[Bio] / FigKernelPackages / Stats.pm Repository:
Log of /FigKernelPackages/Stats.pm
Thu Apr 2 01:11:22 2009 UTC (10 years, 10 months ago) by parrello
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, myrast_33, myrast_rel40, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.7: +17 -0 lines
Added a method to extract saved messages.
Tue Sep 30 15:18:59 2008 UTC (11 years, 4 months ago) by parrello
CVS Tags: mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26
Changes since 1.6: +11 -5 lines
Changed to round floating-point stats to integer values.
Fri Jul 11 01:02:28 2008 UTC (11 years, 7 months ago) by parrello
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, rast_2008_0924, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_release_2008_09_29
Changes since 1.5: +75 -0 lines
Added a method to facilitate periodic tracing.
Tue Apr 29 05:49:26 2008 UTC (11 years, 9 months ago) by parrello
CVS Tags: rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21
Changes since 1.4: +21 -0 lines
Added a new method to rank the statistics.
Tue Feb 5 02:11:31 2008 UTC (12 years ago) by parrello
CVS Tags: rast_rel_2008_04_23
Changes since 1.3: +49 -36 lines
Fixed some major bugs.
Thu Dec 6 13:59:34 2007 UTC (12 years, 2 months ago) by parrello
Changes since 1.2: +9 -9 lines
Tue Feb 6 16:25:18 2007 UTC (13 years ago) by parrello
Changes since 1.1: +27 -1 lines
Added a one-line display method.
Fri Jan 6 20:42:40 2006 UTC (14 years, 1 month ago) by parrello
Moved from Sprout.
