[Bio] / FigKernelPackages / SeedV.pm Repository:
Log of /FigKernelPackages/SeedV.pm
Thu Dec 24 15:54:15 2015 UTC (4 years, 3 months ago) by gdpusch
CVS Tags: HEAD
Add test to flip to "metagenome" mode for genomes smaller than 25 kbp, so that PRODIGAL will not bail out.FigKernelPackages/Prodigal.pm
Wed Jun 8 14:56:26 2011 UTC (8 years, 9 months ago) by olson
CVS Tags: mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_rel40, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.9: +6 -22 lines
fix nasty boundary bug
Mon Oct 4 11:04:59 2010 UTC (9 years, 5 months ago) by gdpusch
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, myrast_33, rast_rel_2010_1206, rast_rel_2011_0119
Changed a debugging line to print to STDERR, not STDOUT; print only if VERBOSE.
Tue Aug 31 19:03:59 2010 UTC (9 years, 7 months ago) by olson
CVS Tags: rast_rel_2010_0928
Changes since 1.7: +17 -5 lines
Banish globbing. Doesn't work on windows.
Sun Aug 29 21:30:44 2010 UTC (9 years, 7 months ago) by olson
Changes since 1.6: +17 -1 lines
add write_features_for_comparison
Fri Aug 27 19:23:51 2010 UTC (9 years, 7 months ago) by olson
Changes since 1.5: +291 -6 lines
many DTR fixups
Thu Aug 19 19:39:41 2010 UTC (9 years, 7 months ago) by olson
CVS Tags: rast_rel_2010_0827
Changes since 1.4: +3 -9 lines
fix to contig stuff
Wed Aug 18 21:53:56 2010 UTC (9 years, 7 months ago) by olson
Changes since 1.3: +188 -48 lines
Desktop rast fixes
Tue Aug 10 19:38:47 2010 UTC (9 years, 7 months ago) by olson
Changes since 1.2: +198 -10 lines
Changes for DesktopRast.
CVHnS: ----------------------------------------------------------------------
Thu Dec 17 21:35:51 2009 UTC (10 years, 3 months ago) by olson
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526
Changes since 1.1: +5 -1 lines
remove Tracer ref
Mon Dec 14 02:11:58 2009 UTC (10 years, 3 months ago) by overbeek
numerous changes
