[Bio] / FigKernelPackages / ServerThing.pm Repository:
Log of /FigKernelPackages/ServerThing.pm
Wed Feb 9 17:56:09 2011 UTC (9 years, 1 month ago) by parrello
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011
Changes since 1.61: +7 -1 lines
Diff to previous 1.61 , to selected 1.39
Changed to store the CGI object in the server object.
Wed Jan 26 15:32:08 2011 UTC (9 years, 2 months ago) by dejongh
Diff to previous 1.60 , to selected 1.39
fix handling of server name
Tue Jan 25 22:44:43 2011 UTC (9 years, 2 months ago) by chenry
Changes since 1.59: +12 -2 lines
Diff to previous 1.59 , to selected 1.39
Added small change to code to handle ModelSEED::FBAMODEL package.
Tue Jan 11 15:03:02 2011 UTC (9 years, 2 months ago) by parrello
CVS Tags: rast_rel_2011_0119
Changes since 1.58: +3 -1 lines
Diff to previous 1.58 , to selected 1.39
Fix to reduce Sapling dependence.
Sat Oct 30 13:52:58 2010 UTC (9 years, 5 months ago) by parrello
CVS Tags: rast_rel_2010_1206
Changes since 1.57: +39 -2 lines
Diff to previous 1.57 , to selected 1.39
New Sapling update support.
Thu Oct 21 13:03:16 2010 UTC (9 years, 5 months ago) by parrello
Changes since 1.56: +2 -6 lines
Diff to previous 1.56 , to selected 1.39
Enhanced "subsystems_for_role", removed reverse-arrow check for correspondence files.
Thu Oct 14 17:28:49 2010 UTC (9 years, 5 months ago) by parrello
Changes since 1.55: +58 -0 lines
Diff to previous 1.55 , to selected 1.39
Expression vector support methods.
Thu Jul 29 17:35:51 2010 UTC (9 years, 8 months ago) by parrello
Changes since 1.54: +2 -0 lines
Diff to previous 1.54 , to selected 1.39
Added support for using SAS_SERVER environment variable to configure the appropriate server.
Tue Jul 13 18:49:09 2010 UTC (9 years, 8 months ago) by parrello
Changes since 1.53: +13 -10 lines
Diff to previous 1.53 , to selected 1.39
Fixed so that if no parameter is specified, it is not parsed.
Thu Jul 8 20:15:39 2010 UTC (9 years, 8 months ago) by parrello
Changes since 1.52: +65 -0 lines
Diff to previous 1.52 , to selected 1.39
Updates for new expression-data method.
Mon Jun 14 14:36:02 2010 UTC (9 years, 9 months ago) by parrello
Changes since 1.51: +28 -7 lines
Diff to previous 1.51 , to selected 1.39
Updates for auxiliary role filtering.
Wed Apr 28 15:46:38 2010 UTC (9 years, 11 months ago) by parrello
CVS Tags: rast_rel_2010_0526
Changes since 1.50: +10 -4 lines
Diff to previous 1.50 , to selected 1.39
Wed Apr 28 15:31:12 2010 UTC (9 years, 11 months ago) by parrello
Changes since 1.49: +2 -1 lines
Diff to previous 1.49 , to selected 1.39
Fixed an error in the Java interface.
Wed Apr 28 14:02:11 2010 UTC (9 years, 11 months ago) by parrello
Changes since 1.48: +53 -3 lines
Diff to previous 1.48 , to selected 1.39
Added JSON support.
Fri Apr 16 21:39:51 2010 UTC (9 years, 11 months ago) by olson
Changes since 1.47: +1 -1 lines
Diff to previous 1.47 , to selected 1.39
Push down max requests.
Tue Apr 13 20:05:49 2010 UTC (9 years, 11 months ago) by parrello
Changes since 1.46: +33 -2 lines
Diff to previous 1.46 , to selected 1.39
Updated for computing previously-mapped genomes.
Wed Mar 31 17:09:15 2010 UTC (10 years ago) by parrello
Changes since 1.45: +1 -1 lines
Diff to previous 1.45 , to selected 1.39
Added module name to the documentation page titles.
