[Bio] / FigKernelPackages / Sim.pm Repository:
Diff of /FigKernelPackages/Sim.pm
revision 1.7, Mon Dec 5 19:06:30 2005 UTC revision 1.8, Mon Oct 16 07:16:16 2006 UTC
# Line 15  Line 15
15  # http://www.theseed.org/LICENSE.TXT.  # http://www.theseed.org/LICENSE.TXT.
16  #  #
17
18    =head1 Similarity Object
19
20    =head2 Introduction
21
22    The similarity object provides access by name to the fields of a similarity
23    list. Unlike a standard object, the similarity object is stored as a list
24    reference, not a hash reference. The similarity fields are pulled from the
25    appropriate places in the list.
26
27    A blast takes a sequence called the I<query> and matches it against a
28    I<database>. When describing the data in a similarity, we will
29    refer repeatedly to the query sequence and the database sequence. Often,
30    the query and database sequences will be given by peg IDs. In some cases,
31    however, they will be contig IDs. In both cases, the match is represented
32    by an alignment between portions of the sequences. Gap characters may
33    be required to get the alignments to match, and the number of gaps is
34    part of the data in the similarity.
35
36    =cut
37
38  package Sim;  package Sim;
 use FIGAttributes;
 use base 'FIGAttributes';
39
40    =head3 as_string
41
42    C<< my $simString = "$sim"; >>
43
44    or
45
46    C<< my $simString = $sim->as_string; >>
47
48    Return the similarity as a descriptive string, consisting of the query peg,
49    the similar peg, and the match score.
50
51    =cut
52
53    use Tracer;
54  use overload '""' => \&as_string;  use overload '""' => \&as_string;
55
56  sub as_string  sub as_string {
57      my($obj) = @_;      my($obj) = @_;
58      return sprintf("sim:%s->%s:%s", $obj->id1, $obj->id2, $obj->psc);      return sprintf("sim:%s->%s:%s", $obj->id1, $obj->id2, $obj->psc);
59  }  }
60
61  sub new_from_line  =head3 new_from_line
62  {
63      my($class, $line) = @_;  C<< my $sim = Sim->new_from_line($line); >>
64
65    Create a similarity object from a blast output line. The line is presumed to have
66    the complete list of similarity values in it, tab-separated.
67
68    =over 4
69
70    =item line
71
72    Input line, containing the similarity values in it delimited by tabs. A line terminator
73    may be present at the end.
74
75    =item RETURN
76
77    Returns a similarity object that allows the values to be accessed by name.
78
79    =back
80
81    =cut
82
83    sub new_from_line {
84        my ($class, $line) = @_;
85      chomp $line;      chomp $line;
86        Trace("Data line for SIM contains: $line") if T(4);
87      my $self = [split(/\t/, $line)];      my $self = [split(/\t/, $line)];
88      return bless $self, $class;      return bless $self, $class;
89  }  }
90
91  sub validate  =head3 validate
92  {
93      my($self) = @_;  C<< my $okFlag = $sim->validate(); >>
94
95    Return TRUE if the similarity values are valid, else FALSE.
96
97    =cut
98
99    sub validate {
100        my ($self) = @_;
101      return ($self->id1 ne "" and      return ($self->id1 ne "" and
102              $self->id2 ne "" and              $self->id2 ne "" and
103              $self->iden =~ /^[.\d]+$/ and              $self->iden =~ /^[.\d]+$/ and
# Line 58  Line 114
114              $self->ln2 =~ /^\d+$/);              $self->ln2 =~ /^\d+$/);
115  }  }
116
117    =head3 as_line
118
119  sub as_line  C<< my $line = $sim->as_line; >>
     my($self) = @_;
120
121    Return the similarity as an output line. This is exactly the reverse of
122    L</new_from_line>.
123
124    =cut
125
126    sub as_line {
127        my ($self) = @_;
128      return join("\t", @$self) . "\n";      return join("\t", @$self) . "\n";
129  }  }
130
131    =head3 id1
132
133    C<< my $id = $sim->id1; >>
134
135  sub id1 :Scalar {  Return the ID of the query sequence that was blasted against the database.
136
137    =cut
138
139    sub id1 {
140      my($sim) = @_;      my($sim) = @_;
141      return $sim->[0];      return $sim->[0];
142  }  }
143
144  sub id2 :Scalar {  =head3 id2
145
146    C<< my $id = $sim->id2; >>
147
148    Return the ID of the sequence in the database that matched the query sequence.
149
150    =cut
151
152    sub id2 {
153      my($sim) = @_;      my($sim) = @_;
154      return $sim->[1];      return $sim->[1];
155  }  }
156
157  sub iden :Scalar {  =head3 iden
158
159    C<< my $percent = $sim->iden; >>
160
161    Return the percentage identity between the query and database sequences.
162
163    =cut
164
165    sub iden {
166      my($sim) = @_;      my($sim) = @_;
167      return $sim->[2];      return $sim->[2];
