[Bio] / FigKernelPackages / Sim.pm Repository:
Log of /FigKernelPackages/Sim.pm
Links to caBIG-00-00-00: (view) (download) (as text) (annotate)
Mon Aug 29 21:25:46 2005 UTC (14 years, 7 months ago) by olson
Changes since 1.5: +48 -0 lines
Add methods:
$sim = Sim->new_from_line($line): create a new sim object from a tab-delimited line of text.
$sim->as_line(): return a tab-delimited line of text for hte sim (including terminating newline)
$sim->validate(): return true if the sim is valid.
The class also overloads the convert-to-string method, so you can do stuff like
print "the sim is $sim\n";
and generate output
the sim is sim:kegg|aae:aq_016a->uni|O66436:4.6e-38
right now it just includes id1, id2, and psc. Implemented in Sim.pm as_string() method.
Mon Aug 1 22:22:13 2005 UTC (14 years, 8 months ago) by parrello
Changes since 1.4: +18 -18 lines
Changed attributes to capital-case in order to prevent the avalanche of compile-time warnings.
Thu Jun 9 05:36:30 2005 UTC (14 years, 9 months ago) by parrello
Changes since 1.3: +0 -2 lines
Fri Aug 13 01:09:27 2004 UTC (15 years, 7 months ago) by overbeek
Changes since 1.2: +20 -20 lines
Reordered access-functions into field order. -- /gdp
Tue Jun 8 20:26:05 2004 UTC (15 years, 9 months ago) by olson
Changes since 1.1: +23 -18 lines
add scalar annotations
Mon Dec 1 16:54:26 2003 UTC (16 years, 4 months ago) by efrank
Branch point for: initial
