[Bio] / FigKernelPackages / SproutSearch.pm Repository:
Log of /FigKernelPackages/SproutSearch.pm
Changes since 1.10: +17 -0 lines
Added license words.
Tue Sep 6 21:12:37 2005 UTC (14 years, 5 months ago) by overbeek
Changes since 1.9: +62 -12 lines
NMPDR seed fixes
Tue Aug 16 19:41:12 2005 UTC (14 years, 6 months ago) by overbeek
Changes since 1.8: +136 -53 lines
NMPDR updates
Wed Jul 6 04:17:38 2005 UTC (14 years, 7 months ago) by olson
Changes since 1.7: +7 -0 lines
Changes to index on property values, display properties in search output, and
display properties in protien page.
Mon Mar 7 17:16:38 2005 UTC (14 years, 11 months ago) by olson
Changes since 1.6: +2 -2 lines
Use $FIG_Config::sproutData instead of FIG_Config::fig/SproutData
Wed Feb 9 20:43:53 2005 UTC (15 years ago) by olson
Changes since 1.5: +22 -3 lines
Search fixes.
Tue Feb 1 07:05:43 2005 UTC (15 years ago) by redwards
Changes since 1.4: +16 -4 lines
Remove (or reduce) dependancy on List::Compare
Mon Jan 31 22:15:57 2005 UTC (15 years, 1 month ago) by olson
Changes since 1.3: +110 -1 lines
Fixes for new Sprout search engine.
(We preprocess the sprout tables to generate key/words tables, glimpseindex
those, then at search time, search independently on each word in the search
string and compute the intersection to form the results.)
Fri Jan 28 21:18:01 2005 UTC (15 years, 1 month ago) by olson
Changes since 1.2: +3 -1 lines
Search cleanup, more style sheet fixes.
GBrowse look cleanup.
Tue Jan 18 23:10:31 2005 UTC (15 years, 1 month ago) by olson
Changes since 1.1: +80 -10 lines
Make searching work properly.
Fri Jan 14 23:05:39 2005 UTC (15 years, 1 month ago) by olson
Sprout search engine module.