168  }  }
169
170  sub ali_ln :Scalar {  =head3 ali_ln
171
172    C<< my $chars = $sim->ali_ln; >>
173
174    Return the length (in characters) of the alignment between the two similar sequences.
175
176    =cut
177
178    sub ali_ln {
179      my($sim) = @_;      my($sim) = @_;
180      return $sim->[3];      return $sim->[3];
181  }  }
182
183  sub mismatches :Scalar {  =head3 mismatches
184
185    C<< my $count = $sim->mismatches; >>
186
187    Return the number of alignment positions that do not match.
188
189    =cut
190
191    sub mismatches {
192      my($sim) = @_;      my($sim) = @_;
193      return $sim->[4];      return $sim->[4];
194  }  }
195
196  sub gaps :Scalar {  =head3 gaps
197
198    C<< my $count = $sim->gaps; >>
199
200    Return the number of gaps required to align the sequences.
201
202    =cut
203
204    sub gaps {
205      my($sim) = @_;      my($sim) = @_;
206      return $sim->[5];      return $sim->[5];
207  }  }
208
209  sub b1 :Scalar {  =head3 b1
210
211    C<< my $beginOffset = $sim->b1; >>
212
213    Return the position in the query sequence at which the alignment begins.
214
215    =cut
216
217    sub b1 {
218      my($sim) = @_;      my($sim) = @_;
219      return $sim->[6];      return $sim->[6];
220  }  }
221
222  sub e1 :Scalar {  =head3 e1
223
224    C<< my $endOffset = $sim->e1; >>
225
226    Return the position in the query sequence at which the alignment ends.
227
228    =cut
229
230    sub e1 {
231      my($sim) = @_;      my($sim) = @_;
232      return $sim->[7];      return $sim->[7];
233  }  }
234
235  sub b2 :Scalar {  =head3 b2
236
237    C<< my $beginOffset = $sim->b2; >>
238
239    Position in the database sequence at which the alignment begins.
240
241    =cut
242
243    sub b2 {
244      my($sim) = @_;      my($sim) = @_;
245      return $sim->[8];      return $sim->[8];
246  }  }
247
248  sub e2 :Scalar {  =head3 e2
249
250    C<< my $endOffset = $sim->e2; >>
251
252    Return the position in the database sequence at which the alignment ends.
253
254    =cut
255
256    sub e2 {
257      my($sim) = @_;      my($sim) = @_;
258      return $sim->[9];      return $sim->[9];
259  }  }
260
261  sub psc :Scalar {  =head3 psc
262
263    C<< my $score = $sim->psc; >>
264
265    Return the similarity score as a floating-point number. The score is the computed
266    probability that the similarity is a result of random chance. A score of 0 indicates a
267    perfect match. A higher score indicates a less-perfect match. Values of C<1e-10> or
268    less are considered good matches.
269
270    =cut
271
272    sub psc {
273      my($sim) = @_;      my($sim) = @_;
274      return ($sim->[10] =~ /^e-/) ? "1.0" . $sim->[10] : $sim->[10];      return ($sim->[10] =~ /^e-/) ? "1.0" . $sim->[10] : $sim->[10];
275  }  }
276
277  sub bsc :Scalar {  =head3 bsc
278
279    C<< my $score = $sim->bsc; >>
280
281    Return the bit score for this similarity. The bit score is an estimate of the
282    search space required to find the similarity by chance. A higher bit score
283    indicates a better match.
284
285    =cut
286
287    sub bsc {
288      my($sim) = @_;      my($sim) = @_;
289      return $sim->[11];      return $sim->[11];
290  }  }
291
292  sub bit_score :Scalar {  =head3 bsc
293
294    C<< my $score = $sim->bit_score; >>
295
296    Return the bit score for this similarity. The bit score is an estimate of the
297    search space required to find the similarity by chance. A higher bit score
298    indicates a better match.
299
300    =cut
301
302    sub bit_score {
303      my($sim) = @_;      my($sim) = @_;
304      return $sim->[11];      return $sim->bsc;
305  }  }
306
307  sub ln1 :Scalar {  =head3 ln1
308
309    C<< my $length = $sim->ln1; >>
310
311    Return the number of characters in the query sequence.
312
313    =cut
314
315    sub ln1 {
316      my($sim) = @_;      my($sim) = @_;
317      return $sim->[12];      return $sim->[12];
318  }  }
319
320  sub ln2 :Scalar {  =head3 ln2
321
322    C<< my $length = $sim->ln2; >>
323
324    Return the length of the database sequence.
325
326    =cut
327
328    sub ln2 {
329      my($sim) = @_;      my($sim) = @_;
330      return $sim->[13];      return $sim->[13];
331  }  }
332
333  sub tool :Scalar {  =head3 tool
334
335    C<< my $name = $sim->tool; >>
336
337    Return the name of the tool used to find this similarity.
338
339    =cut
340
341    sub tool {
342      my($sim) = @_;      my($sim) = @_;
343      return $sim->[14];      return $sim->[14];
344  }  }
345
346  sub def2 :Scalar {  sub def2 {
347      my($sim) = @_;      my($sim) = @_;
348      return $sim->[15];      return $sim->[15];
349  }  }
350
351  sub ali :Scalar {  sub ali {
352      my($sim) = @_;      my($sim) = @_;
353      return $sim->[16];      return $sim->[16];
354  }  }
355
356  1  1;
Legend:
Removed from v.1.7
changed lines
  Added in v.1.8
