[Bio] / FigKernelPackages / SeedUtils.pm Repository:
Diff of /FigKernelPackages/SeedUtils.pm
revision 1.3, Wed Jul 15 23:37:46 2009 UTC revision 1.4, Mon Aug 3 21:31:42 2009 UTC
# Line 40  Line 40
40
41  Create a FASTA record from the specified DNA or protein sequence. The  Create a FASTA record from the specified DNA or protein sequence. The
42  sequence will be split into 60-character lines, and the record will  sequence will be split into 60-character lines, and the record will
43  include an identifier line and the trailing double-slash.  include an identifier line.
44
45  =over 4  =over 4
46
# Line 87  Line 87
87      Trace(scalar(@chunks) . " chunks found in sequence of length " .      Trace(scalar(@chunks) . " chunks found in sequence of length " .
88            length($sequence) . ".") if T(3);            length($sequence) . ".") if T(3);
89      # Add the chunks and the trailer.      # Add the chunks and the trailer.
90      my $retVal = join("\n", $header, @chunks, "//\n");      my $retVal = join("\n", $header, @chunks);
91      # Return the result.      # Return the result.
92      return $retVal;      return $retVal;
93  }  }
Legend:
Removed from v.1.3
changed lines
  Added in v.1.4