Fri Mar 19 18:27:07 2010 UTC (10 years ago) by parrello
Changes since 1.44: +1 -1 lines
Diff to previous 1.44 , to selected 1.39
Fri Mar 19 15:08:27 2010 UTC (10 years ago) by parrello
Changes since 1.43: +9 -6 lines
Diff to previous 1.43 , to selected 1.39
Fri Mar 19 03:43:08 2010 UTC (10 years ago) by parrello
Changes since 1.42: +2 -2 lines
Diff to previous 1.42 , to selected 1.39
Fri Mar 19 00:15:05 2010 UTC (10 years ago) by parrello
Changes since 1.41: +1 -1 lines
Diff to previous 1.41 , to selected 1.39
Thu Mar 18 23:06:48 2010 UTC (10 years ago) by parrello
Changes since 1.40: +40 -2 lines
Diff to previous 1.40 , to selected 1.39
Fixed a bug in the corresponding-genes code.
Tue Mar 16 20:24:05 2010 UTC (10 years ago) by parrello
Changes since 1.39: +9 -3 lines
Diff to previous 1.39
Added option to include reverse correspondences in correspondence map output.
Revision 1.39 - (view) (download) (as text) (annotate) - [selected]
Tue Mar 16 19:50:43 2010 UTC (10 years ago) by parrello
Changes since 1.38: +27 -3 lines
Diff to previous 1.38
Made gene correspondence submission more robust.
Sun Mar 14 14:30:12 2010 UTC (10 years ago) by parrello
Diff to previous 1.37 , to selected 1.39
Sun Mar 14 13:26:32 2010 UTC (10 years ago) by parrello
Changes since 1.36: +430 -49 lines
Diff to previous 1.36 , to selected 1.39
Updates for new gene correspondence system.
Thu Feb 25 20:30:10 2010 UTC (10 years, 1 month ago) by parrello
Changes since 1.35: +78 -0 lines
Diff to previous 1.35 , to selected 1.39
Added enhanced support for gene correspondence maps.
Fri Jan 29 16:08:29 2010 UTC (10 years, 2 months ago) by parrello
Changes since 1.34: +29 -20 lines
Diff to previous 1.34 , to selected 1.39
Fixed an error in the handling of optional identifier lists.
Wed Dec 16 20:57:35 2009 UTC (10 years, 3 months ago) by parrello
CVS Tags: rast_rel_2010_0118
Changes since 1.33: +0 -1 lines
Diff to previous 1.33 , to selected 1.39
Fixed so that the ETracing parameter overrides the environment variable.
Wed Dec 16 20:50:31 2009 UTC (10 years, 3 months ago) by parrello
Changes since 1.32: +1 -0 lines
Diff to previous 1.32 , to selected 1.39
Testing hack.
Wed Dec 16 18:49:10 2009 UTC (10 years, 3 months ago) by parrello
Changes since 1.31: +19 -15 lines
Diff to previous 1.31 , to selected 1.39
Modified so that errors will appear in the trace file by default.
Mon Dec 14 20:59:35 2009 UTC (10 years, 3 months ago) by disz
Changes since 1.30: +51 -1 lines
Diff to previous 1.30 , to selected 1.39
Added LineNumberize
Fri Dec 11 21:21:04 2009 UTC (10 years, 3 months ago) by parrello
Changes since 1.29: +10 -2 lines
Diff to previous 1.29 , to selected 1.39
Server database recovery fix.
Thu Dec 10 19:12:21 2009 UTC (10 years, 3 months ago) by parrello
Changes since 1.28: +2 -2 lines
Diff to previous 1.28 , to selected 1.39
Increased request limit to 5000. Streamlined tracing at level 2.
Thu Dec 10 17:23:23 2009 UTC (10 years, 3 months ago) by parrello
Diff to previous 1.27 , to selected 1.39
Thu Dec 10 17:09:22 2009 UTC (10 years, 3 months ago) by parrello
Diff to previous 1.26 , to selected 1.39
Thu Dec 10 16:40:12 2009 UTC (10 years, 3 months ago) by parrello
Changes since 1.25: +5 -5 lines
Diff to previous 1.25 , to selected 1.39
Thu Dec 10 15:34:10 2009 UTC (10 years, 3 months ago) by parrello
Changes since 1.24: +4 -13 lines
Diff to previous 1.24 , to selected 1.39
Thu Dec 10 15:13:51 2009 UTC (10 years, 3 months ago) by parrello
Diff to previous 1.23 , to selected 1.39
Trying to trace the FastCGI problem.
Wed Dec 9 21:43:59 2009 UTC (10 years, 3 months ago) by parrello
Changes since 1.22: +2 -2 lines
Diff to previous 1.22 , to selected 1.39
Changed to accept CGI request only if the request limit has not yet been reached.
Tue Dec 8 14:53:52 2009 UTC (10 years, 3 months ago) by parrello
Changes since 1.21: +11 -4 lines
Diff to previous 1.21 , to selected 1.39
Converted subsystem filtering from "unusable" to "usable".
