[Bio] / FigKernelPackages / SproutFIG.pm Repository:
Log of /FigKernelPackages/SproutFIG.pm
Changes since 1.9: +17 -0 lines
Added license words.
Wed Sep 21 14:32:55 2005 UTC (14 years, 2 months ago) by olson
Changes since 1.8: +38 -8 lines
Make SproutFIG immune to errors when Sprout code is not present. It will throw
an error if an attempt to create a SproutFIG based on a sprout db when the
sprout code is not available.
Wed Jan 12 21:22:08 2005 UTC (14 years, 10 months ago) by olson
Changes since 1.7: +3 -2 lines
sprout debugging
Wed Jan 12 20:09:17 2005 UTC (14 years, 10 months ago) by parrello
Changes since 1.6: +18 -222 lines
no message
Tue Dec 14 19:54:59 2004 UTC (14 years, 11 months ago) by disz
Sprout fixes
Tue Oct 12 16:41:45 2004 UTC (15 years, 1 month ago) by olson
fix contig_of to work properly with multiple locations.
Mon Oct 11 22:34:16 2004 UTC (15 years, 1 month ago) by olson
Changes since 1.3: +7 -0 lines
more fixes
Mon Oct 11 21:04:58 2004 UTC (15 years, 1 month ago) by olson
Changes since 1.2: +10 -0 lines
Add attribute track stuff.
Mon Oct 11 18:46:45 2004 UTC (15 years, 1 month ago) by olson
Changes since 1.1: +15 -2 lines
More fixes for sprout support.
Fri Oct 8 19:39:45 2004 UTC (15 years, 2 months ago) by olson
FIG/Sprout bridge code
