            }
1622
1623            $local_genomes[$his_idx] = $my_idx;
1624        }
1625
1626
1627        #
1628        # Now that we have our local roles set up to receive the data,
1629        # process the incoming roles one at a time.
1630        #
1631
1632
1633        for my $his_role (@his_roles)
1634        {
1635            my $my_col = $self->get_col($local_roles[$his_role]);
1636            my $his_col = $ss->get_col($his_role);
1637
1638            #
1639            # $his_col is the information for $his_role, indexed by
1640            # genome in @his_genomes.
1641            #
1642            # $my_col is hte information for my copy of $his_role,
1643            # indexed by genome in MY genome list.
1644            #
1645
1646            my $my_role = $local_roles[$his_role];
1647
1648            print "merging: $self->{roles}->[$my_role] $ss->{roles}->[$his_role] his_role=$his_role my_role=$my_role\n";
1649
1650            for my $his_gidx (0 .. @his_genomes - 1)
1651            {
1652                my $hisent = $his_col->[$his_gidx];
1653
1654                my $my_gidx = $local_genomes[$his_gidx];
1655
1656                my $myent = $my_col->[$my_gidx];
1657
1658                print "  his_gidx=$his_gidx my_gidx=$my_gidx hisent=@$hisent myent=@$myent\n";
1659
1660                my %new;
1661                map { $new{$_}++ } @$hisent;
1662                map { $new{$_}++ } @$myent;
1663
1664                @$myent = keys(%new);
1665
1666                print "  new entry: @$myent\n";
1667            }
1668        }
1669    }
1670
1671  sub dump  sub dump
1672  {  {
Legend:
Removed from v.1.24
changed lines
  Added in v.1.25