Sun Dec 6 18:21:07 2009 UTC (10 years, 4 months ago) by parrello
Changes since 1.20: +64 -0 lines
Diff to previous 1.20 , to selected 1.39
Added new subsystem methods.
Fri Dec 4 19:23:43 2009 UTC (10 years, 4 months ago) by parrello
Diff to previous 1.19 , to selected 1.39
Fixed bad URL in "ProducePod".
Thu Dec 3 15:34:16 2009 UTC (10 years, 4 months ago) by parrello
Changes since 1.18: +25 -11 lines
Diff to previous 1.18 , to selected 1.39
Added server to search for roles and/or functions in a genome.
Mon Nov 30 18:08:25 2009 UTC (10 years, 4 months ago) by parrello
Changes since 1.17: +3 -2 lines
Diff to previous 1.17 , to selected 1.39
Made memory tracing better.
Mon Nov 30 17:50:25 2009 UTC (10 years, 4 months ago) by parrello
Changes since 1.16: +1 -0 lines
Diff to previous 1.16 , to selected 1.39
Added optional memory tracing.
Mon Nov 30 17:39:47 2009 UTC (10 years, 4 months ago) by parrello
Diff to previous 1.15 , to selected 1.39
Removed trace hacks.
Mon Nov 30 12:47:36 2009 UTC (10 years, 4 months ago) by parrello
Changes since 1.14: +7 -5 lines
Diff to previous 1.14 , to selected 1.39
Added task IDs to trace messages.
Mon Nov 30 11:44:50 2009 UTC (10 years, 4 months ago) by parrello
Changes since 1.13: +1 -0 lines
Diff to previous 1.13 , to selected 1.39
Added a memory trace for fast CGI mode.
Wed Nov 25 22:34:35 2009 UTC (10 years, 4 months ago) by parrello
Changes since 1.12: +62 -66 lines
Diff to previous 1.12 , to selected 1.39
Fixed to only allocate the server object once during a FASTCGI loop.
Wed Nov 25 21:52:02 2009 UTC (10 years, 4 months ago) by parrello
Diff to previous 1.11 , to selected 1.39
Wed Nov 25 21:38:05 2009 UTC (10 years, 4 months ago) by parrello
Changes since 1.10: +9 -2 lines
Diff to previous 1.10 , to selected 1.39
Added maximum number of requests.
Tue Nov 3 21:20:07 2009 UTC (10 years, 5 months ago) by parrello
Changes since 1.9: +44 -12 lines
Diff to previous 1.9 , to selected 1.39
Error handling restructure.
Thu Oct 29 18:26:59 2009 UTC (10 years, 5 months ago) by parrello
Changes since 1.8: +231 -100 lines
Diff to previous 1.8 , to selected 1.39
Final server updates.
Wed Sep 30 15:34:28 2009 UTC (10 years, 6 months ago) by parrello
Changes since 1.7: +82 -1 lines
Diff to previous 1.7 , to selected 1.39
Moved DocUtils so that it is only included if needed.
Wed Sep 9 15:20:54 2009 UTC (10 years, 6 months ago) by parrello
CVS Tags: rast_rel_2009_0925
Diff to previous 1.6 , to selected 1.39
Fixed CSS link.
Thu Aug 27 19:44:45 2009 UTC (10 years, 7 months ago) by parrello
Changes since 1.5: +60 -15 lines
Diff to previous 1.5 , to selected 1.39
Converted to handle Fast CGI requests.
Tue Aug 4 18:41:56 2009 UTC (10 years, 8 months ago) by parrello
Changes since 1.4: +8 -6 lines
Diff to previous 1.4 , to selected 1.39
Changed handling of documentation URL.
Tue Aug 4 18:19:59 2009 UTC (10 years, 8 months ago) by parrello
Changes since 1.3: +67 -43 lines
Diff to previous 1.3 , to selected 1.39
Added documentation functions to the Sapling server.
Mon Aug 3 21:31:42 2009 UTC (10 years, 8 months ago) by parrello
Changes since 1.2: +11 -1 lines
Diff to previous 1.2 , to selected 1.39
Updated to Sapling Server for Berkeley.
Tue Jun 30 20:11:54 2009 UTC (10 years, 9 months ago) by parrello
CVS Tags: rast_rel_2009_07_09
Diff to previous 1.1 , to selected 1.39
Additional functionality for sapling server.
Tue Jun 16 16:37:23 2009 UTC (10 years, 9 months ago) by parrello
Diff to selected 1.39
New Sapling server support.
